Question about Samsung SyncMaster 204B 20.1" LCD Monitor
My LCD Samsung Sync Master 172x Blank Screeen
Only Blank Sreen and No Singnal or Digital - Analog Text, but my data cable is good and my computer is good condition
  • 3 more comments
  • jkkeckk Jun 21, 2008
    My 172X keeps turning off. Power supply tested OK with multi-meter, XVGA and SVGA cables...same problem. SVGA connected CRT monitor on some video card has no problems.
    Hate to throw this beautiful LCD display away, but it no longer works!
  • erwin7 Sep 20, 2008
    Hi There,
    I got the same thing, when i switch the monitor off, it sometimes cant be switched on again. The green power light comes on for 3 seconds and goes out again.
    Sometimes it happens that the screen just shutdowns and the power light goes off, this happens without user interference.
    Its a great screen but... what causes this problem? how to fix it?
  • Anonymous Sep 21, 2008
    same problem.
    Green light appears for maybe a second and then turns off (along with the screen)
    Happens sometimes on startup and sometimes during operation
  • nasde Dec 28, 2008
    Same problem! If I start PC from cold - and power off, it works fine - as long as monitor never turns off. However if the monitor turns off - via powersaver, or manually, or if screen resolution changes - it will not turn back on.
    Monitor light will stay on for 1 sec before turning off. Moving mouse or keyboard does not help either.
  • kesh140
    kesh140 Jul 28, 2012
    This has also happened to mine as well. If anyone has a solution please let us know.
  • 30 Answers
Hi Yanss1971,
May i know, what's the power led light status? Red, Green, Orange, Blinking or Off? If you need more info on lcd monitor repair please visit this site as reference: http://fastrepairguide.com/p/lcd-monitor-repair/
kent
Posted on May 09, 2008
My Samsung Galaxy Core Prime just recently unsynced all contact in my phone from my fb friends & now there is not even the option to sync phone contacts with fbook. What happened & how can I fix it?
Hi Kimb
I had a similar problem recently.
Lost all my data from one device.
It's a bit hard to put into words...
Sync means to syncronise e.g.. one list to another list, to make them the same.
It's supposed to sync the master with the copy
Trouble is, it often sync's the copy (0 data) with the master which makes both the same (or blank)
Some sync software keeps both copies and transfers new contacts only.... making them equal.
Check your sync settings to see which is replacing which.
You decide which is the master and always go from master to clone.
Although not Samdung G specific....
Hope this helps
Example of a program with good sync options.
Mar 16, 2016 | Samsung Cell Phones
When the monitor is turned on it displays "analog, digital" then "check signal cable", what is the problem?
check the data cable from the CPU to the monitor, it measn the monitor did not detect any signal from the CPu, or the system is not booting. Good luck
Sep 11, 2009 | Samsung SyncMaster 932B LCD Monitor
Cannot get sound using dvi cable
DVI is digital VIDEO interface, you will need a seperate cable for audio
Jun 15, 2009 | HP w1907 LCD Monitor
Samsung 2233 stuck in analog
in your mon there will be small left arror image in box called enter button,,,,if u press that button its shows analog and digital in that have to choose digital.....
Apr 03, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Monitor reads no connection
1. Check the cable connection to your PC. It might be disconnected.
2. If your have more then one cable input on your LCD monitor(VGA or DVI) check if you selected correct input; digital for DVI or analog for VGA.
Jun 07, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
LCD Monitor SAMSUNG Syncmaster 172x
change the potentiometre(three broches) and adjust it.
you find it near circuits which switch on the lampes (card has smalls tranformers)
good luck,Mustapha(Casablanca,
Morocco)
Apr 08, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Viewsonic VA712b issuses
Digital-to-Analog Converter - DAC When referring to Audio, DAC is also short for Digital-to-Analog Converter and is the process of converting a digital signal into an audio signal.
Random Access Memory Digital-to-Analog Converter - RAMDAC Pronounced Random Access Memory Digital-to-Analog Converter, RAMDAC is the ... the digital data to an analog signal to be displayed on a computer monitor.
Good Luck, Please dont for get to Vote/Thank you.
Dec 19, 2007 | ViewSonic VA712B 17" Flat Panel LCD...
Samsung SyncMaster 204B 20.1" LCD Monitor Logo
922 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
