Question about Goldstar Refrigerators
Rubber at the doors no longer closed properly
  • Goldstar Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 01, 2010
Drivers door will not latch closed
It appears that the door is not closing far enough for the latch to move to the second position in it's movement. ie on not closing the door properly you will see that it is latched but not closed . Push it harder and it closes properly. Lubricate the latch mechanism and you may have to adjust the catch position to allow the lock to go to the fully locked position POssible rubbers to cold and stiff to allow the door to close easily
Feb 03, 2013 | 1997 Ford Escort
Door will not close completly
When you say "oven door will not close properly", do you mean that it closes but not tightly against the rubber seal on the oven cavity?
Or is it some other closing problem?
If it is the former, then it is a sign of the door hinge springs wearing out. The solution to this is to replace both hinges on the offending door.
Sep 08, 2011 | Ovens
Oven door does not close properly
When you say "oven door does not close properly", do you mean that it closes but not tightly against the rubber seal on the oven cavity?
Sep 01, 2011 | Neff B1421 Electric Single Oven
Hello. I have a 2000 Mitsubishi Montero Sport. The rear door/hatch no longer stays closed tight enough, so the door ajar light flickers on and off. As a result, my alarm goes off at random times. Could...
The better solution is to fix the hatch so it closes tightly. The latch hooks on to an adjustable loop. The hatch closes on to the rubber seal: if this is damaged, fix or replace. There may be some adjustable rubber bump stops as well. Lastly, check that the door ajar sensor is not loose.
Sep 08, 2017 | 2000 Mitsubishi Montero Sport
Why does my ge front load washer leak from the door and will this be expensive to fix?
Hi from retired Englishman in SW France @21:10 Sat evening.
I think that we can only presume that the rubber sealing ring has been damaged, that is if the door is closing properly. If it is not closing properly the microswitch which senses if it is closed or not requires adjustment- which I think is less likely than the damaged rubber surround to the drum.
Sorry but I would not be able to guess what it would cost from where-ever (?) you live. It would have to be changed anyway unfortunately ;-0(
Best of luck,
John C
Jan 29, 2011 | GE WSXH208A Front Load Washer
Dodge caravan back sliding door won't open (especially when it's cold). Lock seems to work but it seems the handle isn't engaging. Any ideas?
i would spray a lubercet on the in side were is catches and take veg oil to all the doors rubbers that will provet any sticking and last longer than w-d40 and grease the bottom where the track is of the side door alot of dirt gets built up in there and will not allow the door to open and close properly.
Jan 23, 2011 | 1996 Dodge Caravan
Oven door no longer closes
sounds as if the hinges are no longer closing properly,its the only thing gonna stop door from closing, unless you can physically see something protruding from the door that would stop it. no t totally unheard of for the hinges to fail, especially after a self clean cycle
Mar 14, 2008 | GE Profile PFIC1N Bottom Freezer French...
Refrigerators Logo
46 people viewed this question
Top Goldstar Refrigerators Experts
AJMAL KHAN
Tom Chichester
Are you a Goldstar Refrigerator Expert? Answer questions, earn points and help others
