Question about HP LaserJet P3005D Monochrome Laser 35 ppm Mono Parallel USB PC Mac Card Printer
Error code 81.0180 eio 1 - HP LaserJet P3005D Monochrome Laser 35 ppm Mono Parallel USB PC Mac Card Printer
    Champion:
  • HP Expert
  • 202 Answers
Upgrade the firmwere of jet direct card your problem will be resolved
Posted on Aug 31, 2010
4 Suggested Answers
  • 3 Answers
SOURCE: HP Colour LaserJet 4600dn printer problem
Try to remove the jet direct card into another slot. If that does not work you need to purchase a new jet direct card.
Posted on Oct 31, 2007
SOURCE: EIO 1 ERROR
There's probably a problem with the card in the printer. It may need a firmware upgrade, you may need to adjust settings or even change the slot. The EIO 1 means it is now in slot 1. Here are some steps to try from the HP website:
Press (Select) to enter the MENUS.
Press (Down arrow) to highlight INFORMATION.
Press (Select) to select INFORMATION.
Press (Down arrow) to highlight PRINT CONFIGURATION.
Press (Select) to select PRINT CONFIGURATION
Check if the I/O card is on ready state.
Make sure that TCP/IP status is ready.
Check the network statistics for any bad packets or bad transmition.
Try to use another slot then the one that the JD is installed on.
If the problem persist,try performing a cold reset with the JD inside.Warning: This will reset the printer's configuration to the default settings,and also to the JD so you will need to set again the network values.
Posted on May 19, 2009
KingDWS
  • 1606 Answers
SOURCE: ''HP Laserjet 4600, Error code 81 0180 E10 1 Error''
That indicates that the printer has a network card problem. You can try rebooting/resetting which can clear it but usually means a trip to the hp repair shop.
Posted on Jul 09, 2009
Error 09B207 007A0F4F
Switch the Printer OFF and ON again and wait for the initialization. If the Error code continues to appear, switch the Printer OFF. Remove the EIO Card (if installed) and make sure that the Hard Disk Drive is installed correctly by pushing it firmly inwards and checking that the two installation screws are completely tightened. Switch the Printer ON again. If the error codes 09Axxx or 09Bxxx appear then replace the Hard Disk Drive. If the Error Code disappeared after removing the EIO Card, then switch the Printer OFF and reinstall the EIO Card, making sure that the two installation screws are completely tightened. Switch the Printer ON again. If the Error Code reappears, then the EIO Card could be faulty. Replace the EIO Card. If Error Code 09Cxxx appears after initialization, then replace the Electronics Module. Once the Error Code has been solved, print an Internal Demo Print to make sure that the Hard Disk Drive is functioning correctly. If the Error Code reappears, then use the above information to troubleshoot the problem.
Dec 22, 2015 | HP DesignJet 1055CM Plus InkJet Plotter...
What does the error message EI0 1 Mean on the 8150dn printer?
EIO is the External Input Output slot that is on the formatter of the printer. the 8150 has 2 EIO slots (EIO 0 or EIO 1). One of the slots is probably the JetDirect card (network card) for the printer. The second slot might be a hard drive but is usually open.
If you are getting a EIO error first try reseating the JetDirect card (power off the printer first). If you are still getting the error pull the card and power up the device with out the card installed. if the error goes away power down the unit and install the card in the other EIO slot. if the card works you have a bad slot on the formatter but you should be good to use the device. If you get another EIO error the card is probably bad.
Mar 10, 2015 | HP LaserJet 8150 Printer
Error code 40.0
A connection with the card in EIO
slot X has been abnormally broken.
1. Press to resume printing.
NOTE
A loss of data will occur.
2. Check that all cables are
connected to the EIO ports
and that the EIO board is
seated properly.
3. If possible, print to another
network printer to verify the
network is working properly
Jul 24, 2012 | HP Color LaserJet 5550 Printer
81.0180 EIO 1 error
On the back of the printer where the network cable is plugged in, in your case it is EIO slot 1.
The problem could be the slot(EIO 1) or the JetDirect card that is plugged into that slot.
Power down and loosen the two screws on the JetDirect card and reseat it. Power up and try using the printer. If the error persists, power down and remove the JetDirect and plug it into EIO 2.
There are two screws that hold the EIO cover on. Power up and try the printer. If it works, take the two screws and the cover and use it to cover EIO 1. And you are good to go. If it fails again with a 81.02, the JetDirect may need changing
Nov 01, 2011 | HP LaserJet 5100 Printer
Hp Laserjet 2300n printer with error 81.0180 EIO 1 ERROR
You have a problem with the device plugged into EIO slot 1. Most likely it's a JetDirect card. Turn power off and reseat the card. Power up, if problem is still there put the card in the other EIO slot. There should be 2 EIO slots. If it still fails you will have to replace the JetDirect
Oct 07, 2010 | HP LaserJet 2300N Printer
81.0180 EIO 1 error code on a hp laserjet 5500 dn
The printer has encountered a problem with an EIO card device in slot 1. Power off, remove the device from the slot and power on. If it comes up ready then refit the card and try again. if it still fails with the error recommend replacing the EIO device in that slot
Oct 07, 2009 | HP LaserJet 5500DN Printer
Getting error code 04C300 00310000
Hi;
if you HP 1050C Plus display System Error 04CXX Try the following Steps to resolved an error:
1.)Press ENTER and switch the printer OFF. Remove the Hard Disk Drive (if installed) and make sure that the EIO card is installed
correctly by pushing it firmly inwards and checking that the two installation screws are completely tightened. Switch the printer
ON again. If this error code continues to appear then replace the EIO card.
2.)If this Error Code disappeared after removing the Hard Disk Drive, then switch the Printer OFF and reinstall the Hard Disk Drive, making sure that the two installation screws are completely tightened. Switch the Printer ON again. If this Error Code reappears, then the Hard Disk Drive could be faulty.
Replace the Hard Disk Drive.
3.)If this system error continues to appear after replacing the EIO card or the Hard Disk Drive, then replace the Electronics Module...
May 26, 2009 | HP DesignJet 1050c InkJet Printer
Please help me ??? system error
System Error: 04Cxxx
Problem
Description:
EIO Accessories (EIO Card/Hard Disk Drive) Error.
Corrective Action: Try the following:
n Press ENTER and switch the printer OFF. Remove the Hard Disk
EIO card.
n If this Error Code disappeared after removing the Hard Disk
n If this system error continues to appear after replacing the EIO
System Error: 0000D8 XXXXXXXX (Non-Continuable)
Problem
Description:
External Library Error.
Corrective Action: Refer to System Error Code 070100
System Error: 070100 XXXXXXXX (Non-Continuable)
Problem
Description:
Firmware Error.
Corrective Action: Power the Printer OFF and ON again to see if the System Error
disappears.
If the Error Code reappears, then report the error to the HP response
Center or the nearest HP Support Office, stating the following
information.
n Model and Serial Number of the printer.
n Which firmware revision the printer is using (See Note below).
Check firmware in Utilities / Statistics / Code rev.
n The complete error number (See Note below).
n The Service Configuration Print þ
n The Current configuration sheet.
n Which software application the customer is using (name, version, etc.).
NOTE When reporting the System Error Code, make sure that you
supply the full Error Code (including the last 8 numbers where
applicable) and the firmware version. Without this information,
HP Support Personnel cannot help you.
Apr 06, 2009 | HP DesignJet 1050c InkJet Printer
Sysytem Error 009B002 007A046F
System Error: 09xxxx (Non-Continuable)
Problem
Description:
n Switch the Printer OFF and ON again and wait for the initialization.
n If the Error code continues to appear, switch the Printer OFF.
n If the Error Code disappeared after removing the EIO Card, then
n If Error Code 09Cxxx appears after initialization, then replace the
Electronics Module
n Once the Error Code has been solved, print an Internal Demo
Nov 21, 2008 | HP DesignJet 1050c InkJet Printer
System Error 04C300 00260000
System Error 04CXX Try the following Steps to resolved an eror:
Aug 21, 2008 | HP DesignJet 1050c plus InkJet Printer
HP LaserJet P3005D  Monochrome Laser  35 ppm Mono  Parallel USB  PC Mac Card Printer Logo
1,458 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
