Question about Refrigerators
Want to remove and clean the drip tray on my beko la 620w fridge
  • 1122 Answers
SOURCE: Remove drip tray from bosch KTR1670GB
YOU MIGHT TRY TO UNCLIP THE COMPRESSOR AND MOVE IT OUT SLOWLY AS HOT TO KINK THE COPPER TUBING,ALSO MAKE SURE YOU USE CLAUK UNDER THE DRAIN PAN SO IT DOES NOT LEAK,HOPE THIS HELP,THANKS-MIKE
Posted on Jun 01, 2008
  • 6 Answers
SOURCE: freezer drips water into frigde filling up ottom tray
Hello, If it is a top mount freezer then there is a drain that runs from the freezer to the drain pan that gets gummed up sometimes and if that happens then the water has no place to go but the fridge. Look all the way in the back of the fridge and you'll see a yellowish colored tube. You can just pop that out and take it to the sink and clean it out.. Hope this helps
Posted on Feb 18, 2009
SOURCE: Cleaning drip tray.
I have just removed the drip tray from my fridge freezer and it was relatively easy.
Do not remove the compressor unit.
The drip tray is held in place by a metal clasp which is welded to the top of the compressor. The clasp is a flat piece of metal which must physically twisted to align with the key way in the plastic drip tray. I used thin pair of pliers to grip the clasp and twist it clockwise to line up with the tray key way. The tray then has to be carefully manouvred off the compressor so as not to cause damage or spill it foul smelling contents. This I managed to achieve fairly easily.
Clean out and install then twist the clasp to clamp the tray into position. I don't know what would happen if you didnt lock the tray back in position as it does not seem capable of falling off on its own and it would be easier to remove next time.
Hope this makes sense
Mark
Posted on Mar 05, 2009
Maytag317
  • 1136 Answers
SOURCE: need to remove drip pan
Hi, This pan can not be removed without taking the whole frame apart. Best thing is to try and get a long brush (hardware stores sell them) and try and clean it that way.
Using very hot water might help loosen the grime in the pan.
I hope this helps you.
Please let me know if I can assist you further.
Vic
Posted on May 30, 2009
SOURCE: my beko fridge freezer keeps making a dripping noise
im fridge freezer maken bubbleing noise
Posted on Jul 26, 2009
How do I remove the plastic drip tray from behind my Wesitnghouse Aurora Fridge Freezer.
we had a really bad smell coming from the back of our westinghouse aurora. and yes found it to be emanating from drip tray at the back. To remove this we had to undo 4 clips at the base of black motor thingy, that the plastic drip box sits on. Then we were able to lift whole thing a bit ,(10mm up and 50mm out, approx) so we could tilt everything forward and sweeze and wiggle tray out. then cleaned with bleach. also we unblocked hole inside fridge that allows water to drip into drip tray at back.
Jun 01, 2011 | Westinghouse Refrigerators
Milk which was spilled in the fridge has dripped into the drip tray behind the fridge and has created the most awful smell. Can the tray be removed for cleaning and if so how?
Yes, usually the tray can be removed for cleaning. You will have to pull the fridge out, unplug power, remove the rear access cover. Then you should see the evaporator / condensate tray and how to remove it.
Jun 22, 2010 | Refrigerators
Fridge drip tray removal
remove toe kick on bottom of fridge, should be some screws on both sides. tray slides out, maybe not all the way dont force, there is a float mechanism that will stop it from coming out all the way, use some paper towels or rags to soak up the stagnant water, this pan should have a heater hooked up to it to evaporate the water, the installer should have hooked this up on installation, they dont hook it up at the factory to get a better EER out the factory door, just trace back to the pan and hook up any unplugged wires going to it, good luck
Oct 31, 2009 | Miele KF7642S Bottom Freezer Refrigerator
How to clean evaporator beko fridge
I've tried to remove but can't. I've now resorted to soaking up the liquid in the reservoir with kitchen roll then spraying with general household cleaner and once again mopping up with kitchen roll. You could try a weak solution of bleach or a mixture of bicarb and water instead of general purpose spray
Sep 20, 2009 | Belkin F1DK102P 2-port KVM Switch
Strong odour coming from non-removable tray under new fridge
do not frustrated .firsly you should look for any THING THAT block the drip tray from geting out. usually it can be pulled out by PUSH ASIDE THE DRIP HOST SOMTIMES BLOCKING THE DRIP TRAY MOVEMENT IN OR OUT.
LATER CLEANED THE DRIP TRAY & REINSERT IT BACK TO ORIGINAL SITE
Sep 24, 2017 | Kenmore 44273 Side by Side Refrigerator
Cleaning drip tray.
Mark
Mar 10, 2008 | Refrigerators
Beko fridge freezer humming
- Loose flooring or floor not firm.
- Cabinet not level.
- Tubing in contact with cabinet, other tubing or other metal.
- Drip tray vibrating.
- Fan hitting another part or worn fan motor bearings. Unplug the unit and rotate fan manually by your finger.
- Compressor mounting grommets worn or missing; mounting hardware loose or missing.
- Free or loose parts causing or allowing noise during operation
- Check compressor it may contact with tubing or other parts.
- Check the body of your unit is not touching the wall or other object.
Jan 12, 2008 | Haier (492420265334) Refrigerator With Ice...
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
