Question about Carrier Heating & Cooling
I replaced my whole heat pump system 3 years ago with a Carrier Puron unit. The installer called me this week and told me that I needed to replace the puron after the third year at a approx cost of $275-$300. Is this needed??????
  • 490 Answers
Howdy. I have been reading for about 20 minutes about Puron systems and cannot find any info to support that statement. If there is more to the situation, like a leak or some issue with that particular model, then possibly. I would recommend asking at least 2 other contractors in your area if that replacement is really necessary (and how much it should cost) before shelling out the big bucks.
Hope this helps some:)
regards,
farmerbear
Posted on Aug 31, 2010
  • 4,059 Answers
Tell him you already had it done. lol. Unless you misunderstood what he told you no! You don't need to replace the Refrigerant weather it's Puron or Freon. It doesn't wear out. Ever. If your system develops a leak and you loose the Refrigerant it will have to be replaced but you will know you lost it because the system won't cool and heat like it's supposed to. I would report the installer to the better business bureau.
I have a Carrier Weathermaker model #38tdb060300 A/C system. How many tons is that? It is 11 yrs old, capacitor exploded and compressor is blown. Needing to replace.
Looks like a 5 ton unit. However, you might be better off finding a R-22 condensing unit to replace the entire outside unit. Reason being, if you just replace the compressor, you get a one year warranty. If you replace the whole outside unit, you get a 5 year warranty. You can replace the outside unit with any manufacturer, as long as it is the same tonnage and type (heat pump/air conditioner/single stage/ 2 stage ...).
Oct 13, 2014 | Heating & Cooling
24ABA342A30010 NEED TO KNOWHOW MANY B T U'S THIS UNIT HAS
The only important part is before the last A. It gets broken into two parts, xxABA, and *** (where x is any number)
24ABA:
24A = A/C (24H would be heat pump)
B= Base series, C would be Comfort, P would be Performance and N would be Infinity. (B, C, P, N in that order gives you more bells and whistles)
3rd letter = A (puron) or B (R22).
342:
First number = SEER 3 = 13, 6 = 16, 1 = 21.
42 = btu in thousands (18-60)
This means that your unit is a 13 SEER, 42,000 BTU base-model Air Conditioner which uses Puron (R410 refrigerant).
Aug 22, 2011 | Carrier Heating & Cooling
I have Carrier Heat pump model # 25HBA. It was installed 3 years ago. I have had problems with it several times. This time, it is freezing up on the outside unit. My electric bills have sky rocketed. What...
The cooling coils are freezing because the gas (coolant) in the system may need replenishing or a small leak in the system. Something you can check yourself, is whether or not the foam insulation on the refrigerant tubing coming out of the unit is still intact. If not, that tubing is probably freezing too.
The other possibilities will need to be check by a qualified service technician.
Feb 10, 2011 | Carrier Heating & Cooling
I have 4 ton carrier heat pump / puron. It is a new system been installed about 3 months. Live near Dallas Texas and lately the temp has dropped into the low 40's at night. The heat seems too be working...
The water is from humidity in the outdoor air which has condensed and then frozen to your heat pump outdoor coil. The heat pump will defrost occassionally, depending on how much frost has accumulated to the coil and will then generally drip off the unit and onto the ground. This is normal. To keep the water off the drive way may mean having to move the heat pump to a place where the condensation can run away from the drive area. Or provide some other means of redirecting the water.
Nov 20, 2010 | Heating & Cooling
AC will not cool. How much should a service charge cost?
If the upstairs is working and the down stairs is not,You only need to have one unit checked,Don't assume it just needs puron(If it does,You have a leak,which cost more to locate and repair than some other likely causes)This is not something you can do yourself and is illegal if you are not EPA certified.to get a fair price would depend on your geographic location and the best way would be to call around to some local heating and air companies and ask how much a service call is.(That only tells you the price for them to came and see what the problem is,They will not be able to quote a price until they know what must be done to make the repairs.
I hope this has answered all your questions.
Please take time to rate this fixya
May 16, 2009 | Carrier 38CKC036 Air Conditioner
Carrier Infiniti system, system maufunction on primary display
Call a Carrier service comapny and have them investigate further, when system malfunction comes up on the user interface usually there is a substantial problem.
Either that or the User Interface has gone bad and needs to be replaced
May 14, 2009 | Carrier Heating & Cooling
Odor coming from heater vents
Freon should not be leaking from unit at all. I would not pay for freon that has leaked out due to a poor installation. Maybe the technician who installed this unit needs to rethink his choice of jobs. I would contact the owner of this company who installed it and if you get no positive response then find a new a/c company. I have installed about 40-50 of these units and check each one of them for leaks prior to filling the system. Shame on them for not taking pride in their work. Good luck.
Apr 25, 2009 | Heating & Cooling
Carrier indoor coil replacement
yup, entire system needs to be drained, and leak needs to be repaired first before charging with freon.
after sealing the leak and test it is ok, evacuate the system for about 30 mins before charging it.
you may need a qualified tech to do that because you can not buy freon now a days.
you need to weld the leak also. you will need portable torch to weld copper pipes.
you will need vacuum pump to evacuate the system before charging with freon 22.
tnx 4 using fixya,
drcool
Sep 18, 2008 | Carrier Heating & Cooling
I have a carrier Puron unit that is six years old. We had to replace the compresor on the third year, and now it is three years later and the second unit has failed.
I have seen this before when there is an obstruction in the evaporator coil metering device. This causes the compressor to struggle moving the Puron. After the Puron has been recovered make sure that they do a complete check of the metering device and check for other obstructions. When they are done checking they must do a proper vacuum to remove any non condensables like water condensation. Finally they should have installed both a liquid and suction filter dryer to reduce any dirt and stuff. The only other options are unlikely, as we will assume that the last company installed the correct (new) compressor and that they did not do a hack job.
On a happier note, the compressor should still be under the 10 year parts warranty!
Jul 01, 2008 | Carrier Heating & Cooling
Carrier evaporator coil
I recently contacted Carrier Corp after our routine annual HVAC check on our residential system indicated that our 4 ton AC unit and 3 ton unit had leaking evaporator coils.
They basically told me to shove it in a very curt letter - In other words even though a leaking evaporator coil is a manufacturing defect they will not offer any financial assistance in replacing the failed evaporator coils.
I spoke to several HVAC engineers and they indicated Carrier has a high percentage of evaporator coils and compressor failures on residental HVAC systems.
The copper wall of the evaporator coil is being drawn thinner than in earlier years and the R22 being acidic slowly eats through the copper tubing.
Evaporator coils should not fail according to the HVAC Engineers if properly manufactured.
The Bear
May 19, 2008 | Heating & Cooling
Heating & Cooling Logo
215 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
