Question about Sunbeam JARDEN FoodSaver V3840 Upright Vacuum T000 18001 T000 18001
We just bought a Foodsaver v3840 and the vacuum pump only sucks out part of the air. I was vacuuming wet ingredients on the wet cycle with folded up paper towel inside as prescribed by the manual and making sure I left at least 3 inches at the top as directed in the manual. I think that the pump is plugged by liquid or debris as the catcher has little to no liquid in it. How can I clear whatever debris or liquid there is that is obstructing the pump?
2 Suggested Answers
SOURCE: FoodSaver v3825 (I believe it's
Mine did that when I interrupted the cycle. I plugged it in and let the motor fully open the sealing chamber then I was able to pivot open the machine.
Posted on Oct 30, 2011
Door to my foodsaver is stuck on one side. It's shut. How can I release it? Is there a release button anywhere?
Trouble with Food Saver Brand - Survival Podcast
thesurvivalpodcast.com > ... > Food Preps > Processing Food For Storage
Aug 15, 2010 - 17 posts - ‎13 authors
We have been using our Food Saver Vacuum sealer we bought ... connects somehow got stuck open and therefore the bags would not ..... I've had the FoodSaver V3840 for about 10 months now and thus far it has been great.Missing: door
FoodSaver Repair - YouTube
? 8:22
https://www.youtube.com/watch?v=jguFiF0Rouw
May 21, 2014 - Uploaded by Kelly Kimble
Repair a FoodSaver that isn't drawing out air anymore. In this case, its ... Vacuum Sealer Troubleshooting - Duration: 10:25. katzcradul 52,345 views. 10:25 ... How to Food Saver Lemon Juice or Other Liquids - Duration: 4:56.
[PDF]Use and Care Manual - Home Depot
Jan 25, 2016 | FoodSaver Vacuum Food Sealer - V3840
Seals but won't draw all the air out. Seals fine
That could be a bad foam seal not completing suction, A piece of debris that got sucked into vacuum line and or in pump, or in some cases a crack in a elbow or pump housing.
Jan 22, 2016 | FoodSaver Vacuum Sealer Kit V3460
Foodsaver V3460 vacuum runs and sounds like it has reached the end of the cycle then seals bag.
then you do not have the bag in proper place in the sealer , mine has never failed .
Aug 05, 2015 | FoodSaver V3460 Vertical Vacuum Sealer,...
Foodsaver V3840 Won't vacuum air out and wont go to seal. A label states the seals are not removable. Do you know how to fix?
you are not using a "good" bag. Make sure there are no holes and that the bottom and sides of the bag are properly sealed. It will run all day and not pull the air out if the seal is broken anywhere.
Sep 11, 2014 | FoodSaver V3840 Vacuum Packaging System
V3420 foodsaver will not suck out the air
Is the motor still running?
If so it sounds like a blocked pipe
Aug 09, 2014 | FoodSaver V3420 Smart Seal Vacuum Sealer...
V3840 Food Saver won't vacumn
Hi valkenwil798
Go to the following webpage for parts to repair the vacuum part of the sealer
Please take time to rate me
Bud
http://www.foodsaver.com/parts.aspx?cid=0
Sep 30, 2012 | Tilia FoodSaver V2240
My food saver won't vacuum. It worked beautifully last salmon season but now it makes a lot of noise but barely sucks.
Does it have the black rubber gaskets like my V845 Foodsaver? If so, make sure that you wet down the black rubber gaskets like with a wet paper towel before each sealing, and of course make sure the edge of the cut bag is between the two black rubber gaskets. Hope this helps you.
Sep 05, 2010 | Tilia FoodSaver V2240
FoodSaver v3825 (I believe it's the same as the v3840) will not pivot open so I can clean the drip tray - the release buttons are releasing, but it is hung up on something.
Sep 05, 2010 | Sunbeam JARDEN FoodSaver V3840 Upright...
Not sucking air out
Either the seal to the vacuum foot is not being made due to folds or improper placement, or more likely the filter for the vacuum has gotten plugged. Check out the path to the pump.
Sep 09, 2009 | Tilia FoodSaver V2240
Sunbeam JARDEN FoodSaver V3840 Upright Vacuum T000 18001 T000 18001 Logo
168 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
