Question about Lite On (PS-5101-2B) (ps51012b) 145-Watt Power Supply
My Power supply blow up and it seems RV 120 on the board that are bad. MODEL:PS-5301-08HF DC OUTPUT:300W INPUT 100 -127V 200 - 240 Please could you direct me
3 Suggested Answers
  • 1027 Answers
SOURCE: cannot locate the fuse in the liteon power supply
The fuse is internal, and soldered to the circuit board. It can be replaced by soldering - an old-timers trick is to get a new fuse (with pig-tails) and just solder in parallel with the old - no removal needed.
Posted on Jan 31, 2010
SOURCE: I want the electronic layout of LITEON model NO.
what in pin order mainboar connector liteon ps5301-08hf
Posted on Sep 28, 2011
I have an Astec DS 1500-3-001 power supply that I want to use a a stand alone PS. What pins do I need to connect to get +12v DC output with 120 VAC Input.
Mike
I take it that this is a standard power supply out of a PC (switch mode)
These are a common connection point on any brand PC
Use a DC Voltmeter to find the Ground, +5 Volt & +12 volt wires to power your 3.5 inch Hard Drive. The 2.5" Hard Drives (laptop) has only Ground (Black) & +5 Volt.
Oct 30, 2014 | Computers & Internet
Motor tripping out power supply
The input to your treadmill is about 120 volts Ac. The output from the board will be about 30 Ac. Almost nothing on there will be measured in DC. Your particular issue is your motor controller. It needs to be replaced.
Jul 27, 2017 | Reebok treadmill i-run s
Dear Sir, I have astec model AA23160 power supply input Ac 100-240 5A max output Dc +5v 23A, +12v 22A max it does not give output the LED give yellow when it is ON. the two cooling fans were also not...
Hi! l have have the same problem whit the Asctec model AA23160 power supply.But l need to know how many time your power supply worked: How many time do you use it?
Thank's!
Aug 13, 2010 | Astec 300w AT Power supply 190170-01...
Yesterday I bought an STP-120 SIMA power inverter
you inverter was not fully charged because it requires a 110/220 v ac as specified in the manual; to charge it so it is impossible for the aircraft 15vdc to charge it
Jan 27, 2010 | APC DC to AC power inverter ( external ) -...
Adapter/power supply cord missing emachine model SP 30A speakers
AC/DC Adapter
Model MA-9200
Input 120 VAC 60 Hz
Output 9 VAC 200 Ma
Class 2 Transformer
Oct 17, 2009 | Audio Players & Recorders
NPS-200PB-73M
SPECIFICATIONS:
Dimensions 5.9"W (150mm) x 3.4"H (86mm) x 5.5"D (140mm)
Special Features Dell Proprietary Main ATX & 6 Pin Auxiliary Connectors
AC Input 100-120V/7A 60Hz 200-240V/3.5A 50Hz
DC Output Voltage 3.3V 5V12V
Total Output Max Load 200W
Regards.
Jul 20, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Can anyone tell me if the 12 volt powersupply is 12 volt AC or DC ?
Model HER-48-12010
P/N: 68300021-0013
AC Input
DC Output
Sep 20, 2008 | Compaq S 200 Flatbed Scanner
Lite On (PS-5101-2B) (ps51012b) 145-Watt Power Supply Logo
83 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Michael Vanidestine
Michael Vanidestine
Level 1 Expert
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
