Question about GE WBSR3140DW Top Load Washer
Machine not spining - GE WBSR3140DW Top Load Washer
  • 2,272 Answers
Check the Motor,the lid switch and the connections. If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. If your washer pumps out the water but doesn't spin, check these:The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. The clutch may be worn.The drive motor may be defective. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other.
The transmission may not be shifting properly. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. You can get required parts fromwww.repairclinic.com
get to the lid switch by removing the front first then removing the top. The lid switch has a quick connect. Unplug that and check for continuity or simply by pass it at that point to see if that washer wakes up.Set the meter on ohms and see if you have continuity between the 2 pins of your lid switch assembly.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 31, 2010
AKITA washing machine does not spining why?
Fan belt may have snapped!
go to there website and see if they have instructions on how to open the front of the machine to get to belt.
Aug 08, 2015 | Washing Machines
Tip
Washer not spining Top Loader Part II
In this tip I will discuss tips towards checking the motor ,transimssion, and timer on Top load model washing machines. Please also see part 1 of washer not spining Top loader for more tips as well.
on Apr 28, 2011 | Washing Machines
Water not spining out
CLOTHES ARE SOAKED BECAUSE YOUR WASHER IS NOT DRAINING THE WATER.....ONCE YOUR MACHINE HAS DRAINED ENOUGH WATER OUT IT SHOULD START SPINNING AGAIN
Apr 16, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
What is the spine corrector barrel?
The spine corrector utilized for individual needs, stretching, aligning and strengthening the spine. It also relieves stiffness of the shoulders and hips as well as relieving common backaches.
Aug 30, 2012 | Allegro Exercise & Fitness
The needle doesn't go up & down. Any suggestions? Thank you
Does the handwheel turn eazy or is it stiff. If it is stiff you need to take the top and bottom off and lubricate all moving parts. may take a bit of turning the handwheel and lubicating(it may tire you out). If the handwheel is not stiff I would check to see iff the motor is spining at all. If motor is not spining may be a bad footcontrol. If it is spining try cleaning the belt pullys and tighting the belt.
hope this helps
Mar 22, 2011 | Kenmore 15516 Mechanical Sewing Machine
The machine is not spining properly and leaving wshing wet
when machine is empty turn on side and check underneath for slipping or broken belt Replace . hope this helps
May 17, 2010 | Washing Machines
Washer not spining burn smell
belt burrt out advise new belt or new machine
Jul 12, 2009 | Maytag LAT3600A Top Load Washer
GE WBSR3140DW Top Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
