Question about Dryers
Kenmore Elite Dryer will not start. When I press 'start' all button lite up, but the 'start' button give out a low buzzing sound. It will not stop until I press 'cancel'.
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 04, 2010
My Kenmore Elite dryer has power & you can select a cycle, but pressing the start button does nothing. The timer flashes and makes a buzzing sound.
Check door switch plunger, it protrudes into the switch to make contact and may be broken, if OK, check for broken door switch. Order parts from repairclinic.com
Sep 18, 2015 | Kenmore Dryers
I have a Kenmore Elite HE4 smartheat quiet pak 9 that has power but will not start.
Sounds like the belt that turns the drum could be broken. I'd check that first.
Oct 12, 2017 | Kenmore Elite HE4 Electric Dryer
Drum will not turn and there is a buzzing sound when start button is pressed. How do you access the drum or motor on the Kenmore Elite Model #592-89309?
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
May 23, 2011 | Dryers
Our Kenmore Elite HE4 gas dryer will not start although all controls on front are lite and appear to be functioning properly (settings can be changed, etc). I has been working fine for several hours until...
check the door switch and door latch. Open door, set the dryer to air fluff cycle, and manually depress the door switch. Press start button. If it started - door needs alignment to fix it.
If it did not start:
If your dryer has light inside - check if light turns off when you press the switch. If not - switch needs replacement.
If all that checks out ok - the problem is more serious, and you might need a tech to come out and diagnose it.
Mar 04, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Dryer, start button doesn't stay on
when I press and hold the start button it tumbles but not sure if it heats up. When I let go of button machine stops
Aug 16, 2009 | Kenmore 62602 Electric Dryer
Elite 73952 will not start
sounds like it is the motor, open the door and press the door switch in ,have another person push the start button,and you tunr one of the drun fins. IF itstarts, you need a motor
Mar 11, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 80 series Dryer NOT working
I have a kenmore elite , smart pac,he3, it will run for 10 min then shut off and a code (F 70 ) will start flashing, what does that mean.
Feb 02, 2009 | Dryers
Kenmore elite HE3
You need to check if the Spray Arms are knocking against an item in a basket. If the source of noise cannot be determined, run a program without plates or glassware. If the noises continue, let me know for further investigation.
Oct 05, 2008 | Kenmore 82822 Electric Dryer
Dryers Logo
41 people viewed this question
Top Dryers Experts
