Question about HP Officejet 5610 All-In-One InkJet Printer
Installed new black cartridge yesterday,now today when I go to print it says cartridge error check documentaion,which Im not sure what they mean ? please help
    President:
  • 4,070 Answers
Hi! Please remove the black cartridge and shake it a little. You need to do this when installing a new set of cartridges. Hope this helps and thank you for using FixYa!
Posted on Aug 31, 2010
My MP490 is saying that I do not have the print head installed. It worked fine when I last used it on yesterday. Today nothing! Can anyone help with how to lear the message?
The printhead not installed error means that the printhead and the printer itself are not communicating properly. This could be a temporary system error, the printhead (cartridge) having failed or the printer needing service.
Make sure that both cartridges (color and black) are installed correctly and are the Canon cartridges for this printer. Replace if they are low or have clogged with ink from going unused. (Note: the color cartridge goes on the left and the cover for each cartridge should close with a click and be flush against the cartridge.)
To check if this is a temporary error, with the printer on, unplug your data cable (USB), then remove the ink cartridges. When the printer indicates "Insert ink cartridges", unplug the power cable from the back of the printer. (I tend to unplug the data cable from both the computer and the printer and the power cord from the wall after removing it from the printer as well.) Wait a minute then plug the power cord back into the wall outlet (if unplugged) and then into the printer. Turn on the printer if needed. Then reinsert the ink cartridges when prompted to do so. (Make sure to fully seat the cartridges.) Close the scanner unit and print a calibration page if you see a prompt for one. Then reconnect your USB cable and try printing a job.
If this doesn't solve the problem, then decide if the printer is worth servicing if it is out of warranty or conact Canon if it is in warranty.
I hope this helps.
Aug 12, 2011 | Canon MP490 InkJet Printer
HP 4015x and I get an insert black cartridge error. Not sure what I should be replacing on it or what to check on the printer.
Thank you for contacting FixYa with your printer inquiry.
This error is most common when your toner cartridge has reached it's end of life. Sometimes it will alternate with "This cartridge has reached a low threshold error" which indicates you can keep printing but need to order a new toner cartridge. See page 155 of your support manual for more on this error.
See page #117 of your user guide for toner installation instructions. http://h20000.www2.hp.com/bc/docs/support/SupportManual/c01295101/c01295101.pdf
If you have installed a new toner cartridge and receive "Remove Shipping Lock Error" that means you have not removed the protective strip on page 118 step #5.
You can order new toner cartridge from HP PartSurfer or retail merchant where printer purchased.
http://partsurfer.hp.com/Search.aspx?SearchText=CB511A CC364-67902 Black print cartridge - Prints approximately 24,000 pages per cartridge CC364-67901 Black print cartridge - Prints approximately 10,000 pages per cartridge
Hope this helps helps. Please keep us updated and remember to rate this answer.
Mar 30, 2011 | HP Laserjet P4015x Printer
I have the same problem but mine is with a canon mp190. also says E5 error on lcd and 2,114,0 eror when i try and scan. what can i do
According the Canon the error code means this:
E, 4/ E, 5 The FINE Cartridge cannot be recognized
The FINE Cartridge may not be installed properly, or the Cartridge may not be compatible with this machine. Open the Scanning Unit (Cover), and then make sure that the FINE Cartridges are installed properly and that the installed FINE cartridges are compatible with the machine.
If the error is not resolved, the Print Head may be damaged. Contact your Canon Service representative.
The "fine cartridge" means the black printing cartridge. The black should be installed on the left and the color on the right.
Double check to make sure your cartridges are installed on the correct sides.
After verifying that they are on the appropriate sides, then turn off your printer and unplug it from the power source.
Remove and reinstall the black cartridge.
Plug the printer back in and turn it on. If the error code is still there, press the menu button and scroll using the arrows until you see the "maintenance" area on your printers display. Then press enter or "ok". Continue scrolling until you find the "clean print heads" function and then again press enter or "ok" Follow the instructions and clean the print heads at least two times.
If the cartridge is full and installed correctly, the according to Canon the print heads have trapped old ink in them and this could be cloggin the ink flow. Cleaning the print heads should solve that problem. If you still get the error code after cleaning the print heads a couple times then I suggest contacting Canon for a possible warranty repair.
Nov 25, 2010 | Canon PIXMA MP190 All-In-One InkJet...
We have an HP 2015n printer with an error code of 10.1000. Can you please tell me what this code means? Thanks
10.1000 Black e-label missing error Error message 10.1000 supply error alternates with Reinstall c00381084.jpg with a ? under the Black print cartridge gas gauge Description The black print cartridge or print cartridge e-label is missing. Action
  1. Install the black print cartridge.
NOTE: If this error occurs upon initial power-up on the printer, remove all cartridges to check for the orange packing tape. If present, remove it before reinstalling the toners.
Nov 10, 2010 | Computers & Internet
My hp lasrejet 5000 N does not print on one side? new cartridge installed today.
Two possibilities
1. check to make sure the laser scanner glass is clean (glass is located above the toner cartridge when you take it out. you might need to move a metal cover that covers the glass)
2. clean the transfer roller. (black spongy roller that sits just below the cartridge).
use a lint free cloth
Jul 18, 2010 | HP LaserJet 5000 Printer
Hello! My Lexmark X2350 today said me: "Unsupported cartridge Install a correct print cartridge." Yesterday it printed very well... but today((( What I must do now? help me !
Follow the steps on how to correct the error from this Lexmark link:
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:487:0:0&docid=ENUS24096
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
May 11, 2009 | Lexmark X2470 All-In-One InkJet Printer
Won't print gives error message above power and function push button incorrect color cartridge installed---was working fine yesterday no cartridge was done...
uninstall and reinstall printer and make sure u follow the promp and put the right cartridge in the right spot....black and color....2 different chambers
Apr 19, 2009 | HP PSC 750 All-In-One InkJet Printer
E5 Error when I reinstalled new & original cartridges
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
597
Jul 01, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Cartridge error
I switched my cartridges, color in black and vice versa, then printed test page then switched them back and they worked fine.
Oct 24, 2007 | Dell A940 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
