Question about De Dietrich Microwave Ovens
Problem with De Dietrich dhd7000x no suction - De Dietrich Microwave Ovens
Our De Dietrich DME715X microwave oven is sparking from the ceiling - have tried a new wave guide cover but that did not work.
Some ovens have a tuning stub in the wave guide. If it has become loose or rusted, it could cause the problem. If that's the cause, you would have to transfer all of the oven's components to a new cavity. This is usually not done due to the cost, although I did do this once on an oven that was still under warranty.
Make sure the wave guide is clean inside.
Also check for rust near the wave guide cover. Re painting damaged areas might help.
Sparks fly, too, if the ovens contents do not contain enough water to absorb enough of the microwave energy. Leftover energy converts itself into electrical current in any conductive material (such as cavity panels).
Nov 25, 2016 | De Dietrich Microwave Ovens
Microwave "popped" during use
Could be an open internal fuse
Sep 07, 2016 | De Dietrich Microwave Ovens
My De Dietrich DME 101XE1/3 microwave oven does not work.
I'd check the door switches first. The primary and secondary ones must go into the closed position when the door is shut.
You might also have an open thermal cut out on the outside of the cavity. There is also one on the magnetron you could check, although it's les likely to cause this problem.
Avoid all high voltage components, as there's likely to be a 4000 volt charge on the high voltage capacitor. Unpleasant to touch, and it could be fatal.
May 12, 2016 | De Dietrich Microwave Ovens
How to change the light bulb in the microwave oven
have to remove entire outer case to access it .
Mar 15, 2015 | De Dietrich Microwave Ovens
How to reset De Dietrich oven DO410
follow this step and fix it. A power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
God bless you
Jul 20, 2013 | De Dietrich Microwave Ovens
Tried to change time on clock and all the power has gone out of the microwave
The fuse in the microwave has blown, there are any number of reasons for this, one of the door switches has failed, "common problem" or in some cases just the fuse will go.
Mar 25, 2012 | De Dietrich DME101 1000 Watts Convection /...
The turn table doesn't always rotate. If you move it manually it will sometimes work for a short while.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 04, 2011 | De Dietrich MM6768 900 Watts Convection /...
Sometimes heat food and then not
Basic
heatman101
Jan 11, 2011 | De Dietrich DME112X Microwave Oven
Microwave has power but start button not working
Usually a shorted high voltage capacitor...see components section
Sep 17, 2009 | De Dietrich DME112X Microwave Oven
Microwave Ovens Logo
77 people viewed this question
Top De Dietrich Microwave Ovens Experts
William Miller
William Miller
ray gallant
Tom Chichester
Are you a De Dietrich Microwave Oven Expert? Answer questions, earn points and help others
