Here you go!.... works for me!!!!!!!!!!!!!
Anyway press the ( PP button with the GREEN RING around it 3 times and it
unlocks it ) then you have to go into the menu and turn key lock off.
hope this is a help to anyone in the same state.
cheers
pod
Im in the same boat .. any solution yet ????????
According to this forum post, the set uses the sane remote control codes as a Bush set. So if you have a universal remote, try setting it to the Bush remote code set and see if you can get it going.
Try either "0000" or "1234" and see if that helps...accordianman
I'm in the same boat....
Nigel
thanks so much for your help but unfortunatelly it did not work.
