Question about GE Profile PGSS5PJXSS Stainless Steel Bottom Freezer French Door Refrigerator
GE Profile PGSS5PJXSS Stainless Steel Bottom Freezer French Door Refrigerator - Bought in 2008. Experienced following problem August 2010. Had same problem in June 2009. Opened door one morning and the unit didn't feel as cold as it normally does. Opened freezer and indeed everything was thawed or on it's way to being thawed. Panel reported temperatures at 0 for freezer and 37 for Refrigerator but obviously that was wrong. Unplugged, waited 15 sec., plugged in. Compressor immediately went on. Checked panel again - reported freezer at 37 and refrigerator at 50. Working fine since problem. This is only the second time that it's happened but want to know if there's a circuit board replacement that might fix this problem - or even a quick fix like unplug monthly, or is it caused by sun spots or some such uncontrollable occurrence. Although only once a year, I hate losing my food.
  • 161 Answers
SOURCE: GE Profile Stainless Steel Top Freezer Refrigerator
Check the compressor.
Unplug for 15-20 min. plug it back in and listen for the compressor to start. You will have to be behind the ref to listen and make sure you hear the compressor start and not just a fan running. If you hear a clicking noise then the compressor relay is bad.
Posted on Dec 17, 2008
  • 999 Answers
SOURCE: Ge Profile Stainless Steel Refrigerator panel replacement
You can replace the doors but you will think you bought a new frig when you see what they cost. Most come as an assembly and are very expensive.
Posted on Jun 29, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GE Profile PFSF5NJW French door Bottom freezer.
If that is what happened after plugging back in still no change in temperature I recommend you call someone you can trust. Trust is about asking too much these days. You refrigerator does not need to run at all until I or someone can find the problem. If someone there would like the challenge and knows how to use a multi-meter let me know. Thanks, Sea Breeze
Posted on Nov 21, 2009
  • 5 Answers
SOURCE: there is a loud knocking noise from inside or the
This is normal. It is the actuators adjusting the temperature between the freezer and the fridge.
Posted on Dec 21, 2009
SOURCE: Express Thaw comes on when refrigerator door is closed
We have a GE Profile side-by-side refrigerator which we purchased in 2002, Model PSS25NGNACC. Today we had a repairman come to investigate why the Express Thaw 3lb. light was on and could not be shut off. If shut off, it came on again when the door was closed and reopened. The repairman called GE and learned that this light was an air filter change indicator which turns on at some interval (2 years, they said, although we don't remember ever seeing this before). The air filter involved is for the interior of the fridge and is not critical. GE said that newer master control boards have this function disabled, since people rarely changed the filter and GE no longer makes them. I have read our user manual cover to cover and find nothing on this filter. I guess we just have to pay the $70 dollars to have someone come and call GE to figure it out. But, enough of that. To reset the indicator, simultaneously press the following keys on the touchpad and hold for 5 seconds until it beeps:
Adjust Freezer Temp (Warmer)
Express Thaw
Adjust Refrigerator Temp (Colder)
Lights and functions should return to normal.
Posted on Mar 10, 2010
Stopped working. lights & electronic touch controls are working. Any suggestions what to check first? Any motor diagrams avail? thanks
first I would call a repair service and see if they give estimates of repair cost . usually when the compressor gives out they do not cool/ freeze .
Oct 21, 2015 | GE Profile PGSS5PJXSS Stainless Steel...
Led light not working in refrigerator
I have the exact same problem. I saw that I can buy a new LED light fixture for about $115 online. I removed my LED fixture and got no DC voltage difference on the wires when the doors were open or closed. This leads me to believe that the main circuit board is the problem. I also saw the main circuit board for about $125. I'd hate to buy the board and it not be the problem. Have you solved this yet?
Nov 15, 2011 | GE Profile PGSS5PJXSS Stainless Steel...
Ge profile refrigerator not cooling
there is a fan that brings the cool air from the freezer to the fridge. make sure thatit is working and that the vents for it are not blocked or frozen
Nov 10, 2011 | GE Profile PGSS5PJXSS Stainless Steel...
GE GFSL6KEXLS Stainless Steel (2585 cu ft) Bottom Freezer French Door Refrigerator Problem: Freezer handle is all stainless steel is loose. How can I tighten it? I looks like I would have to go through...
look for a small hole on one side of the handle. There should be a set screw there you can tighten. (the handle attaches to a ball shaped peg under the handle, and does not attach from the inside of the door)
Nov 28, 2010 | GE GFSL6KEXLS Stainless Steel (2585 cu ft)...
Refrigirator does not cool and bottom freezer works fine.
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,</span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"><br />Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling<br /><br />Refrigerator not Cooling or Fridge not Cooling<br /><a href="" target="_blank"></a><br /><br />How to Defrost Refrigerator Defrost Timer Problem <br /><a href="" target="_blank"></a><br /><br /><br />Water Running in efrigerator from Freezer<br /><a href="" target="_blank"></a><br /><br />heatman101</span><br />
Aug 26, 2010 | GE Profile PGSS5PJXSS Stainless Steel...
Items in refrig are freezing when they're not supposed to.
thermostat has failed i'd say..its not turning off at the requested temp.
Jul 24, 2010 | GE Profile PGSS5PJXSS Stainless Steel...
Moisture build up in the freezer causes the refrigerator to become warm
try cleaning all of the seals around freezer door and all contact points
Jul 21, 2009 | GE Profile PGSS5PJXSS Stainless Steel...
GE Profile PGSS5PJXSS Stainless Steel Bottom Freezer French Door Refrigerator Logo
63 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
