Question about Frigidaire Dryers
Squeaking noise frigidaire electric dryer model # gler341as2
  • Frigidaire Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Sep 04, 2010
Frigidaire model# GLER341AS2 humming noise
Hello friend, thanks for your inquiry!
I understand that your Frigidaire dryer, GLER341AS2, is making a humming noise. It could be a possible issue within your belt, motor, or the blower assembly. The manufacture provides to a dryer preventative maintenance kit part number 5304457724 and it costs $45.12 plus tax and shipping. I would also recommend contacting a professional to help avoid any unnecessary purchases. I hope this helps. -Matt
Aug 15, 2014 | Frigidaire Dryers
I have a Frigidaire Dryer model number GLER341AS2. The dryer runs fine, but won't get hot. I pulled the dryer from the wall to see anything obvious. I noticed what I thought at first to be anim
Are you mechanically inclined? You may have several problems. 1st, heating element is most likely burnt out. Then I would check ball and socket assembly that back of drum fits into. Also check felt in front of machine that drum rides on. May need competent service person on this.
Sep 13, 2017 | Frigidaire Electric Dryer
Frigidaire electric dryer (model # LEQ1442ESO) is making a loud noise. It's like a loud humming or vibration. Is it the motor?
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 08, 2011 | Frigidaire FEQ1442ES Electric Dryer
My Frigidaire GLER341AS2 squeals real loud while it is drying. I am not sure what would cause this to happen
heatman101
Apr 22, 2011 | Frigidaire GLER341A Electric Dryer
We have a Frigidaire Dryer Model GLER341as2 that is making a screaming or schreeching noise. The drum does turn though. The drum is not centered. More space at the bottom than at the top in relation to the...
heatman101
Aug 30, 2010 | Dryers
My Frigidaire electric dryer GLER341AS2. The
Does it shut down completely? If it does, and the timer ceases turning, your problem may be a blocked vent pipe or Lint buildup.Your high limit switch is designed to kill power to your heater coils and sometimes the motor in case of overheat.
Mar 09, 2010 | Frigidaire GLER341A Electric Dryer
When Turned on, drum will not spin?
if the motor is running,your belt is the problem.if all you hear is a slight humming noise,you may have a bad motor,or something caught in blower. if the drum turns easily by hand,its probably the belt
Mar 05, 2010 | Frigidaire GLER341A Electric Dryer
Frigidaire Dryer GLER341AS2, tumbles but not heating
I would say your right on track, check your heating coil when you locate it also...just in case.
Good luck,
Hope this helps...
Oct 06, 2009 | Frigidaire FEQ1442ES Electric Dryer
Intermittent Squeaking
You know how when the pads on your car get worn they start that noise? Well the bearing that holds the tub has a metal bracket. When that plastic wears down it begins to makes those noises. If left alone the metal bracket will eventually cuut into that drum bearing like a guillotine. I have pictures. Have the women and small babys leave the room: Click (HERE)
Jul 08, 2009 | Frigidaire GLER341A Electric Dryer
Dryers Logo
559 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
