Question about HP LaserJet P4015N Printer
Hp p4015n - How do we program the copier for duplexing? (We do not have the automatic duplex attachment).
  • 48 Answers
Without the attachment the printer will not duplex.
Posted on Aug 31, 2010
Testimonial: "tks"
Printing on both sides
Make sure the Automatic Duplexing option is enabled:
Enter Control Panel then Devices and Printers.
Right click the printer icon, then Printer Properties.
Click the Device Settings tab.
Set the Automatic Two-Sided Duplex Accessory as installed and click OK to save.
Now Automatic Duplexing should become available.
My LaserJet 1320 will no longer do duplex printing with Windows 8
Aug 07, 2014 | HP LaserJet 1320 Printer
Hi I hv installed hp laser jet 1320 printer in my system but print on both side option is not shown in printer property
Do you have the 1320D or just a 1320. Only the D version will duplex automatically. The base version requires you to manually duplex. If you are sure you have the duplex version, then check the settings in the print driver and make sure it shows that the duplex option is installed. The driver often defaults to no duplexer.
Jul 05, 2011 | HP LaserJet 1320 Printer
We have a new hp lasterjet 4015n. It will print two sided, but it won't flip up the back side. I have my driver set to duplex print and flip up, but it won't flip up. Is there some setting on the...
I assume that you attached the two-sided printing accessory (duplexer) to your product:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01909142&cc=us&lc=en&dlc=en#N428
The duplexing has to be set in the printer's
Printing submenu
DUPLEX OFF/ON
This item appears only when an optional duplexer is installed. Set
the value to ON to print on both sides (duplex) or OFF to print on
one side (simplex) of a sheet of paper.
The default setting is OFF.
Print on both sides (Duplex) Click Print on both sides. If you will bind the document along
the top edge, click Flip pages up.
User manual:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c01295101/c01295101.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 01, 2011 | HP LaserJet P4015N Printer
After firmware upgrade the HP 4015x will not boot up with the duplex unit installed. Boots up ok without the duplex. We even reapplied the firmware upgrade.
I had the same problem. HP Pro Support advised me to
deinstall the additional paper tray and the toner.
and reapply the firmware update 3 times.
It sounded stupid to me but it worked!!!
Be sure to use usb connection and wait 30 min between progress.
1 st time - no paper tray, toner, wait 30 minutes
2 nd time - no paper tray, wait 30 minutes,
3 rd time - all together now, wait 30 minutes
I hope this will help you and others,
Arthur
Nov 05, 2010 | HP LaserJet P4015N Printer
I want duplex printing for hp 2420
The only way to duplex print on a standard 2420 is to print the first page, then take that page and re-insert it into the paper tray face up. Then print page 2 onto the back of page 1. If you want to automatically duplex print then you need a 2420DN printer which has the duplexing paper path as well as the formatter board with the duplex firmware.
Good Luck and Thank You for using Fixya.
Sep 23, 2010 | HP LaserJet 2420 Printer
Duplex printing availeble in HP laserjet 2015n?
HP 2015n is not able to print duplex (both sides). HP printers, which have duplex print have "d" after the product name/number - like HP2015dn, 2055dn.
Aug 20, 2010 | HP LaserJet P2015n Printer
My HP 4700 printer suddenly can not print on both sides, yet it used to print on both sides. I can't see the option for duplex on its printing menu. Pls help
You can enable duplex printing from your computer, if it somehow got turned off. Open the printer program, and under Configuration Settings, click Duplex Mode, then click Enable Duplex Mode and then Apply.
At the printer, you can find the Duplex options by clicking Menu and scrolling down till you see Configure Device. Duplex is in that menu.
Aug 06, 2010 | HP LaserJet color laser printer
How do you print duplex on a HP Laser Jet 4650n
You have to print the first side then take those prints and put them back into the paper tray to print the second side (Manual Duplex). If this were a DN model it would have built in automatic duplexing and you cound select "duplex printing" from your print setup screen and the printer would print both sides automatically.
May 13, 2010 | HP LaserJet 4650 Color Printer Manual...
LaserJet 5MPHP
Only if you print the first side then place the paper back into the printer to do the second side. Also referred to as manual duplexing. This printer has no automatic duplexing option.
Also keep in mind that the percentage of duplex prints you do should be very low as this printer has no method of cleaning the fusing unit as most printers do that are made for duplexing. The industry standard is 2% or less should be duplexed.
Jan 05, 2010 | Office Equipment & Supplies
Problem w/ Duplexing Attachment on HP PhotoSmart P1100 Printer
Maybe this would help:
Open the access door on the duplexer and clean the rollers with a damp cloth. If that solves the problem, I suggest using rubber rejuventator as a long term solution.
Nov 15, 2007 | HP PhotoSmart p1100 InkJet Printer
HP LaserJet P4015N Printer Logo
344 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
