Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Always running out of ice - Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 01, 2010
Kenmore Elite Model # 795.7205 Ice dispenser pad does not always shut off when released
Ice Maker Doesn't Turn Off If your ice maker keeps making ice, even when it is full:
1Lift the bail wireto shut off the ice maker, and remove the ice bin. Then, using a screwdriver if necessary, remove the ice maker, clean it thoroughly, and then reinstall it.
2If the problem persists,consider removing and replace the entire ice maker and valve. With this type of problem, you can have it repaired, but it's often wiser and less expensive in the long run to replace the unit entirely.
Feb 28, 2015 | Kenmore Refrigerators
We have a new 3 month old frigdaire gallery and the Ice makes doesn't constantly make ice and we are always running out. There are only two of us using the ice. What is wrong
The energy efficiency cuts down on the functionality. Newer refrigerators will only make 100cubes of ice in a 24 hour period try lower your freezer temp to -2 to help it run longer.
Feb 15, 2015 | Refrigerators
My ref/frez is out of plumb- how do you adjust the feet?
I found a solution in another question for a different fridge. I believe the solenoid that opens and closes the trap door for the ice is not functioning, causing the ice to either always crush or stay cubed, depending on the orientation of the metal rod that runs along the bottom of the ice bucket. Pull out the bucket and slightly twist this metal rod in the opposite direction, reinsert the bucket, and you should now have the opposite of what you had before (crushed vs cubed, vice versa). The solenoid should rotate this rod for you, but if it's busted then that doesn't happen. If you always use one type of ice, you'll be fine, but if you want to choose between crushed/cubed, you'll probably need to replace this solenoid.
Jul 09, 2013 | Kenmore Top Freezer Refrigerator
I have a problem with the ice maker, went i turn it on in ice switch the compressor no running only the the water pump and led indecator is always clean.
you need to send the model number and brand name of the refrigerator.if it's a G.E. and the reason i ask is that i saw this happen on a G.E. refrigerator,when you hit the ice switch or for water the compressor stops running.the problem is the computer board,the common board number is wr55x10942.
Apr 01, 2011 | Kitchen Ranges
Ice is forming on coil fins
Either your coil is dirty or filter is dirty. Worst case your low on freon which would make a coil freeze.But freon doesn't evaporate if your low there must be a slow leak.
May 19, 2010 | LG Heat cool Window Air Conditioner
Viking refrigerator with bottom freezer always running
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 05, 2009 | Viking VCBB363L Bottom Freezer...
Ice dispenser will not stop. Motor continues to run even after re
hi there,
replace the lever switch it was already defective it always contactor normaly close,let the qualified techinician do this for you.
besure to unplug the unit before doing this.have a nice day.don't forgety to rate me,thank's a lot
Mar 30, 2009 | Frigidaire FRS26H5AS Side by Side...
Ice maker not working now refridge seals are hot, but still cooi
okay....i used to be an employee at Vinothque and these piece of **** units are always and I mean always running low on refrigerant, due to a slow leak in the system. You will have to get tech to come out and recharge the unit
Dec 29, 2008 | Refrigerators
Ice maker water overflow
ITS BEST THAT YOU GET A TECHNICIAN TO SOLVE THIS FOR YOU AS ADJUSTING THE WATER FLOW ON THE ICE MAKER CAN BE A BIT TRICKY.GOOD LUCK.MOHAMED
Sep 02, 2008 | Whirlpool ED2FHEXN Side by Side...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
