Question about Lexmark X4270 All-In-One InkJet Printer
Paper jam X4270 how do you open the machine to get to the paper jam
  • LXK Chris
    LXK Chris Aug 31, 2010
    Try to check in the feeder if you can get a hold of the paper jam. If not, unplug the printer from the power source, open the cover where the cartridges are and see if you can get a better hold of the paper jam. Then, replug printer to power source.
  • karen168 Aug 31, 2010
    This fixed the printer
    Genius:
  • 1,087 Answers
Great job karen168!!!
Posted on Aug 31, 2010
X4270 paper feed jam
You may have remnants of torn paper left in the feed rollers or beyond -from a prior jam. Other causes include:
  • Overheating
  • Wrong Paper Type
  • Printing Labels
  • Cracked or Dirty Rollers
  • Use of Wrong Tray
  • Incorrect Loading of Paper
  • Paper Overload
Nov 21, 2013 | Lexmark X4270 All-in-One Multifunction...
My pinter is an X4270. It prints well, but will not feed the paper to fax, scan or copy. I keep getting a clear paper jam reading, but there is no paper jam.
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 07, 2011 | Lexmark X4270 All-In-One InkJet Printer
Error e03, but there is no jammed paper
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Lexmark fax machine series x4270 has an error code saying #1200
Please click on this link :
http://support.lexmark.com/perl/support/support.cgi
and then click on support ,once the page is opened please center X4270 in
Search by Model ,after that choose Lexmark X4270 ,after seconds a page will open and then in
Search the KnowledgeBasePut this number and follow the steps given:
ENUS23485
good luck...
Oct 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
Paper jams in Lexmark X4270
Mine is doing the exact same thing and I need to know how to fix it, I am expecting some very important paperwork and I need the fax machine working!
Aug 27, 2008 | Lexmark X4270 All-In-One InkJet Printer
Fax Machine
Turn the printer off and open the access cover.
Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Watch the paper as it feeds through and try to determine where the jam is occurring.
Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
Turn the printer off.
Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Mar 05, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x4270 paper jam
Have you looked inside the roller assembly. More often then not a small piece of paper will get stuck deep inside the roller assembly. This will lead to paper jam errors. Inspect more closely. You will probably find some tiny tidbit somewhere.
Dec 20, 2007 | Lexmark X4270 All-In-One InkJet Printer
X4270 lexmark printer hook up
I have a lexmark X4270, I'm having a problem with the fax machine, the display keeps displaying "clear paper Jam", however there is no paper jam. I'm also not being able to recieve or send any faxes. I'm low on ink, would this prevent sending faxes? Any suggestions?
Nov 06, 2007 | Lexmark X4270 All-In-One InkJet Printer
Help
check inside around the rollers as it sounds as if there is paper caught in the mechanism causing it to jam.
Jul 30, 2007 | Lexmark X4270 All-In-One InkJet Printer
Paper pull only fron the right side
You may have a jam insude the unit. Open it up as if you are replacing cartridge, check everywhere for a tiny paper jam, with a torch, near roller, carriage etc. good luck xxx lilacgerry
Dec 30, 2006 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
19 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
