Question about IBM Infoprint 1552 Laser Printer
SOURCE: 202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Posted on Aug 08, 2008
SOURCE: Keep getting an error message
If you can't see any paper stuck inside the printer when you open the rear door or when you remove the toner cartridge, the rear paper flag is either stuck or broken.
The flag is a small piece of plastic which sits at the rear of the fuser and as the paper exits the fuser it pushes the flag down. The easiest way to see this is to remove the rear door then the rear cover (two screws).
If it's broken you'll require a replacement fuser (i don't think you can get the part separtely), but if you have recently installed a maintenance kit, i would contact the supplier and ask for a replacement.
Posted on Apr 20, 2009
SOURCE: Paper jam - can't clear error message
Hello Nj,
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Paper jams are was very common on HP printer model.
Here are few instructions on how to clear the paper jam on
your printer.
How
to Clear a Paper Jam on an HP Inkjet Printer
1.
Disconnect the power cord from the back of the
printer before you begin. With the power disconnected, you will protect
yourself from being shocked. This is an important step when you are fixing any
type of electronic device.
2.
Move your printer so that you'll have access the back
panel. Unhinge the back access panel of the printer.
3.
Look for paper through the opened back panel. Remove
any paper you find jammed.
4.
Close the back access panel. Make sure that it
latches into place and looks the same way it did before you opened it.
5.
Open the front or top access panel. This is the panel
you use to access ink cartridges. If the carriage that holds the ink cartridges
moves, then you forgot to unplug the printer. Go back and do that now. Look for
paper that may be jammed in this area of the printer.
6.
Remove any paper you find jammed here. There will be
resistance from the paper feeder, so pull slowly or the paper will rip and
create a more serious problem.
7.
Close the front access panel. Make sure that it
latches back into place.
8.
Plug the printer in and attempt to print again. If
you can print successfully, you have removed the paper jam.
Hope this helps.
Posted on Aug 08, 2009
SOURCE: Lexmark Optra S 1625 202-paper jam open rear door
well with my experience with my opinion crappy lexmark printers there is a senser on the fuser behind the cover it could be jammed down saying there is paper in the fuser when there isnt try lifting it and then flicking it down a few times to work it loose so it springs back all the time and then re-assemble the printer and try it now. hope that works for you had the same problem at work with another model and that is what was wrong with it. good luck
Posted on Sep 02, 2009
SOURCE: My canon MP620 Paper Jam Pull out the Jam Paper Al
There are pieces of paper stock on the sensor, when the paper jam happened then you pull out the paper did you get the whole page of the paper or have missing pieces? open the paper guide, turn off and on the printer and observe the unusual objects in the roller, this error is caused by objects in the sensor.
Posted on Oct 21, 2009
Mar 18, 2013 | HP Photosmart C4100 series
Mar 13, 2011 | HP Photosmart C5180 All-In-One InkJet...
Nov 22, 2010 | HP J3680 Officejet All In One Printer
Oct 26, 2010 | Dell 948 All-In-One InkJet Printer
Jan 24, 2010 | HP J3680 Officejet All In One Printer
Dec 30, 2009 | HP DeskJet 3745 Printer
Oct 25, 2009 | HP PSC 1610v All-in-One Printer
Aug 06, 2008 | HP Office Equipment & Supplies
Jun 29, 2008 | HP Officejet 5610 All-In-One InkJet...
May 09, 2008 | HP Photosmart 2575 All-In-One InkJet...
1,894 people viewed this question
