My York ac runs for an hour or so and then the fan stops?
  • 32 Answers
Sounds like a bad fan motor or capacitor
Posted on Aug 31, 2010
YORK OUTSIDE UNIT MODEL # HP036X1021A
You must change the fan motor or you will have more problems
with car temperature!
May 09, 2014 | Canvas Dipped York Brief - Grey
During a three hour drive back home, our AC stopped blowing cold air. If you stick your hand in front of the vent, you can feel cold air, but it doesn't blow. If you turn the fan up all the way, you can...
Have your a/c pressure tested, the clicking could be the a/c compr coming on and off due to low freon, it will do that so it don't damage your compr when there is none or low freon.
Jun 14, 2010 | 2005 Mitsubishi Endeavor
Wiring Question York Diamond 90 Condensor Unit - New Capacitor
the wire diagram should tell you how. it all depends where wires lead to. be very carefull, capacitors can be dangerous. brown usaully go to fan black usaully goes to common red usaully goes to herm or compressor. it all depends where wires come from
Aug 27, 2009 | Heating & Cooling
Fan runs for a minute then slows and stops.
Sounds like the capacitor..
Don't run it until the problem is fixed..
IF and only IF - you are pretty handy and have knowledge,,
Perhaps you could try this...
BE SURE POWER IS OFF to the ac unit..
Cut the breakers OFF in the breaker box !!
IF YOU CAN NOT GET THE BREAKERS OFF AND/OR CUT THE POWER TO AC - DO NOT GO ANY FURTHER !!
IF THERE IS ANY POWER GOING TO UNIT - YOU COULD BE SERIOUSLY HURT OR KILLED...
Inside the unit – the capacitor is metal & looks kinda like a can (round or oval) & has 3 wire connections at the top..
Do not remove capacitor until you have a new replacement to put in..
Be careful to not mix up the wire sequence..
Change one wire at a time and be very sure..
A capacitor is cheaper than a fan motor - and makes the most sense to replace..
If you are not at all comfortable trying this - get a ac company with a trained tech out to do it..
Hope this helps !!
Aug 17, 2009 | Ruud Matching Split Air Conditioner
Samsung 1.5 ton slpit AC.the out door unit is very noisy
Check to see if the noise is coming from the fan, could be bad bearings. Replace the fan motor if that is the case. If the noise is coming from the compressor, the only other place besides the fan, then your compressor has some issues and will probably stop working soon, maybe line up for a replacement before you are left with a hot house.
Jun 11, 2009 | Fujitsu 24C1 Air Conditioner
Goodman CKL60-1 Condenser Fan Runs OK, then stops
check connections tightness or if you just change the connector will solve the problem that is if the motor has not burn out yet
May 28, 2009 | Goodman CKL60AR60 Air Conditioner
Bad bearings on the motor or check the fan rotations . Air should always blow out the top and **** in through the sides or coils.!... Thank-you-very-much!
Aug 25, 2008 | Goodman CKL60AR60 Air Conditioner
1993 Toyata Previa
El encendido es demorado, hay que darle varios startes.
La luz testigo indicadora de la presión de aceite no se apaga sino después de un rato de funcionamiento del motor.
Jun 14, 2008 | 1993 Toyota Previa
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
