Question about Cameras
Will not close while tape is in ejecter,alarm beeps and screen says (remove cassete), but will however close without tape??? canon mv830i digital camcorder...
  • 57 Answers
Several things could be happening...the tape is backwards, upside down, inverted or just wrong type since it closes without it. Next check to see on the inside if something is jamming the tape. While it closes without a tape there could be something that jams when a tape is inserted.
Posted on May 10, 2008
1990 lexus ls400 cassette player will not read or play my cassetes. i put in my cassettes but my front tape flap doesn't close and it automatically switches back to the radio.
The player has to seize the cassette as it is inserted and seat it in the correct position to be played. Sometimes the manual eject linkage becomes defective or misadjusted, preventing the cassette from seating correctly. The eject button may depress fully without causing ejection or it may depress but not cause ejection.
Dec 03, 2013 | Nakamichi 90 94 Lexus Cassette Tape Radio...
Will not eject tape
take the top off the VCR, you will see where the tape is hung up. Reach down and release the tape and pick it up, now close the top.
Jul 31, 2012 | Mitsubishi HS-U575 VCR
Tape will not eject / Battery full
while the eject process is trying to happen remove the battery and replace it. keep initiating the eject process and removing the battery and it should finally eject. If you attempt to use the camera again put in a new tape so you don't lose a tape that contains footage you may want to save.
Dec 07, 2008 | Canon ZR100 Mini DV Digital Camcorder
Canon zr300 ejects tapes
http://www.fixya.com/support/t985270-cassette_loading_problem_in_canon_zr200
I "smacked" my ZR300 as instructed on this site and it worked. Good luck!
littlequeen
Nov 02, 2008 | Canon ZR80 Mini DV Digital Camcorder
Mv800i camcorder
well there are certain cassettes made for that camcorder. i suggest you search for what the are called and then you can buy them
May 26, 2008 | Canon MV800i Mini DV Digital Camcorder
Canon ZR60 Mini DV Digital, remove the cassete message
This is a tape transport problem and is expensive to fix. Unless you know a cheap tech, it's time for a new one. Be patient loading and unloading tapes. This is usually what causes this problem. The Yellow warning sticker is REALLY important. Another important item is to always use the same brand of tape because switching tapes causes a gummy build-up the makes tapes get caught in the machine.
Videoteacher
Dec 08, 2007 | Canon ZR60 Mini DV Digital Camcorder
Loading tapes
I had the same Problem. My Solution was i open the camera, then i take the batery away. I put the tape into and close the camera, then i put the battery into and the camera close with the tape
Nov 05, 2007 | Sony Handycam CCD-TRV40 Camcorder
Cassete willl not eject
Solutions * The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. * Once the power source is available, some models require manually unlatching and opening a cover. * When the cover is fully open, the cassette will eject automatically after a few seconds. * If the tape still will not eject, seek assistance from a Service Facility because you need a special tool to remove the tape without causing further damage.
Dec 13, 2006 | Canon MV850i Mini DV Digital Camcorder
A beeping noise goes off, when i put in a tape, like it starts beeping then ejects it out, and the screen shows "remove casset", ive already tried the dry video head cleaners, but it ejects that tape back...
Does the unit say anything about moisture? This sounds like a moisture fault. Leave the unit open for a day in a dry area and try it. If it is moisture and everything is OK this should solve your problem. If it doesn't solve your problem you could have a bad moisture detector. This is a small square metal looking device near the video drum with two wires hooked to it. It's job is to protect the camcorder and keep it from damaging tapes when moisture is present in the unit. The simplist way to verify if it is defective is to jump a wire across the two connections and try the unit. If it works this is your problem and you will need it replaced. A good repair shop should be able to do it for about $50 US. Two websites which give free estimates are http://www.videotech.com and http://www.camcorderrepair.com Good luck.
Jun 16, 2006 | Canon ZR100 Mini DV Digital Camcorder
Cameras Logo
98 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
