Question about RCA P52920BL 52" Rear Projection Television
I have an RCA Home Theater 52" Projection TV P52920BL. It appears one of the three TV lamps (bulbs) is going out. On pictures with a red hue, the red is deep and too dark (black) and adjusting controls will not lighten this. What are the model numbers for the three replacement bulb in this TV and where can I get them for the best cost? Can you recommend in-home TV repair consultants in Atlanta GA?
  • 4,889 Answers
If I am not wrong, this is a CRT projection tv and does not have any lamps(they exist only in DLPs). SO i guess you are talking about the three CRT tubes. This sounds more like a convergence problem. Did you try adjusting it?
Posted on Aug 31, 2010
Replacement bulb
model indicated here does not use a bulb or lamp, it has three picture tubes.
Apr 27, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Problem with sony tv kp-15ws150 convarace
Ur convergence it dead.Know how to solders?Tries these websites for convergence kit.Tv repair World.com,Tvrepairkits.
Dec 12, 2009 | RCA P52920BL 52" Rear Projection...
RCA 52" projection tv convergence problems,can i fix it?i try auto convergence? the model is P52920BL and is a 1998 i try the green centering blue & red convergence in the setup of the tv,and it goes back...
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
Mar 28, 2009 | RCA P52920BL 52" Rear Projection...
What is Convergence IC's?
Tube-type projection TVs have separate picture tubes (CRT) for red, green and blue. Convergence is the process of getting the images from the three CRTs to line up properly so you see the correct colors on the screen. The convergence output integrated circuits (ICs) are the electronic devices which make this happen.
Mar 23, 2009 | RCA P52920BL 52" Rear Projection...
MY RCA 52 IN TV WONT TURN ON?
MOST LIKELY, THE PROBLEM
IS THE BULB USED IN THE SET?
BY THAT I MEAN THE HIGH INTENSITY REAR PROJECTOR BULB?
DO A SEARCH ONLINE AND THERE ARE COMPANIES SELLING THE BULBS AT A PREMIUM. YOU MAY WANT TO CONSIDER DUMPING IT.........
Mar 14, 2009 | RCA P52920BL 52" Rear Projection...
RCA P52920BL (1999)
The fuse fails when the convergence power supply fails,putting a new fuse in the set will let the unit come back on but convergence is not working,check in screens in the menu to see if you have adj. projection t.v.,if the is not in the menu,replace reg ic part number 215530 on the convergence power supply,this board is above the right module mounted on the black plastic.,hope this helps
Feb 28, 2008 | RCA P52920BL 52" Rear Projection...
RCA P52920BL
i'd like to help.that model# looks familiar.but that chassis num you gave looks more like a serial num all my rca prints go buy chassis # is there anothe num like ctc197 exet or ptk19 doc
Aug 25, 2007 | RCA P52921 52" Rear Projection Television
RCA 52" Big Screen TV model;P52920BL Chassis;PTK195KB PICTURE BOWED AFTER FUSE BLOWN.
You have bad convergence IC's.. If your not experienced in troubleshooting electronics or soldering, you should have a trained tech take a gander at the set. Its not worth risking life and limb to save a few bucks, Good Luck
Jul 30, 2006 | RCA P52920BL 52" Rear Projection...
Televison & Video Logo
56 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
