Question about Ovens
Hello my power has completely failed on my microwave. It is really 2 years old. We check the fuses and everything looks good please help us out. It is a frigidaire f m v 158 f m b. You have any professional suggestions for us? Ok for chili we do not have the funds to the able to get a repair by somebody at the house. So i want to do whatever it takes to repair my problem At the least possible cost. My email address is as follows. Chris.Tesche@Gmail.com. you can reach me at 856-481-4812
  • 17,130 Answers
We are fixya try to solve problems only on line. I can guide you and give some suggestions.
If the fuse is OK then if there must be three things you can check up.
Put in a glass of water, set the time to about 3 minutes and switch ON in low power .
Now take care when touching the circuits as there can be high voltage and it is not recomended for a novice to do this work as in the presence of microwave there is danger of burning or skin damage.
Check the Magnetron and the capacitor along the circuit. make sure the transformer is connected and the inline fuse is OK.
make sure that the limit switch of the door is correct. If not open and close for the switch to latch on so that the ccircuit completes for switching the microwave.
Next finally check on the TOC- temperature cut offf contact- a small round component on the side of the cabin.
Check this and comment. Dont forget to rate my advice.
Posted on Aug 31, 2010
My oven is about 10-15 years old and I cannot reset the clock after the power has been disconnected.
Hello. I need the model number to help you accurately and provide part numbers for your particular unit. Was the power turned off by you or was it a power outage(caused by lightning, construction, etc). If the power went out due to an outage, the main board might very well have been damaged. Power interruptions are notorious for blowing out or damaging circuit boards in ovens, microwaves, dishwashers, washers, dryers...the list is almost endless. Normally, the power going out doesn't do the damage--it's the restoring of the power(and the accompanying current surge) that is the culprit. If a board has been damaged by a current surge, if it wasn't knocked out completely immediately, 3-4 weeks after the event is the usual time when symptoms start appearing--caused by weakened electronic chips on the circuit boards starting to fail.
Sep 18, 2015 | Fisher and Paykel Ovens
Kitchen aid microwave door error
Try unplugging it to reset. Also, check your circuit breaker...as an additional check point. This will shut power to the outlet as well as the microwave completely.
Mar 05, 2014 | Ovens
Oven door glass shattered
What was the weather outside?
Feb 03, 2014 | Miele Ovens
Wall microwave worth fixing?
There's micro switches and fuses worth fixing on microwaves... if its doing nothing its most likely the fuse on control board. maybe even the breaker.
Sep 01, 2012 | Ovens
I have a maytag microwave that just quit. there is power to the outlet but nothing on the microwave works. do you have any suggestions
Hello, there is a fuse on the front display panel. First unplug the Microwave. Remover the screws and and the front panel. On the printed ciruct board will be a fuse rate at 2 amps. If the fuse isn't blown out. The check the HV diode. It about 1 1/2 long, it will screwed down to metal flashing, it has two pronges with two wires plung into it. Take it to a TV repairman/women have them check it. They have electronic equipment to check it. GB...stewbison
Aug 31, 2011 | Maytag Ovens
Our microwave is approx. 9 years old and has started to shut off after 6 seconds. It is a Panasonci Inverter (Lost book) Type S333 (F04114182CP) Is this repairable.
1) power to display- main fuse good
2) no power to magnetron- check all realated thermal switches hidden behind control panel. Remove top grill to find two hidden screws.
May 30, 2011 | Ovens
I have a Whirlpool microwave (wmh1164xvs-2) that runs everything normal but does not heat.
Hello there and thank you for choosing fixya:
normaly when this problem occurs there may be 2 problems that need to be looked at
the first one is the mengatron this is the part that converts the electrical power produced to thermal power when these go bad it will not let the machine warm up and some times it can produce a error code (but not always ) Should look like this pict below
And next is the power inverter (capacitor) this is part of the electrical system that converst the electrical power to the usable power the microwave needs to operate correctly
So check these out first and then if needed i can assist you in checking out more parts ok?
Best regards Michael
Feb 27, 2011 | Whirlpool Ovens
I have sanyo microwave oven purchased in 1996 in dubai was fully functional untill few weeks back it has not been serviced for long time ,i am looking for advice on service or replacement
Usually when a microwave quits either the Power Diode or High Voltage Capacitor has failed. When they fail they usually also cause the internal 15 Amp fuse to fail. The back comes off by removing the 4 screws (2 on each side) and 6 screws in the back. (UNPLUGGED!) The you slide the cabinet cover back about 1/2 inch.. lift the rear of the cover 30 deg and remove the cover by pulling to the rear of the unit.
Once inside take a bladed screwdriver and short across the capacitor at least 3 times just in case it was not the failure. If you don't do this and the Cap is good it can really ruin your day! Then isolate the Cap by removing the set of terminal connections that include the power diode connection. Use an analog meter on R x 10K and probe the cap terminals. You should see resistance then watch the resistance increase to infinity. Reverse the leads and watch for the same indication....resistance then increase to infinity. It should do this each time you reverse the leads. To check the diode you read both ways with the meter leads across the diode. One way will read ZERO ohms and the other way should read close to infinity. (You have to reverse the leads.) Like I said usually the Cap or the diode fails. Make sure you check the fuse for continuity also. Most of the time they fail when one of the 2 components above fail. DO NOT replace the fuse until you replace the failed part. Otherwise the fuse will fail again.
The fuse is located in the fuse block at the end of the power cord.
When your reinstall the cover make sure you ensure the front side locking tabs near the bottom front are engaged with the front of the internal chassis.
If you need product specific parts replacement information we will need your exact model number. I will tell you that if you find the problem via the steps above you can walk into any LOCAL Appliance Parts source store and they will have the part you need in stock.
Thanks for choosing FixYa.
Kelly
Sep 13, 2010 | Ovens
GE. Microweave Oven, Model JVM 1090
If your microwave won't start and the display is blank and unresponsive, the issue may be with the ceramic fuse. This part protects other microwave components from power fluctuations, and causes a complete loss of power when it fails, meaning your microwave won't work. To access the ceramic fuse, located inside the cabinet near the power cord, first unplug your microwave. Use a multi-meter to test the continuity of the fuse. They look like this:
If the oven will not power up, but you are getting some display lights ... then it could be a thermal fuse in the back or a faulty door switch.
Helpful?
Good luck on your troubleshooting!
Mar 04, 2018 | Ovens
Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Dec 06, 2007 | Whirlpool RBD245PRS Stainless Steel Oven
Ovens Logo
56 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
