Cisco Transceiver
Problem for Cisco (GLC-LH-SM=) (glclhsmrf) Transceiver
GLC-LH-SM with a Catalyst 2960 switch
By wremes on May 09, 2008
when I put in the transceiver module, and connect it it doesn't show any 'light' and it won't make the connection. distance is 200m+ on a MM 62,5 fiber which works perfectly with the existing 3COM switches & SFP's.
Comments:
May 09, 2008
- thanks !
Same Problem
Aug 28, 2008
-   what other settings are needed for Single Mode to get it light? did no shut, switchport trunk allow all, switchport mode trunk
thanks,
Rich-   rsee215
Best Solution
posted on May 09, 2008
Very Helpful)
Rubec
Rank: Wiz
Rating: 91%, 38 votes
Cisco disables the trans port as default, have you enabled it in the system?
Was this helpful?
Yes
No
Solution #2
posted on Aug 05, 2008
Not Rated)
arcadeforeve
Rank: Guide
Rating: 92%, 3 votes
after doing a no shut on it, if it doesnt light still you may have to play around with negotiation, post if it still doesnt light.
ZXR
Was this helpful?
Yes
No
Popular Solutions for Cisco Transceiver
Questions and Unsolved Problems for Cisco Transceiver
Do you recommend Cisco (GLC-LH-SM=) (glclhsmrf) Transceiver?
Answer
Answer
i have a dlink300 wireless and it keeps dropping out the green bars on task bar are lite up but the... (More)
Answer
Can you fix my chat line back to normal on Facebook.
Answer
were about to design slave clocks wherein it synchronized its time from pc..we used the User... (More)
Answer
how much is the international calling when we use this device?
Answer
The issues are that either the SFP is manufactured too small and is quite loose fitting in the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Cisco Transceiver:
Top Transceiver Experts
Rank: Guru Guru
Solutions: 1349
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Transceiver Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
