SETTING THE TIMER
Unable to set timer
  • Anonymous Sep 14, 2008
    Timer Setting worked fine before we added cable TV.  Now channel numbers don't appear on timer set up screen.  Solution?
    Sony SLV-N700 VCR  Before we added cable tv, timer programming worked, but now no channel numbers appear on Timer Set/ Check screen.  Solution?
  • 520 Answers
On most vcrs you must set the clock before you can set the timer.
Posted on May 13, 2008
How do you set a hager eh010 timer
switch the timer off or disconnect
turn the thermostat setting to low
that way it will not work when the solar section is producing enough hot water and when the temperature in the hot water system falls below the thermostat setting it will switch on the power
usable hot water temperature is around 60 degrees c and anything over that will scald the skin within minutes
low thermostat setting is 55 -65 degrees c
Aug 06, 2016 | Solar Hardware & Accessories
How do I set the clock? The included instructions for setting the clock do not work. I can set all the programmed on & off times, days of week, etc., everything except the friggin' clock. The cl
Give us the model number so we can see what you're talking about. Tell us what link you have tried, and how the instructions seem to be different.
Display showing no-op is sometimes associated with defective timer, bad battery. Resetting timer will clear memories and restore functionality in some cases.
http://waterheatertimer.org/How-to-troubleshoot-timers.html#digital
Attach photo of timer, or description of timer.
Add if this is new timer or if timer worked before, and what load the timer controls
Do you have correct instructions for timer ?... scan the manual into .pdf format. and then post the .pdf manual on your website .... then post link here to assist other folks with same problem.
Gene
Water Heater Timers Save Money
Dec 11, 2014 | Hardware & Accessories
I have an old "Intermatic Time-All." I no longer
Most time-all timers have two different trippers on dial.
Push down and rotate tripper to desired ON time and OFF time.
Then manually rotate dial until current time lines up with a mark or arrowhead.
To replace timer with new one:
Buy TN311c with 3 sets of on-off trippers that push onto dial, and 3-prong outlet.
http://www.amazon.com/Intermatic-TN311C-Heavy-Grounded-Timer/dp/B00002N5FO
Buy TN111c with 2 sets of on-off trippers, and 2-prong outlet
http://www.amazon.com/Intermatic-Appliance-Security-TN111C70-Settings/dp/B00002N5FI/ref=pd_cp_hi_3
Aug 09, 2011 | Solar Intermaticlamp & Appliance Timer...
I lost instructions on setting the timer.
I Googled in Diehl digital timer and located a website that had the exact timer I have. Included in the list of information was a manual with instructions on setting the timer. I downloaded the instructions and set the timer. Exactly what I needed.
Jan 17, 2010 | Solar Digital Electronic Timer 20/40/60...
Don't know how to turn off the alarm. Bought this used (made in 1995) so there were no books with it. It comes on every day at 2. The system is on 'standby' all the time. I just don't seem to find the...
Setting the ON time (Example: AM 10:15).
1. Press the TIMER button on the Unit for more than
two seconds.
The Timer indicator lights up and the hour digit of the
current ON time blinks on the display.
• When the clock is not set, “CLOCK” and “ADJUST”
appear alternately on the display. Set the clock first.
Press the ¢ or 4 button on the Unit to set the
hour you want the Unit to come on.
Pressing the ¢ button moves the time forwards and
pressing the 4 button moves it backwards. Hold
down the button to move the time rapidly.
2. Press the TIMER button.
The minute digits of the ON time blink on the display.
Set the minute you want the Unit to come on, using
the ¢ or 4 button.
2 Setting the OFF time (Example: PM 1:30).
1. Press the TIMER button.
The hour digit of the OFF time blinks on the display.
(The same time as the ON time will be automatically
set.)
Set the hour you want the Unit to be turned off, using
the ¢ or 4 button.
The minute digits of the OFF time blink on the display
Set the minute you want the Unit to be turned off, using
the ¢ and 4 buttons.
3 Selecting the music source.
The “TUNER” or “CD” blinks on the display.
2. Press the ¢ or 4 button to select the music
source you want to listen to.
The display changes as shown below.
TUNERôCDô(back to the beginning)
4 Setting the volume level.
The current volume setting blinks on the display.
2. Press the ¢ or 4 button to select the volume level.
-- :The current volume level will be used.
0 to 50 :When the timer is turned on, the Volume
will be automatically set to the selected
level.
5 Press the TIMER button.
The timer setting is completed and the display returns to
the display before you set the Timer. The Timer indicator
remains lit.
6 Before turning off the System, prepare
the music source selected in step 3.
TUNER: Tune in to the desired station.
CD: Insert a CD. (Playback will start from the first
track at Timer on.)
7 Press the % button to turn off the System.
In standby mode, you can see the Timer indicator ( )
on the display.
• When the timer turns on, the Timer indicator starts
blinking and the prepared source in step 6 will be
played.
To cancel the timer, press the TIMER button. The
Timer indicator ( ) goes out on the display.
To re-activate the cancelled timer, press the TIMER
button to light the Timer indicator ( ).
At this time, you can see the current timer settings. Each
setting appears on the display for two seconds in the order
of ON time, OFF time, music source and volume.
To change the timer setting, repeat the setting procedure
from the beginning.
Oct 31, 2009 | JVC KD-G210 CD Player
I have an MTD8 timer, that fits into my main electrical board
MTD8 Timer - Instruction manual
1. This timer has a total of 8 ON / OFF programs.
2. MANUAL ON / AUTO / MANUAL OFF for easy setting.
3. Switchable 12 / 24 hour mode.
4. 16 timer combinations are available as follows:
Monday
Tuesday
Wednesday
Thursday
Friday
Saturday
Sunday
Mo, Tu, We, Th, Fr, Sa, Su
Mo, Tu, We, Th, Fr
Mo, We, Fr, Su
Mo, We, Fr
Tu, Th, Sa
Mo, Tu, We
Th, Fr, Sa
Sa, Su
Initial operation:
1. When the timer is first connected to mains power, it will take up to 12 hours to charge the internal battery.
2. The settings can be defaulted by depressing the R (reset) button.
Setting Current Time.
1. Press the C+ (clock) button and hold, then simultaneously press the W+ (week) button until the actual day is displayed. Continue by pressing the H+ (hour) or M+ (minute) button until the current hour or minute is displayed. When setting, the W+, H+ and M+ buttons can be held down for rapid forward counting.
2. Release both buttons. The weekday and time will be set according to your selections.
3. To set incorrect time (etc.) repeat the settings.
Settings for programs:
1. Press the Timer button (Clock) and release. The first ON setting can now be made.
2. Press the W+ button to set the day or blocks of days. Select the ON time by pressing the H+ button and then the M+ button.
3. Press the Timer button (clock symbol) again to finish the first ON setting and enter into the first OFF setting. Repeat step 2 to set the first OFF setting.
4. Press the Timer button again to finish the first OFF setting and enter into the second ON setting. Repeat steps 2 and 3 to program the remaining settings.
When setting block dates, the ON and OFF times apply to all dates in the block.
I.E. Selecting block Mo, Tu, We, Th, Fr, Sa, Su and setting ON to 10:00 and OFF to 16:00 means that the selected times automatically apply to all the indicated days in that block.
Specifications: 230Vac 50 or 60Hz. 16A Inductive load. 20A Resistive load.
Battery backup >100 hours. Accuracy: +/- 1 minute per month. Temp: -10 to +40 deg C.
Apr 18, 2009 | Hardware & Accessories
Setting the clock on my coffee maker
After turning the coffee maker on press and hold down the timer button until flashing; then press the hour and minute buttons to set the clock.
Dec 19, 2008 | Cook's Essentials Cooks Essentials Arome...
Setting of clock
You need to examine the timer settings. Perhaps you could turn off the power to the oven for a few minutes - this might reset the timer.
Jun 30, 2008 | Cannon 10476G Dual Fuel (Electric and Gas)...
Unable to control the maching
Are you sure that this is a timer issue because my research does not list this unit with a timer. It does have a humidistat which could give the operation that you describe depending on where the humidity level is set. You should be able to go to the menu and select the mode that the unit is in. If it is set to run until a certain moisture level is reached it sounds as though your unit is probably working the way it is supposed to. Generally that is the mode that most people would want. If you want it to remove more moisture readjust this setting to a lower percentage. Your operation manual should explain the procedure. Good luck.
Jun 21, 2006 | Danby DDR600R Silhouette Dehumidifier
Televison & Video Logo
248 people viewed this question
Top Televison & Video Experts
