Question about KitchenAid Refrigerators
Need manual superba ksrs271 - KitchenAid Refrigerators
Ksrs271 refrigerator moved from downstairs to upstairs now not cooling
did you lay it down? if so it needs time to settle.
after switching off you might have to reset the temperature.
Sep 30, 2016 | Refrigerators
Can we light a gas oven manually, it is a kitchenaid superba
No, You have to replace it. When the ignitor grows weak, it does not allow enough voltage through it to open the gas valve. Very common problem. Good Luck, Appliance Specialists
Jan 31, 2010 | Ovens
Kitchenaid Superba 27 KEMS376WHO
Go to manualsonline.com. They will ask for make and model of your appliance. Most manuals are free. Give it a try.
Jul 08, 2009 | KitchenAid KEBC107 Electric Single Oven
Over temperature alarm on KitchenAid Superba Refrigerator
Remove the screws from the bottom grill cover. Use a vac brush to clean out that area. You should also pull the frig out from the cabinet and vac behind.
Also, you can go on kitchenaid.com and download a product manual to replace your lost manual. Click on customer care and select "Locate Manuals & Guides."
Mar 31, 2009 | KitchenAid Superba 21.6 cu. ft. Top...
How do you change filter in Kitchen Aid superba refridgerator
The superba series is a dishwasher type. the model number would be really helpfull. either way if you go to kitchenaid.com and click on product type then on refrigerator it shows all models and when you click on your model it takes you to its page and on the bottom of the page is the installation guide and every manual for your fridge. its all in PDF format and really easy to use. if you still need help please email me at phoenixnixinks@yahoo.com with the model number and i will be more than happy to help you farther.
good luck
Jan 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
I need help
how to change the water filter
Jul 11, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
205 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
