Question about Kenmore Freezers
Model 23971 # kenmore 19 #216369506 0r 8 cant read it. Buzzer was on we were out of town it was deforstins. Help my husbon is a handyman he can fix it please help me.
Kenmore upright freezer model 31205 .Needs a new evap fan motor.Sears parts says model doesnt come up cant help.
Recheck the model number on the fridge or try the Manufacturer web sites. A lot of fridges share the same parts, you should find a Kenmore model that is listed with the same part.
Nov 20, 2016 | Kenmore Freezers
Is the Kenmore Freezer model 23971 supposed to run continuously or should it be alternating on and off? Mine is running all the time and I am not sure if this is broken or working correctly.
If it is in a warm garage or the sun is shining on it through the window its going to run a lot. Try putting a thermometer inside and see what temperature is. Leave it in for an hour or so. It shouldn't be below 0 degrees F unless you have some high quality ice cream in there that needs a colder temperature. Slowly turn the temperature up one number increment every couple of days until you reach 0. Hope this helps and good luck.
Oct 05, 2014 | Freezers
Kenmore freezer buzzer
I would need to model number to check if you have a on/off for you over temp alarm. That "Buzzer" is a over temp alarm. If you fridge uses a 9volt battery then you might need to replace the battery. Please post your model number.
Mar 13, 2013 | Kenmore Freezers
Defroster get red hot
Kenmore Frostless Upright freezer model# 23971. The alarm sounded, all contents in freezer is frozen solid. We turned the alarm off, but the red light continues to blink. How do you reset the alarm and stop the red light from flashing? It has been 3 days now and every time we have check to see if the contents has started to defrost, there is no signs of defrosting, everything inside of the freezer remains frozen solid.
Sep 01, 2010 | Kenmore Freezer 20.6 cu. ft. Manual...
Warning buzzer sounding
this is usually an indication of a temp. problem you need to check the seal around the lid,make sure there is not gaps and or the door was not left open.
Jan 31, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
Freezers Logo
73 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
