Question about Dell 0Y3740 Keyboard
My Dell laptop keyboard is very temperamental. It's not any particular key, but when typing some letters or numbers or special characters won't type. Very frustrating when trying to enter a password for example and it's not working because one of the key didn't work. I called technical support and they told me it's a static build up and to remove the battery and press the ON button for 10 sec. to remove excess of static. It seems to work at first but it didn't fix the problem. I still have some keys that won't type unless pressing 2 or 3 times.... Any suggestions as to what is wrong?
  • 2 more comments
  • icilynda Aug 31, 2010
    I forgot to mention that I tried to use an external keyboard to see if it would work better but it still does the same thing. Also, I know for sure that nothing has ever been spilled onto the keyboard. Do you still recommend changing the keyboard?
    the external keyboard is USB. I type about 40wpm.... not very fast! but I know my partner uses the 2 fingers method! and he does hit the keys quite hard. How does it work replacing the keyboard, does it come out in one piece?
    Thank you very much!
    Very fast and friendly service, thank you very much for your help.
  • 905 Answers
Welcome to the dark side of laptops. The biggest complaint about laptop keyboards is that some keys start to work intermittently. Every laptop that I have ever used, suffered the same fate. Getting "stuff" dropped into the keyboard is also a pain, as the key tops are difficult to remove and replace to get said stuff blown out.
The solution is to replace your keyboard. It isn't hard, but it can be tedious. Keyboard replacements can be obtained from several places on the internet, and it is something that you are able to do yourself. Just allow yourself an hour at the minimum so that you don't get rushed.
But, before replacing, try spraying canned air under the keys to blow out any kind of debris that may be present.
Posted on Aug 31, 2010
  • Sheldon Dedek Aug 31, 2010
    Ahh, this is different. Using an external keyboard, and experiencing same problem on the internal keyboard points to the keyboard controller. It is 1 thing to have mechanical. Another when it becomes electrical.
    It wouldn't be the same keys that are giving issues on both keyboards, would it? May I ask how fast you type? Is your ext. keyboard USB or PS2?
    I ask about typing speed because generally the faster you type, the harder you hit the keys, and the faster the keys wear out. Doesn't matter if external or internal, though external / desktop keyboards do last longer. USB / PS2 leads towards a suspected timing issue. It takes longer for keypresses to be acknowledged on USB vs. PS2.
    I type 120wpm +, uncorrected. I replace my keyboards at least every quarter. And yes, I use a laptop (Acer - cheap keyboard replacement), with both int. and ext. 'boards.
    If both keyboards are doing the same thing, then it likely is not a keyboard issue. But, to answer your question, search for your Dell Model # and Keyboard Replacement on google, and you will find dozens of sites catering to your needs.
    Go into the BIOS, and under keyboard mouse, change the option for external, and change the USB type to Legacy (better w/ ext. keyboards). That should help w/ external problem, but not sure about internal though.
How do I type accents on a laptop without a secondary numeric keypad?
Type character map in your windows search box and select the font you require. You may need to download the windows language pack for each language you use.
Oct 26, 2014 | Compaq Computers & Internet
Tip
Short cut keys for Blackberry phone,storm,curve,pearl.bold
Typing shortcuts keys for BlackBerry
These shortcuts keys can be used when typing text in Blackberry:
  • If you want to type the alternate character on a key, hold the Alt key and press the character key.
  • For an accented or special character, hold the letter key and roll the trackball left or right. Click a selected character.
  • To type a symbol, press the Symbol key. To view more symbols, press the Symbol key again. Type the letter that appears below the symbol to insert the corresponding symbol.
  • To insert a period (.), press the Space key twice. The next letter is capitalized.
  • To capitalize a letter, hold the letter key until the capitalized letter appears.
  • To turn NUM lock on, hold the Shift key and press the Alt key.
  • To turn NUM lock off, press the Alt key.
  • To insert an at sign (@) or a period (.) in an email address field, press the Space key.
  • To type a number in a number field, press a number key. You do not need to press the Alt key.
  • In order to type a number in a password field, hold the Alt key and press the number key.
  • To type a letter in a number field, hold the Alt key and use the multi-tap input method to insert the letter.
  • If you are typing input languages, hold the Alt key and press the Enter key. Select a language, then release the Alt key.
Know more about Windows 7
Windows 7 keyboard Shortcuts
on Dec 05, 2009 | Cell Phones
Tip
How to use Blackberry as a modem to acces internet?
Keyboard typing multiple letters/ numbers when pressing certain keys.
Keyboards on Windows computers can repeat letters when key press sensitivity is too high. This problem can be rectified by adjusting your keyboard's repeat frequency. Once this is lowered, key presses will occur slower and you will not have the letters repeated instantly.
Click"Start," then "Control Panel." Click "Hardware and Sound," followed by "Keyboard." Move the "Repeat delay" slider further to the left below the "Character repeat" option. The further left the slider moves, the longer the delay will be before a character repeats.
Feb 03, 2013 | Computers & Internet
I use a lap top, IBM ThinkPad, that has been in my docking station for a long time and it works fine in the docking station with the external key board and screen. I recently took it out of the docking...
NUMBER LOCK
You have press the NumLk key (number lock) and this changes the right hand keys to a number pad.
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock.
Dec 03, 2012 | IBM ThinkPad T41 Notebook
Keyboard mapping
Your numlock is turned on. There is more than one way to turn it off.Find a USB keyboard, and plug it in. Then push the numlock key on the USB keyboard to turn it off.OR, if you don't have access to one of those, hold down the fn key (lower left hand corner of the keyboard) and press the key with numlock or number lock written on or near it.
Mar 01, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
How to use accents when writing in Spanish in a Dell Precision m4500 laptop?
On Windows XP
  1. Log On
  2. Click the Start button
  3. Click on Control Panel
  4. Click Regional and Language Options - a new window will pop up
  5. Click the Languages tab
  6. Click on the Details button
  7. Click the Add button - a new window will pop up
  8. Select United States-International (keyboard layout menu)
  9. Click OK
  10. Click Apply
  11. Read the instructions for "Using the U.S. - International Keyboard" below.
Note: You will now have a keyboard icon on the taskbar (usually on the right side). To switch between keyboard layouts click the keyboard icon on the task bar and choose which layout you want to use. Changing the keyboard layout will only affect the log on profile used. No other users will be affected.
Windows Vista
  1. Start-->Control Panel-->Clock, Language, Region-->Change Keyboards
  2. New Window: Click the Change Keyboards button
  3. New Window: Click the Add button
  4. Select United States-International keyboard
  5. Click OK
  6. From drop down menu (Default Input Language) select United States International
Using the U.S. - International Keyboard If you followed the above directions carefully, your keyboard will now react slightly differently than it did before. First of all, notice that if you strike the single apostrophe (') key, nothing happens. To type the single apostrophe now, you must strike the single apostrophe key and then strike the space bar. When you strike the spacebar, the apostrophe will appear.
The next thing to note is that the quotes (") key behaves the same way as the apostrophe key. You must first strike the quotes key and then strike the space bar in order to create the (") symbol. These two minor inconveniences are more than made up for by the ease with which you can now type the special characters.
To type the special characters, two keystrokes are required. To type the ?, you need only strike the apostrophe key and then the letter a. The other characters are just as easy:
  • ? = ' + a
  • ? = ' + e
  • ? = ' + i
  • ? = ' + o
  • ? = ' + u
  • ? = ~ + n
  • ? = " + u
To type the special punctuation characters, you need to hold down on the Alt key while you strike the appropriate punctuation mark. On some keyboards, only one of the two Alt keys will work for this.
  • ¡ = Alt (hold down) + !
  • ¿ = Alt (hold down) + ?
Using Cryptic Codes If, for some reason, you don't want to change your keyboard, you can always type in the troublesome cryptic codes. Using this arcane system, the following codes apply:
  • ? = Alt + 0225
  • ? = Alt + 0233
  • ? = Alt + 0237
  • ? = Alt + 0243
  • ? = Alt + 0250
  • ? = Alt + 0241
  • ? = Alt + 0252
  • ¡ = Alt + 0161
  • ¿ Alt + 0191
When using this utterly out-dated system, there are two important things to remember. First, when you type in the numbers, some keyboards require that you use the "numeric keypad" located to the side, rather than the numbers along the top. Second, on some keyboards, only one of the two Alt keys will work for this.
May 02, 2011 | Computers & Internet
What is the keyboard combination for Ñ in a
Alt+0241
On Windows, the Alt key functions as a modifier like the Shift key. To make special characters, hold down the Alt key and type in the numbers from the numeric keypad. Note that on the some small keyboards (e.g. laptop keybaords) the “numeric keypad” is found by pressing the NumLock key and then looking for the keys on your keyboard that double as numeric keypad keys when in NumLock mode.
Jun 23, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
Screen only displaying keys that are on blue on keyboard
sir if u wants to type the special characters then press the shift key before pressing that button.
Apr 23, 2009 | Dell 0Y3740 Keyboard
Dell 0Y3740 Keyboard Logo
583 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
