Question about DISH Network IR Remote Control
Remote lights up as if it is going to work however it won't do anything batteries are new, so that is not an issue almost seems like it needs to be re programmed or something my 2 year old could have pressed something (remote # IR/UHF PRO)
  • Official Brand Answer
  • 263 Answers
Without knowing the exact issue I can only provide general information. Since it seems like it may be a satellite address problem, I can definitely help with readdressing the remote.
To program remote to Receiver:
1. Access System Information from main receiver.
2. Note the number on the bottom by Primary Remote Address/Secondary Remote Address.
3. Hold SAT until all lights turn on on top of the remote.
4. Enter a number between 1-15 and press #.
5. Press record 3 times after it finishes blinking and the number by remote address should change.
Tommy Faust
DISH Network
Posted on Jan 28, 2011
I changed the batteries in my rca remote and now the indicator light will not turn off and the remote does not work
The new batteries may have been installed incorrectly. Check the polarity marking inside the battery compartment.
Nov 11, 2013 | RCA New Original CRK76WB3 Remote Control
Hunter ceiling fan. Remote control. Lights work, fan won't. Batteries in remote new.
If the fan came with a remote you probably need a new receiver. You can order at 1-888-830-1326. Need model #
Jul 07, 2013 | Dryers
Atlas ocap
use the camera digital or cell cam and with the remote control viewn see if the LED are ON. see the photo attached.
If do not do it. Open the remote control clean the keypads from corrosion, and resolder any colder joint . clean the contacts batteries and try again.
May 30, 2013 | Televison & Video
I have a 5301. Connected last year, worked fine. Installed new batteries, connects and beeps, but fireplace won't light. All controls are in correct position.
I know it seems obvious, but sometimes over the summer people shut off their pilot light, and when relighting forget to move the pilot knob back to the "on" position after the pilot is going - check this first.
Next, you can slide the switch on the Skytech 5301 receiver from "remote" to "on" and verify that it lights the burner. If it does, you may need to re-sync the remote to the receiver. If it does not, check to make sure your wires are nice and tight on the TH & TP/TH connections of the valve.
If you are still having trouble, Skytech has a toll-free hotline for tech support on the 5301. It is: 1-888-672-8929 8am-5pm EST.
Nov 29, 2012 | Procom SSU320RHN-GB Heater
My rca remote won't go to input or do anything
1) change the batteries by new ones
2) open the remote control clean the keypads from oxide, bad contacts,corrosion, dirty, and fix it.
3) try again, if doesnot work, you must go to the repair shop TV for fix it.
God bless you
Sep 23, 2012 | RCA Televison & Video
My remote control isn't working
Take a digital camera like the one on your phone... point the 'business end' of the remote at the camera while you can view it in the screen and press a button on the remote.. the IR LED on the remote should be visible on the camera screen. If not, try replacing the battery. If that doesn't work either then it would seem the remote as come to an unfortunate demise. If you can see a blinking light from the remote then it would seem the issue is with the radio's receiver. Make sure the IR port on the radio is free of stickers or anything else that might block it. Also, be sure that you have LOS (line of sight) from the remote to the radio.
Other than that it would seem you need to take it to a repair expert locally.
Apr 08, 2011 | Lasonic Ghetto Blaster i931 Boombox
IR Reliability--Intermittent
The Kenwood VR-510 does indeed respond to IR remotes. I now use a Logitech Harmony H659 which is IR only.
Your issue is a problem with the VR-510, actualy the whole series had a problem with cold solder joints on an assembly behind the front panel. Fix that and fix the problem. It frustrated me for 5 yrs.
Go here for the fix:
This site has the fix well documented: http://resnet.uoregon.edu/~gurney_j/kenwoodrepair/.
All is working great now!
Jun 08, 2007 | Kenwood VR-510 Receiver
DISH Network IR Remote Control Logo
155 people viewed this question
Top DISH Network Televison & Video Experts
brian soufane
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
