Question about Canon PC-940 Black and White Copier
What makes corner of paper crumple - Canon PC-940 Black and White Copier
  • Canon Master
  • 3,866 Answers
You might have something in the paper path , or a part came simi unloose inside.
1. check paper path for debris (may have to open the unit up)
2. Check for simi loose parts as well.
Thanks for using fixya please do rate befor you leave, Thanks
Posted on Aug 31, 2010
Second copy is crumpled
You need to isolated a problem.Verify the vertical conveyance feed and clean the feed rollers,verify the fusing unit and a duplex unit,and verify the exit unit.Stop the copy process before the paper enter in the fusing unit,and verify if the paper is crumpled or not.If is crumpled verify the paper tray rollers(casette feed rollers,vertical transport rollers).If not crumpled stop the proces after a half copy is out on the fusing unit.If crumpled change or clean the upper and lower fuser roller and the lower roller cleaning roller(aluminium roller)in the fusing unit.
Dec 14, 2013 | Ricoh Aficio 2015 Black Toner Cartridge...
Crumpled paper
A bit more information is need ie model number and a description of where the paper us crumpling most crumpling problem are due to a foreign object like a paper clip stuck in the paper path
Nov 02, 2013 | Kyocera Office Equipment & Supplies
Printer Jammed
If you unplug the machine when the printhead is out of the corner, you can shine a light in and see where the crumpled paper is, usually on the right side where the cleaning assembly is.
Aug 12, 2009 | Brother MFC-5840CN All-In-One InkJet...
HP LaserJet 1300 crumples paper on top left corner
simple, the printer needs servicing as the gears which forwards the paper out from the left side r getting blocked somewhere.and the gears needs to be cleaned.
Nov 14, 2008 | HP Office Equipment & Supplies
Hp laserjet 4650 crumples leading edge of paper
When you open the paper tray assembly you will see that on each side there is a silver bracket on each end of the paper tray that the paper sit under. You can bend these away from the paper in a sidways just a little and that will fix your problem. The paper is hanging on these plates as it feeds and is bending the paper as it feeds.
Oct 01, 2008 | HP LaserJet 4650 Color Printer
Paper jam at fuser unit section
answered here :
http://www.fixya.com/support/t636850-paper_jams_fusion_stage
also, if the paper stuck in FU is straight not crumpled and will come out easily then make sure that the 2 knobs located at top of the FU are in right position.
Jun 22, 2008 | Konica Minolta magicolor 2400 Laser...
Crumpled paper comes out of copy machine
Firstly make sure that in the cassette the paper tray guides are fully against the paper as if they are not the paper will wiggle through the machine and cause your fault. If this doesn't work then check the paper path as there maybe a small piece of paper causing it to shift and turn causing the crumple. Also check the fuser and the little plastic stripper fins as they may have dried toner on them causing the fault.
Hope this helps you
Thanks J
Jan 08, 2008 | Office Equipment & Supplies
My copier makes a noisy sound
Check the crumpled paper. If it has an image, it has reached the drum and is crumpling at the fuser unit (part that gets hot). If that is the case the fuser gear and drive gear need to be replaced.
May 01, 2007 | Sharp AL 1215 Black and White Copier
Canon PC-940 Black and White Copier Logo
old marine
old marine
