Question about D-Link AirPlus DI-524 Wireless Router
Not connecting with router
Mine laptop showing the gud strength of singnal but still not working with the wirless router
Netgear came as optus packege
Posted on Jun 13, 2008
    Novelist:
  • 144 Answers
Hello!
-- what is your laptops ip address?
-- what is the brand and model number of your wireless adapter?
-- what is the operating system of your computer?
-- can you get online if you connect the laptop directly to the router?
Posted on May 09, 2008
Continues to say acquiring ip address? Singnal strength is excellent! What's the problem?
Quite offer the user name and password have been entered incorrectly. The first action I take is to reset the router back to factory sitting and re-enter your details again. Remember that spaces and punctuation has to be entered exactly as required by your isp. Passwords and sometimes user names are case sensitive. To reset most router there is a reset button at the back of the router which needs to be pressed for up to 30 seconds with power on to complete the reset. Then check your computer/laptop /Tablet to make sure that the password you have used is correct. I start with the router because that is normally the most troublesome.
Oct 01, 2014 | Computers & Internet
I have a acer laptop the keeps turning off wirless connection
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Aug 20, 2012 | Computers & Internet
Not getting good signal strength frm router with wirless computer
There are signal boosters and repeaters available, but generally run in the $250 range for decent ones. What you can do is get a wireless access point installed. It requires an ethernet cable to the router to connect it, but you can put that in the house close to where you are and feed off of it.
Jun 14, 2009 | 2wire Computers & Internet
Wirless signal strength fades
it sound like to me that someone is logging on to your router set up your laptop with wep or wap with 128 bit enycription and let me know how that works
Mar 17, 2009 | Toshiba Satellite A105 Notebook
Unable to get IP address on SMC2804WBRP-G
You need to setup security on the laptop/access point. Apparently it has been setup in the router.
Jan 25, 2009 | SMC Barricade g SMC2804WBRP-G Wireless...
Low to no signal strength
Try agusting the wirless properties for your wirless card. You will need to go uder start then go to conect to and the show all conecsions. The you will need to right clcik on the wirless conecsion and go to properties. Now you will click the button that says configure. I hope this helps
Jan 01, 2009 | 2wire HomePortal 1800HG Router...
Can't launch Internet
seems like there is DNS confiuration set in the wirless porperties page.
right click on the "My network Places" go to porperties. right click on the wirless connection.
go to TCP/IP under the "connection uses the following items." high lite the TCP/IP adn select the porperties box.
under hte genral tab
Obtians an IP address automatically
under alternate configuration
make sure nothing is checked. click OK and close.
try to connect again.
Oct 28, 2008 | 2wire 1800HG Router (RG1800HG00)
Wireless signal
right click on your network icon in the taskbar and go to view connections and clear all connections and allow it to find the connections again, this time it should find yours first
Aug 21, 2008 | Belkin (F5D7231-4) Wireless Router
Im not getting any singnal on my router
check the cable connections..reset the router..otherwise please contact your service provider
May 01, 2008 | Linksys Wireless-G WRT54G Router
D-Link AirPlus DI-524 Wireless Router Logo
66 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
