Question about Weslo Cadence CT 4.8 Treadmill
Weslo cadence 70e - nothing happens when power control is slid to turn on speed/belt. There are 3 lights on the main circuit board that light up when treadmill is turned on and speed control knob is moved but no belt movement or noise at all. What could the problem be? model # is 831.293020
joboo1
  • 257 Answers
SOURCE: How do you adjust the belt for a Weslo Cadence 815 treadmill?
Hi, I don't have a manual on your particular treadmill but most all treadmills use the same type of belt tension and tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
Posted on Mar 14, 2009
  • 13 Answers
SOURCE: I have a weslo cadence dx5 treadmill and i can't
go to:
http://www.iconservice.com/manuals.html
fill out form......search.... view manual in PDF Format
Print
Posted on May 13, 2009
mohtwister
  • 37 Answers
SOURCE: Lost owners manual
try this: http://fitness.owneriq.net/manuals/mfg/weslo/cadence_450_model_no_wltl35520.html
Posted on Jun 02, 2009
SOURCE: given a Weslo Cadence 840 but panel is not providing read out
just got one myself not sure if you have yours question answered already but i will tell you anyway.. on the left hand side of your base read out there is a slide up panel and it takes 3 aa batteries to work the digital readout..
Posted on Aug 17, 2009
SOURCE: can not find my manual for my weslo cadence ts5
try this site and type in model and type...manual will be a PDF booklet
http://www.iconservice.com/CustomerService/manuals.do?dr=WL
Posted on Jan 10, 2010
Weslo cadence 70e doesn't come on , how do you trouble shoot the problem
If you wish to get some details about treadmill repair and service; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jan 02, 2017 | Weslo Exercise & Fitness
Replaced motor and motherboard board through warranty but belt still won't work. Not even the power noise will turn on.
The motor, or a connector to the motor, or the controller is faulty. If you can measure DC voltage at the motor (up to 90VDC), but the motor won't turn, and if you can manually move the treadmill belt with your hand or rotate the motor pulley (POWER OFF) with your hand, then the motor's dead. Even IF it was replaced under warranty.
If you can't measure any DC voltage to the motor under any conditions, then the problem is in the controller or a connector. Try measuring directly at the controller board.
Jul 26, 2014 | Weslo Cadence G 5.9 Treadmill
Weslo Candence 5.9 won't run after being moved
Check for any loose electrical connections between control panel and motor especially any plug together connections. Moving may he have loosened or unplugged one of these connections. Hope this helps.
Dec 29, 2013 | Weslo Cadence G 5.9 Treadmill
My Weslo Cadence 70e treadmill works fine, but the dislay doesn't come on at all.
1) Tight the ribbon cable very well, and tight the connector from display board vs. lower board.
2) Adjust the REED switch, see the diagram attached.
God bless you
Jun 08, 2012 | Exercise & Fitness
Treadmill will not operate when plugged up.
check the outlet first by plunging in a light to make sure their is power and that the house breaker was not tripped. then plug in the power cord next locate the reset/off circuit breaker on the treadmill frame near the power cord. Switch the circuit breaker to the reset position. Then place safety key on console and the display should light up if not then you may have a lower board problem.
May 17, 2010 | Weslo Cadence Ct 5.8 Treadmill
Walking belt slows down to almost a stop when i get on it
I believe under the motor shroud on the circuit board their should be 2 pots 1 adjusts torque 2. adjusts speed try adjusting them and see if that take care of the problem if not. worse case it might be the drive motor.
Feb 27, 2010 | Cadence Weslo 4200 Treadmill Walking Belt
Weslo Cadence 450 Treadmill Manual
When turned on it acts like the walking surface is grabbing.Itgoes and stops its not as bad when speed is increased,but it still feels like it is grabbing.
Mar 22, 2009 | Cadence Exercise & Fitness
Weslo Cadence CT 4.8 Treadmill Logo
441 people viewed this question
Top Weslo Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
