Question about Epson Stylus 1400 InkJet Photo Printer
Green lines about 1 inch apart right across the picture
Green lines about 1" apart on photo's I'm using Epsom DX6050. have run a jet clean.
Posted on Oct 25, 2010
My toshiba 55pd8800ta now has horizontal lines of picture across the whole screen. The picture and menu are out of sinc. Help!
These lines are called vertical retrace lines. Thin white lines are seen across all over the screen, at about an inch apart. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help. One among the posts has details about this fault.
Apr 05, 2013 | Televison & Video
Jvc rear projection tv
Do yourself a favor and dump this old TV, new ones are much better and cost is very low due to low demand.
May 18, 2012 | Televison & Video
I have a sony 60 in rear proj. lcd that has no red in the picture other than faint red vertical lines all the way across about an inch apart. any ideas ?
It sounds like you do not have the red component cable firmly inserted. I had this problem on my first HD TV, when the green component cable popped out when I moved the TV back in place, and the picture was desaturated of any green, causing my wife to remark, "That sure doesn't look like HD..." I reinserted the green component cable, and the picture was excellent. Check those component cables.
Feb 06, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Intermittent 3 inch green vertical line-5 inches from right side
it you have a repair skills you need to open the TV and make sure all the ribon connectors around the circuit boards are proper connected
and if all seems to be ok, the DG board will need to be replaced.
If you dont have any repair skills I would recommend you to take you TV to a repair shop since this is complex repair
Jun 16, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Red an green lines across the tv about every two
Sounds like you have retrace lines in your picture. It may resemble something like window blinds, but slanted to the lower right. You most likely have a bad crt or the AKB circuit is bad. This most likely needs a technician to adjust the G2's to see if it can be balanced.
Apr 29, 2009 | Sony KP-51WS500 51" Rear Projection...
Mitsubishi DLP WD 52525 has small green lines on the screen
do the lines go from top to bottom, and are they about 1 inch apart? or do they move diagonally across the screen?
Dec 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Black horizontal lines across pages
If they are the same distance apart every time then suspect the problem to be caused by the components in this order First the drum that is in the print or xerographic module, the charge and cleaning roller are located in that module also. So I suspect that first.its .Located above and to the right of the toner cartridge. Secondly it could be the roller on the toner cartridge, that would occur probably every 1 1/2 to 2 inches apart, the drum would cause the defect about every 3 inches. It less likely could be coming from the fuser, and if the fuser was causing that you should also have a lot of jams. There is also a transfer roller on the right hand door that could be causing it, but that would be exceptionally rare.
If the lines are random and have no consistant spacing, I would suspect the power supply then the laser.
Oct 28, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Red line across top half of screen
My maxent 42" has green and red flashing pixels all across the screen, what is the problem?
Thanks
Aug 30, 2007 | Maxent MX-50X3 50 in. HD-Ready Plasma...
Epson Stylus  1400 InkJet Photo Printer Logo
367 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
