Question about Oceanic Veo 100nx 3 Gauge Scuba Dive Computer
Veo 100Nx: After turning on and diagnostic is done, ALT flashes a few times and computer turns off.
  • djkrash_10
    djkrash_10 Feb 11, 2012
    Have the Same problem, Did you find any solution?
  • djkrash_10
  • 60 Answers
Sounds like your battery power may be low. Strongly recommend you send it to your nearest authorised dealer for a service. Hope that helps.
Posted on Nov 05, 2010
Hello I have a 1994 maxima manual transmision,it have a check engine light on,when I start the car and beguin to drive it,runs perfect the a few minutes later the car gets very lazy almost want to turn...
Hello! I'll need the trouble code to fix your vehicle...Below is procedure with a code list...Guru...saailer
Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.
  • Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.Observe the red and green LED lights on the side of the computer. The red light flashes to indicate the "Tens" digit of the code and the green light flashes to indicate the "Ones" digit of the code. For example, if the red light flashes two times and the green light flashes seven times, this would indicate code 27.
    Turn the ignition key off for two minutes to exit diagnostics. The computer will automatically return to mode one for normal operation...
    Code 11 Crank sensor angle
    Code 12 Mass airflow sensor
    Code 13 Engine coolant temperature sensor
    Code 14 Vehicle speed sensor
    Code 21 No ignition reference
    Code 22 Fuel pump
    Code 31 Engine control unit
    Code 32 EGR sensor
    Code 33 Oxygen sensor
    Code 34 Knock sensor
    Code 35 EGR temperature sensor
    Code 43 Throttle position sensor
    Code 45 Injector leak
    Code 51 Injector circuit
    Code 54 Automatic transmission signal
    Code 55 No malfunction recorded
    May 04, 2012 | 1994 Nissan Maxima
    Won't idle wants to stall at lights and stop signs. want to stall when it shifts into 2nd gear [auto]. thinking maybe fuel filter?
    It could be the fuel filter, air filter, vacuum leak, MAP sensor, or any number of things. If it is running this bad you should have a code stored in the computer. You can pull it out using a paper clip by jumping the two ports on the diagnostic connection under the dash. You'll see a rectangle with a bunch of little slots. In one of the corners there will be two metal tabs in the slots right next to each other in the same row. Put a paper clip between them so they make electrical contact and turn the key to run, don't try to start it. The 'service engine' light will start to flash codes after a few seconds. All of the codes are two digits and get repeated three times in a row. The first code you will get is a 12, that lets you know it is in diagnostic mode. It will be 'flash' pause 'flash flash' longer pause, 'flash' pause 'flash flash' longer pause, 'flash' pause 'flash flash'. Be sure to write them down. When it flashes the 12 code again it is done. If you get the 12 code more than three times in a row when you first do it, then there are no codes stored. These codes will give us a better chance of tracing down the issue the first time instead of just guessing and throwing parts at it.
    Jan 05, 2011 | 1991 Chevrolet S-10 Blazer
    My nissan serena air bag light flashes on and of
    "If you have the airbag light, it will show steady for a few seconds (the manual says 7 secs) after you turn the key from off to on (but not start) and then start to flash. Here is how to reset it:
    1. Turn the key from off to on.
    2. Watch the airbag light closely. It will stay on for a few secs. and then as soon as it blinks off (the start of the flashing), turn the key off instantly.
    3. Count to 5 (1 Mississippi, 2 Mississippi . . . .)
    4. Repeat steps 1-3 two more times until you have done the cycle three times.
    5. Now turn the key on and watch the light. It will start blinking in a different, slower manner. This is diagnostic mode. You can watch this for a little while, no hurry.
    6. Now turn the key off again, Count to 5 like in step 3 again, and turn back on. If the procedure worked, the airbag light will not be flashing.
    If it does not work the first time, just repeat the steps again."
    Aug 06, 2010 | 1996 Nissan 200SX
    I turned off the Dell Dimension e520 before a storm. I have tried numerous times to turn it back on, only to have a yellow flashing light. How can I get my computer to turn on?
    Good day.
    Here's my point of view of you problem. I have also experienced the same problem since it is always raining here in the Philippines. I just have to ask a few questions before i can give a direct solution to you.
    Please provide the following:
    1. Do you have a voltage regulator in your computer set. 2. Do you hear a beeping sound everytime you turn your computer on after the incident happened? 3. Does the processor fan still runs after turning your PC on or not? 4. Kindly provide your computer specs.
    Good day and should you have any questions regarding the questions, feel free to approach us.
    Jun 15, 2010 | Dell Dimension E520 PC Desktop
    Diagnostic Troubleshooting Codes for 1996 Chrysler Sebring Cvtble
    FIRST YOU TURN IGNITION SWITCH ON WITH ENGINE OFF.LOOK AT MIL LIGHT IT SHOULD COME ON 3 SECONDS THEN GO OFF IT NOT THEN YOU GOT BURN OUT BULB OR A CIRCUIT PROBLEM.IF ALL IS WELL. ATTEMPT TO START ENGINE.TURN OFF IGNITION. WITH OUT STARTING ENGINE.TURN IGNITION ON OFF ON OFF AND WITHIN 5 SECONDS RECORD 2 DIGIT DIAGNOSTIC TROUBLE CODES.DISPLAYED BY FLASHING MIL LIGHT.YOUR MIL FLASHES WILL BE YOUR CODE LIKE THE MIL LIGHT FLASHES 5 TIMES THEN PAUSE FLASHES 3 TIMES THAT CODE 53 THAT YOUR CODE.IT LIKE MORSE CODE.WHEN DONE TURN OFF IGNITION SWITCH.GO TO AUTO ZONE OR ADVANCE AUTO GET HAYNES COMPUTER CODE BOOK. TO GET CODE MEANING OR WHAT SENSOR GONE BAD.HOPE THIS CAN BE SOME HELP.
    Jul 27, 2009 | 1996 Chrysler Sebring
    Key for Royale 100NX to turn on machine
    is there a number on the front of the lock, if there is then you can have a key cut to code. if not drill the lock and replace.
    Jul 05, 2009 | Casio Parts Cash Register PC Desktop
    How do you reset driver airbag warning light on 2000 Nissan Frontier?
    if you have the airbag light, it will show steady for a few seconds(the manual says 7 secs) after you turn the key from off to on(but not start) and then starts to flash. heres how you reset it, that is if there isn't any under layin problems in the system.
    1. turn the key from OFF to ON
    2.watch the aifr bag light closely. it will stay on for a few secs, and then as soon as it blinks off(the start of the flashing), turn the key off instantly.
    3. count to 5 (1 mississippi, 2 mississippi.. ect..)
    4. repeat steps 1-3 two more times until you have done the cycle 3 tinmes
    5. now turn the key on and watch the light. it will start blinking in a different, slower manner. this is diagnostic mode. you can watch it for alittle while, no hurry.
    6. now turn the key off again, count to 5 like in step 3 again, and turn it back on. if the procedure worked, the airbag light will not be flashing.
    if it doesn't work the first time, just repeat the steps again. if it doesn't work after the second try, there is more than likely something work with the srs system and needs to be serviced by the dealer.
    this seams to be a standard airbag reset for all newer nissian vehicles
    Jul 03, 2009 | 2004 Nissan 350Z
    My veo camera do not power up
    Normal 0 Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
    Hope this helps. Bud
    Oct 27, 2008 | Veo Wireless Observer Network Camera
    Oceanic Veo 100nx 3 Gauge Scuba Dive Computer Logo
    277 people viewed this question
    Top Oceanic Scuba Diving & Snorkeling Experts
    Bill Boyd
    ray gallant
    Are you an Oceanic Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
