Question about Shure Beta 58A Professional Microphone
WHERE TO SODER THE YELLOW AND GREEN WIRES - Shure Beta 58A Professional Microphone
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
The wiring diagram is in the User Guide that is on the Shure website.
Beta 58A Web Page
Posted on Sep 13, 2010
IM LOOKING TO INSTALL A TACH ON A HARLEY SPORTSTER 1980 3 WIRES BLACK GREEN AND YELLOW
trail and error it will or wont work.. but i got a tac green goes to coil black ground yellow battery.. if dont work reverse the green and yellow thats the basic tac wiring
Sep 18, 2014 | Harley Davidson Motorcycles
There are 3 wires on the itrip and i need to repair the car socket which one's goes to which soder points
if these are your letters on the board
this is with the car socket to your right
A Green
S Yellow
LR Brown or Orange
LG Blue
G Black
V Red
My problem is the other side need white blue and purple
Aug 17, 2011 | Griffin Technology - iTrip Auto Dock...
03 monte carlo ss power seat wont go down. how to fix?
i have a 2003 monte carlo and the wires came out of the plug under the seat. im trying to put them back in so my seat will be able to work. there are 12 wires that make up 6 connections. i need to know what wires go together. the wires are red with blue strip, red with green strip, red with white strip, yellow with blue strip, yellow with green strip, yellow with white strip, light green, green, peach, blue, light blue, and yellow.
Jun 08, 2010 | 2003 Chevrolet Monte Carlo
I need wiring manual for goodman mini split.
outside unit L1 and L2 are load (input 240vac)
then you have control voltage, usually yellow and blue (24vac) this connects to some 18/2 thermostat wire which goes inside as white and red.
note: this unit may only need 24v control which is 2 wires from the inside unit and also 3 wires 2 hot 1 ground for line voltage.
STANDARD WIRING
on the inside unit you have green, white, blue and red control wires.
on your thermostat you have white, red, yellow and green
you run the wire from the outside unit to the inside unit. then run a 18/4 wire to the thermostat if wired and join the following wires.
inside unit thermostat outside unit
green------------------------green
white-------------------------white
red----------------------------red
blue-------------------------------------------------------blue
yellow--------------------yellow
Oct 08, 2009 | Heating & Cooling
I am converting a 3 prong dryer to a 4 prong plug. The wires inside the dryer are black/yellow, white and blue. The wires on the plug are white, black, red and green. I am assuming the green is the ground...
on plug white is neutral, black is power , red is power, green is ground. black/yellow and blue are power and white is always neutral ie. (white to white) black to black/yellow, blue to red. green to grounding screw on machine
Jan 04, 2009 | Estate TEDX640JQ Electric Dryer
Need wire diagram for Canon 1d mark 11
if it's any help, I've got the top off my 1D Mk II and wiring as per photo link:
http://joeseph101.servebbs.com/Odd_files/3E7C3645-700.jpg
cheers.
Jan 03, 2009 | Canon EOS-1Ds Mark II Digital Camera
Replacing the thermostat, took the old one off without marking the wires. Hooked it up by color and we get the furnace when we put it on cool. wires are green, red, yellow & blue (ground wire)on the...
the normal wiring for stats is white=w=heat,red=r=24volts,green=g=fan,blue=c=common,yellow=y=cooling.
see what ties into your furnace board and match the terminals.
Aug 12, 2008 | Honeywell Heating & Cooling
Xbox360 video doesn't work
make sure you are using the right cables and that if you have the HD cable you have set the switch to the correct setting. If you are using the composite cable (red white yellow) try plugging it into a different port if the TV has it. If you are using component (red green blue) make sure the switch is set to HD.
Aug 07, 2007 | Microsoft Xbox 360 Console
MITSUBISHI WS-65908 red crt going off and on
You don't have enough soder on the STK392-570 unit ! I had to re-soder mine and is OK now
Aug 02, 2007 | Mitsubishi WS-65908 TV
Shure Beta 58A Professional Microphone Logo
286 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
