Question about Philips J44414
Philips pc camerea
Had it working for a moment get .vxd error and vidcap
I know
Posted on Jun 01, 2008
I loaded Check-it Fastmove on a laptop running windows XP. It will not start up and gives the following message: Could not start communication service. It worked fine on my old Desktop running windows XP.
I struggled with this same problem a few years back. I tried a couple of different compatibility modes for the fastmove.exe file and finally settled on Windows 98/Windows ME mode. When you right click on fastmove.exe and enable this mode in properties, you still aren't all the way there. When you try to run fastmove in this mode you will get another error message. Something about how it could not find a file called paralnk.vxd (actually the error message mispells the file name as paralink.vxd).
Well this file is only necessary for parallel port connections which I don't think anyone uses anymore (everyone should be using USB to sync). So I got to thinking that all the Fastmove program needed to see was a dummy file called "paralnk.vxd." And I was right. So this is what you need to do.
1. Find "fastmove.exe" in your program files, right click on it, click on properties, go to compatibility tab, enable "Windows 98/Windows ME" compatibility mode.
2. Go to your Windows\system32 folder and right click on some empty space. A dialogue box comes up. Mouse over "New" then click on "Text Document." After you have created the new text document, rename it to "paralink.vxd." You will get a warning message about changing the filetype from txt to vxd, but ignore it.
It doesn't matter that the new paralink.vxd is just a dummy text file. Fastmove doesnt use the file for anything. It just wants to see that it is there.
And that is how you get fastmove working on XP. It also works in Vista.
I sure wish they would update this program, but it got discontinued. Best sync program I ever used. I wish I knew who the actually developer was. I would contact them and see if they wanted to update it on an open source project.
Sep 19, 2010 | Smith Micro CheckIt FastMove...
.VXD errors
I myself am not familiar with them at all however I have a link that goes through everything you need to know briefly and easy on the eyes I hope it helps
http://ask-leo.com/what_can_i_do_about_vxd_errors.html
Please leave feedback
thanx
Robb
Apr 03, 2010 | Compaq Presario 5440 (152507-004) PC...
I Unable to access my Laptop please help me out.
hi,
do not choose safe mode,instead choose the start normal, If still you can not load and error exist, there might be missing of your files or your files are corrupted..Format your computer and back your important files then install new (OS) Operating System.I hope this may help you.
best regards,
kaybicks
Feb 27, 2010 | Toshiba Portege 320CT Notebook
Funcam connected to pc seeing olnly black image. Mode button not
Try to change the settings in the menu. There are different modes like sepia, ...
Thankyou
Appreciate a good rating from you..
Jul 31, 2009 | Philips FunCam DMVC300K/00 Digital Camera
My bison built in web cam says error 80040275: cannot and vidcap
I GET THE SAME **** ON THE SUYIN WEBCAMS IM TRYIN TO FIX MY CAM AS WELL
Jul 30, 2009 | Labtec 961307-0914 Webcam
Camera wont load
diconect your camera from the computer and try reloading the driver software, then re-attach the camera and make sure that the program your trying to use is configured to recognize the device for what it is, actually as with programs like paintshop pro make sure your using the correct command as there are a couple of similar commands only one of which really is the one you want while the other will comeback with unable to find the device or words to that effect
Apr 12, 2009 | Philips J44414
When I insert a cd in my player I get this error oe 0028:c182b573
Method ONE Disable the SCSI1HLP.VxD using the Microsoft Configuration Utility:
  1. Restart your computer, press and hold down the CTRL key while Windows is starting, and then choose Safe Mode from the Startup menu.
  2. Click Start, click Run, and then type msconfig in the Open box.
  3. On the Static VxDs tab, click to clear the Scsi1hlp.vxd check box, click OK, and then follow the instructions to restart your computer.
Method Two loadTOCNode(2, 'resolution'); NOTE: By following the steps below, any device that uses the Scsi1hlp.vxd file may not function properly or you may not be able to restart your computer. Some SCSI devices and some ATAPI devices use this file. If you are not sure if your hardware uses this file, check with your hardware manufacturer before you proceed.
Rename the Scsi1hlp.vxd file in the Windows\System\Iosubsys folder:
  1. Restart your computer, press and hold down the CTRL key, and then choose Safe Mode from the Startup menu.
  2. Click Start, point to Find, and then click Files or Folders.
  3. In the Named box, type scsi1hlp.vxd, and then click Find Now.
  4. In the list of found files, right-click the Scsi1hlp.vxd file that is located in the Windows\System\Iosubsys folder, and then click Rename.
  5. Type scsi1hlp.old, press ENTER, and then restart your computer.
Apr 04, 2009 | Microsoft Windows 98 for PC
The following file is missing or corrupted; C:\WINDOWS\SYSTEM\VMM32.VXD type the name of the windows loader (e. g., C:\WINDOWS\SYSTEM\VMM32.VXD)
That is a special file, created during Windows installation. Every computer uses a different VMM32.VXD file, so you can't simply copy one from another system and expect it to work.
If you can't find that file by searching the system in DOS, you could wipe the drive and reinstall Windows again, or do a repair install, installing Windows on top of itself. That should force the creation of a new VMM32.VXD file, and that problem should be history.
If you DO find the file somewhere on the HDD through a DOS search, copy it into the Windows\System folder, then reboot the system.
Jul 23, 2008 | Computers & Internet
Toshiba equium 6200m computer
Those files are related to your network card. You must be running windows 95, 98 or ME.
Reinstall your network drivers and that should take care of the issue.
Jun 16, 2008 | Toshiba Equium 6200M (PV1026U-01A) PC...
I put blank disc in record side a messege no disc or oop error
go to driverguide.com for your driver for this camerea.
Sergio
May 03, 2008 | Philips J44414
Philips J44414 Logo
20 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
