Question about 2wire HomePortal® 1800HW Router (1000400212000LNR)
1800hg 2wire modem problem!
When i on the power for my 1800hg 2wire router, there is a quick blink of lights and then it just dies. Does anyone know where the problem lies? adaptor or the modem? Thanks
  • 1 more comment
  • Caveman99 May 12, 2008
    Thanks, used this router for more than a year. Will go check with the dealer, see if i can get any replacement. Thanks again.
  • Mark Gil
    Mark Gil May 11, 2010
    Is this the intial setup of this was working before?? IF this is a initial setup make sure the physical connection is correct and the modem is already configure correctly with your ISP.
  • serra baby
    serra baby May 11, 2010
    hello!
    if you dont see any stable light on any of led lights on your router, possible that the physical connections are not properly connected or the router istself is not properly configured
  • 2wire Master
  • 6,487 Answers
Feel free to contact us back in the furture for any concern....
Posted on Oct 25, 2008
    Novelist:
  • 173 Answers
Try to use another power adapter with the similar power output aside from what came with your 2wire modem if you have one, if it works fine that means the original power adapter is busted and i think it is also covered by the warranty, get a replacement from the store where you purchased it.
oh by the way, it's normal for all of the lights on your modem or router to blink when you initially power on the hardware, usually your hardware will perform a system check for several seconds to verify if there is any problem after that, several lights if not one should remain steady like the power light, the other lights on the other hand like the ethernet(LAN) or the wireless(WLAN) will most likely flicker from now and then because it indicates activity between the modem and the device/s attach to it.
Hope that answer your concern about your 2wire modem.
Posted on May 12, 2008
How can i set up my 2wire 1800hg gateway modem without the disc on windows vista
your 2wire 1800HG modem has the cd-less install or Greenlight technology in it. it will automatically startup once you open a browser, (preferably IE. However, if you don't see it, try pushing the reset button at the back of the unit for 30 sec. open IE, then you will see the installation page.
NOTE: make sure you know what your username and password is... for authentication purpose...
Apr 14, 2011 | 2wire 1800HG Router (RG1800HG00)
What are the power requirements for this modem - I have a 9V 1000mA powersupply that fits - is this the right voltage?
My 2Wire 1800hg original power transformer shows OUTPUT of 6V (Volt) and 2000ma. (The 2000ma is also known as 2amp, like 24 inches is also known as 2 feet). On polarity the inside hole is positive (+).
Oct 20, 2010 | 2wire 1800HG Router (RG1800HG00)
There is no power to my router. how do i know if i need a new power cord or if it is defective unit. 2wire 1800HG older model
You can measure the power cord voltage with a voltmeter. The specifications, and voltage output are on the transformer, or modem body. If you don't have a voltmeter, you can take the power supply into Best Buy, Radio Shack, or any computer shop, and they'll measure it for you. If the voltage is ok on the power supply, chances are you have a bad modem, in which case you'd be better off getting a new one. Hope this helps.
May 14, 2010 | 2wire HomePortal 1800HG Router...
Xbox 360 wireless adapter wont connect to my 2wire
Have you tried removing all security protocols on the 2wire and trying to connect?
Good Luck!
Jesse
Jan 05, 2010 | 2wire HomePortal 1800HG Router...
AT&T 2Wire 1800HG set up on Ubuntu
https://help.ubuntu.com/7.04/internet/C/connect-to-internet.html
Jan 03, 2010 | 2wire 1800HG Router (RG1800HG00)
2wire 1800HG router keeps resetting
1) Check power cord. 2wire has known issues with power cords being defective. If you have a Multimeter, I would check to ensure the correct voltage and amperage and being delivered to the router first.
2) Need to resolve the "resetting problem" first. Then attack the port forwarding issue.
Aug 15, 2009 | 2wire 2700HG-B Router (2700HGB)
1800HG DSL modem/router: Cannot access any of the setup pages.
you have to set the unit to default hold the reset button for about 30 seconds the small hole
Jul 11, 2009 | 2wire 1800HG Router (RG1800HG00)
Red Broadband Link
log into the modem and unchk the box for wireless "b" enhancement. should stop disconnecting wirelessly also check for interference.
Jul 10, 2009 | 2wire 1800HG Router (RG1800HG00)
Anyon know of a power supply cord for a gateway 2-wire modem for a 1800 gateway
I ran into the same problem; not many people can seem to find a power cord for these things.
I went to Radio Shack, and was told that no such replacement cord exists anywhere. I had a hunch that this guy was full of poo, so I went to the Radio Shack across town. Lo and behold, they had what I was looking for.
Just take your 2wire modem into the store and ask for a 3-7.5v 2A AC adapter. They may be hard to find, but they are around. Don't forget to make sure they give you the correct tip for the modem.
Hope this helps,
Jon
Jul 22, 2008 | 2wire 1800HG Router (RG1800HG00)
Replaced my old 2wire 1800HG with a new one and can't connect it
hi!
first of all, let's try to make the broadband link light turn green. open any browser, go the modem's UI by typing gateway.2wire.net or homeportal/setup on the address bar, follow the onscreen instructions on running the system setup wizard. it should make the broadband link green now. for wireless connection, click on the airport icon, and select on the SSID or network name in the drop down menu. if ssid is not on the drop down menu, click on other. type the SSID in the network name field and wireless security is none. (SSID is the last 3 nos. of the SN)
Apr 22, 2008 | 2wire 1800HG Router (RG1800HG00)
2wire HomePortal® 1800HW Router (1000400212000LNR) Logo
190 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
