I hooked up some speakers get humming sound nothing else. mycomputer says no speakers installed. So i cant do anything with the volume. Its not on mute. What can i do? I have a compaq presario desktop.
    President:
  • 4,070 Answers
Hi! The speaker installed may be defective which can cause the speaker to fail. Try putting a different speaker and see how it goes. Hope this helps and thank you for using FIxYa!
Posted on Aug 31, 2010
Benwin 5.1 surround sound system Humming loudly without anything pluged into it!!!
It is sad your having a problem with your
If humming can be heard on all speakers, then it could probably
be on the power supply.
If it is only on the main SUB unit, then it could be the amp itself.
But check for power supply capacitors that supplies voltages to the
amps.Check for amp output DC voltages too.
Oct 04, 2012 | Audio Players & Recorders
Hello. I just purchased these speakers and there is a low static hum in them. Also, if I turn up the bass volume on the subwoofer I get a deep hum and no sound. Any assistance would be greatly...
Double check your wiring again, sounds like something is either not hooked up right or maybe you got faulty speakers. There shouldn't be any hissing or humming in any speakers. Get a flash light and make sure you have it in the right spot on your computer most sound cards have about 5 different jacks you could have simply put it in the wrong jack.
May 15, 2011 | Cyber Acoustics CA-3080 Computer Speakers
My speakers will not play sound . they will turn on , but nothing but a slight hum.. everything is hooked up properly but still nothing.. is there some kind of driver i need to reinstall
i Think your computer sound drivers are not installed properly. Post your computer model number iwill give the link where you can download the drivers for your system.
Nov 16, 2010 | Dell 5650 Computer Speakers
Re: Boston digital BA735. Hum with or without input signal.
Hmmm I just got the same problem. They worked fine on my old Dell desktop but when I plugged them in to my son's old Dell PC (maybe 1 year newer than my old one) they all hum like crazy - as you say even if it's just the power plugged in and nothing else. Yes it does have the original power supply. I get no music (but still it hums) from digital out/in but when I switch to analog out/in I hear the music and it still hums, plus the sound is distorted. Wierd.
Jul 14, 2010 | Boston Acoustics BA735 Computer Speakers
Hi, I have a pair of Polk RT1000i powered towers and one now makes a constant loud humming or buzzing sound. It is not hooked up to the receiver. It does it as soon as its pluged into the wall. Any...
the volume on the speakers are too high. try to put make the speakers the master volume(whatever device you plug in into your speakers make that device's volume go all the way up and then adjust the volume on the speakers to what ever volume you desire.had the same problem with my computer speakers
Jan 16, 2010 | Polk Audio RT1000I Speaker
Speakers are hooked up, cant listen to anything.
ok the first thing u have to check in ur windows xp desktop that the volume icon is diplaying in the bar below the screen .if not than go to controlpanel --> sound and audio devices --> place volume icon in the taskbar check this option and the volume icon will be avaliable on ur desktop.remember this option is only avaliable if the drivers is installed . than u can double click this icon and set the equilizer. if ur sound not installed than u have to install it from the motherboard cd that is provided by the manufacturer. thankx and take care of urself.
Jun 09, 2009 | Foxconn 45CMX socket LGA775 motherboard...
Volume out of speakers nill
I bought two of these in "non working" condidition. All it was is this: There are two plug-in's or shunt's whatever you wanna call them that come pre-installed on my units that were up/down and should have been horizontal in block marked "speaker output".
Both unit's work fine now. Came from factory that way!
Try it and let me know at kyhillbilly@bellsouth.net
Someone
Aug 22, 2008 | KLH KL2400 Tuner
Gemsound power speaker pxa105
First,
Disconnect any input cables from the amp. Turn down the volume controls and disconnect the speakers. Power back on. If you still blow fuses with nothing hooked up, have the amp fixed.
If the fuse holds, shut down and connect the speakers, leaving the volume controls down. Power up and see if your fuse holds. If you have hum, an output transistor is most likely shorted. If you have no noise, SLOWLY turn up the volume controls and listen for the hum. If all is quiet, turn down the volume controls and connect your input cables and turn the volume back up. Noise? check your cables!
Mister Phil
Apr 07, 2008 | NAD C350 2-Channel Amplifier
Volume
follow the below checklist :
Check1 : Is power for speakers on
Check2 : Are speakers connected correctly to laptop (fixcables)
Check3 : nothing on volume control is muted
Check 4 : try to check with other pc or laptop if speakers are working.
If speakers are working with other computer , then all you need to do is instal audio drivers from mother board CD which you get from hardware manufacturer....
If the speaker is not working with other PC
check 5: if all the wires are in good condtion
If yes.. then contact hardware manufacturer
If no.... fix wires correctly ......
Hope this anwwers your problem.... thanks..Robosoft.
Dec 16, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
