Question about Epson Office Equipment & Supplies
I can't change my black cartridge in my epson dx 4400 what do i wrong because he doesn't stop in the place where i can change the cartridges
  • 480 Answers
HI, You have to be fast in changing the cartridge in Epson printers. The instructions are usually printed in figures. try to follow it carefully.
Cheers!!!
Posted on Aug 31, 2010
When I try to change black cartridge in Epson NX100 the carriage will NOT STOP - flips back and forth. How do I get it to stop so I can remove the cartridge - Black is only one out.
1. Turn on your Epson Stylus NX100 Series printer. Your printer should be plugged in and connected to your computer.
2. Lift open the scanner and prop it up with the support bar. Press the stop button on your printer. The print head will move along the printer and will stop to allow you to change cartridges.
3. Squeeze the tab on the cartridge that needs to be replaced and remove the cartridge by lifting it straight up. Dispose of the used cartridge immediately.
4. Shake your new cartridge several times before removing it from the package. Remove the cartridge from the package without touching the green chip. Take the yellow tape off the bottom of the cartridge. Insert the cartridge into the holder by pressing until you hear it lock into place.
5. Release the support on the scanner and put the scanner back into its original position. Press the stop button to let your printer know that you have changed the cartridge. It may take up to two minutes for your printer to be ready to use. When the "On" light stops flashing and remains on, you may begin to use your printer
NOTE: Beware that you must have all ink cartridges full because Epson uses color even when only printing black and white (lots of comments here about that scam!!)
Sep 05, 2011 | Epson Stylus NX105 All-In-One Printer
My printer epson dx 4400 dont recognise black...
Remove the cartridge and check the contacts after taking it out. Now reset the cartridge back to the holder and remove printer. Now un-install the printer drivers from the PC, then reinstall and connect printer to be detected and installed. If the cartridge is not seen now there are errors in the mother board or the ink cartridge holders.
Feb 07, 2011 | Epson Stylus DX4200 All-In-One InkJet...
Epson stylus sx200 refuses to acknowledge black ink bought direct from epson
I believe the DX series and the SX use the same system
# Determine which ink cartridges are not recognised.
# With the ink cartridge holder in the ink cartridge replacement position, lift up the ink cartridge holder lid and take the cartridge or cartridges out.
# Check that the cartridge is a genuine Epson ink cartridge - look for the EPSON branding and T0xxx codes on the cartridge labels.
# Check that the cartridges are correct for your Epson product.
# Wipe the green Intellidge Chip on the cartridge that is not recognised.
# Check the chip contacts within the ink cartridge holder for any debris or dried ink and wipe with a lint-free cloth if necessary.
# Check that the plastic at the bottom of the cartridge has been pierced.
# Check that the cartridges are in the correct slots.
# Reinstall the cartridges into the ink cartridge holder in the correct order.
# Push the ink cartridge down firmly. It should click into place.
# Repeat this for any ink cartridges that were removed.
# Push the ink cartridge holder lid down. It should clip into place and be secure.
# Press the Stop button, this will return the ink cartridge holder to the right hand side of the unit.
# If the error light flashes after the print head returns to the home position, the ink cartridge may not be installed properly.
# If the red light is no longer displayed, but Status Monitor still reports a Non-Genuine Ink warning.
# If the red light is still on the printer, and Status Monitor indicates that an ink cartridge is not recognised, follow the steps below.
# If the problem remains, there may be a fault with the ink cartridge.
Dec 30, 2010 | Epson Office Equipment & Supplies
My printer epson dx 4400 dont recognise black cartige !!!!!!!
Is it a genuine epson cartridge? Remove and blow dust off and reinsert.
Aug 03, 2010 | Epson Stylus C48 InkJet Printer
I have an Epson Stylus 4400. when I replaced the ink cartridge with a new Tesco cartridge it still registers empty.
Compatibility issues. The epson cartridge has an intellidge chip so the printer's sensor can read the cartridge properly.
Try to take the cartridge out then put it back in to the printer. Let it charge like it normally does.
Use an epson cartridge. Log on to epson.com to get the compatible cartridge for your printer.
Apr 29, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Cartridge holder does not move to
Hi
have you tried pressing it down for 3 seconds? on the printer utility on your computeris there an option to change cartridge? pls check that, if all fails then that's a hardware issue. call epson for replacement.
Hope this help
Dec 20, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Cartridge holder for BJC-4400
I have the cartridge holder you are looking for and wiould be glad to trade you for the black only cartridge holder. PRB4u@bellsouth.net
Jul 18, 2008 | Canon BJC 4400 InkJet Printer
Renew ink
A comprehensive guide to ink cartridge replacement is given in the on-line manual at:
http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
If you need further help, please post a new comment.
Mar 17, 2008 | Epson Stylus C40SX InkJet Printer
60 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
