Question about Car Audio & Video
Had car repairs done recentlty & when radio came back on it needed code putinq in. however having put what i thought to be correct code locked 10 now appears on the unit. how do i unlock it. thanks.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
Try leaving the radio on for and hour or two..
Posted on Aug 31, 2010
2005 Chevy Cavalier, get code out of radio to get unlock code from GM
oN STERIOS THIS NEW YOUR ONLY CHOICE IS TO TAKE THE RADIO TO THE DEALER AND HAVE THEM SHIP IT IN TO THE FACTORY FOR REPAIR AND WHEN YOU GET IT BACK YOU WILL PROBABLY HAVE TO TAKE IT TO THE DEALER TO HAVE IT PROGRAMMED
Apr 06, 2013 | Chevrolet Cavalier Cars & Trucks
How do i reset computer on a delta88 year 1988
There is no resetting any cars computer
Everyone reads & copies the others questions
All you doing is asking to turn off the Malfunction
or DTC (diagnostic trouble code) light
Then you loose all stored data your mechanic needs
to find & resolve any problem
No resetting,not windows 7.
When repairs are complete most lights go out,
some need to be turned off (not reset)
That is done with a code reader,professional scan tool,
or disconnecting the battery
If you disconnect the battery on some vehicles,not much will
work again,no radio,door locks,all kinds of bad things happen.
You have an older OBD1 car 1980 thru 1995
Only if you have had repairs made & ALL issues resolve,
then disconnect the battery. Off & back on,no need to hang out
for 30 min
Jun 09, 2012 | 1988 Oldsmobile Delta 88
My sterio in my truck locked on,me what can I do to fix it my self it doesnt even let me put in a code no more
If you try to input the code a certain number of times it will lock, normally code 10? If this is so then ensure you have the CORRECT code and try this:-(Gives another 3 chances) If you have a code 13 it is a dealer only fix.
1- Drivers door open.
2- ign, off.
3- radio off.
4- press and hold "6".
5- turn on radio.
6- hold "6" 30-40sec.
7- if nothing happens let it go.
8- try 3 more times.
This operation depends on what system & serial number you have installed.
Mar 30, 2011 | Ford Car Audio & Video
Check engine light comes on intermittently. Code 14, replaced air idle control valve. Ck engine light still comes on. What the problem?
If you are secure that the repair was done correctly, pull the 7.5 backup fuse (with the car turned off) in the under hood fuse box and wait 10 or 15 seconds before putting it back in. That should clear your engine light. You will have to reset your clock, and any selected radio settings.
If you do not have an anti-theft radio, you could simply disconnect the negative battery terminal for 10 or 15 seconds and that would do the same thing, but if you have an anti-theft radio that would require a code reset, meaning that you would have to have the five digit code.
If the engine light comes back on after the reset, then something has gone wrong with the repair.
Hope this helps.
Oct 26, 2009 | 1988 Honda Accord 4 Door
Radio Locked Up, due to wrong code entered.....
Leave the radio on for one hour and the radio will reset. Works on all locked Mitsubishi radios. Dont go opening up the radio for no reason....
Jun 21, 2009 | 2001 Mitsubishi Montero
Correct radio unlock code not working on 1995 Honda Accord
One of these ways will work. Try this first. Remove the negative battery cable and leave it off for 5 minutes. Hook it back up and then enter the correct code. If that does not work, just turn the radio on, and drive around for one hour. The radio will reset itself and you will then be able to insert the code.
Feb 23, 2009 | Jensen VM9510 Car DVD Player
Ford mondeo radio says locked
HI if you have the correct code, then pushing and holding the 6 button will give you one more attempt, if you enter the wrong code again, may as well put the radio in the bin .
make sure the code is correct!!
regards
Mark
www.carradiocode.co.uk
Nov 15, 2008 | Car Audio & Video
Code wire(s)
i have a saab 900 se, my car stereo has a few connections on the back you just plug them in. once you have power enter the code 2455 or 2544. oh get a couple of scewers to get the radio out unless you have the tool. these codes work on my car. or when you pull out the radio sometimes the code is on top of the radio. just check connections make sure things look right. hope this helps
Jul 18, 2008 | 1995 Saab 900
How to unlock my radio (5000 RDS ford) from the LOCK 10
if locked 10 appears:
ensure the radio is off.press and hold preset 6 and switch radio on keeping 6 pressed.the display should change after a few seconds and u can then enter the pin code but i beleive u only get 2 or 3 attempts so make sure u have correct pin or it will need to be sent away to be unlocked
robbie
Jun 28, 2008 | 2003 Ford Focus
Unlocking of a car radio
chardaker,
Try leaving the car sit with the key on(the engine doesn't need to be started) for 10 or 20 minutes - often that will return the radio to where it will again be prompting you for the code.
Feb 20, 2008 | Car Audio & Video
Open Questions:
Car Audio & Video Logo
14 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
