Question about Sport & Outdoor - Others
How do i get a plug in my 12 guage shadow f-1 serial# J39152G
  • tazhunter92 Aug 31, 2010
    how do i get a plug in my 12 guage shadow f-1 shotgun serial# J39152G
  • 864 Answers
Well i take it since its in sports and outdoors theres very few things with the name "12 gauge shadow f1" Now i need to know first is the the 3 shot model or the extended model? Because if its the 3 shot model you dont need a plug. Because it is already 3 shots. But if you can answer that ima go see about taking some pictures to show you how to take it apart
Posted on Sep 08, 2010
  • Nathan Ayers
    Nathan Ayers Sep 08, 2010
    at the end of the magazine tube below the barrel there is a screw cap. Take that cap off and becareful because there is a spring. Then inside of that you put the plug at the end of the spring and put the cap back on and you have a plug in the gun.
  • Nathan Ayers
    but for hunting you are only required to have a plug if the gun holds more then 3 shots. An the nikko shadow f1 generally is a 3 shot gun. So ensure that it holds more then 3 shells total 1 in the chamber 2 in the magazine to ensure you need to have a plug.
  • 2,019 Answers
When you remove the knob that holds the barrel on, as you do to clean it, you remove the shell spring and insert your wooden plug. You can make your own or buy it, based on whether you are allowed 1 or 3 shells at a time.
Posted on Aug 31, 2010
  • Kirk Augustin
    Kirk Augustin Sep 01, 2010
    All you have to do is make a wooden dowel long enough so that there only room for the dowel and 2 shells in the magazine tube. Then you unscrew the cap on the magazine tube, remove the spring, insert the dowel, replace the spring, put the cap back on, any you are done.
    If you want to know how long to make the dowel, just take some old fired shells and load it up.
    subtract 2, and that is how long you can make it. But to reduce the spring tension, you can make it more then a half shell shorter than that, as long as it prevents loading a 3rd shell.
    If it is too small in diameter, it could slip through the spring. It would be better if it was thick enough so that it could not do that.
  • Kirk Augustin
    Federal migratory bird law is 3 shells, but that includes one in the barrel, so you can only have 2 in the magazine tube.
  • 2,272 Answers
This appliance is for use on a nominal 120-volt circuit, and has a grounding plug.A temporary adapter may be used to connect this plug to a 2-pole receptacle if a properly grounded outlet is not available.The temporary adapter should be used only until a properly grounded outlet can be installed by a qualified electrician. The green-colored rigid ear, tab, or the like extending from the adapter must be connected to a permanent ground such as a properly grounded outlet box cover. Whenever the adapter is used, it must be held in place by a metal screw. Grounding adapters are not approved for use in Canada. Replace the plug if the grounding pin is damaged or broken. The Green (or Green/Yellow) wire in the cord is the grounding wire. When replacing a plug, this wire must be attached to the grounding pin only. Extension cords connected to this machine should be 12 gauge, three-wire cords with three-prong plugs and outlets. DO NOT use extension cords more than 50 feet (15 m) long. -------------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
NGK y-116v glow plug change over to Champion glow plug what part number???
very difficult to get a cross reference for champion
I did come across a code to explain the part number
it reads like this the Y denotes sheathed type earthed through the plug body
the first 1 is the thread diameter + 10 mm
the next 1 is the battery voltage ---4-12 volts
6 is the serial number
V denotes it is fast heat or rapid glo type
reference -ngktk.co.uk page 114
so if you can get a champion glo plug chart , you are looking for a glo plug that is earthed through the plug body, is 10 mm thread dia is for 12 volts ( serial no is optional , and is a fast or rapid glo type
take the glo plug to a diesel specialist repair shop and see if they can cross reference or have a plug that will do the job
consider it doesn't have to be champion brand
Oct 01, 2016 | Ngk Commercial Series Spark Plug, glow...
How can I tell the age and serial number of my Springfield 947D single shot 12 guage shotgun
You can't do it that way. You shotgun has the serial number on it. It will either be on the side or on the barrel under the forestock.
With that information you check some of the sites below or contact Springfield.
  • Springfield Armory, Inc. - Official Site www.springfield-armory.com ... Springfield Armory is the premier manufacturer of quality handguns for protection and competitive shooting. Customer Service; ... Springfield Custom ...
  • U.S. Military Dates of Manufacture - OldGuns.net oldguns.net/sn_php/mildateslookup.php?file=us_m1grndsp.dat U.S. MILITARY DATES OF MANUFACTURE. ... Springfield: Covering numbers: 1 - 6020771. Please enter a serial number and click the submit button. ...
  • SPRINGFIELD ARMORY US MODEL 1903 RIFLE SERIAL ... www.bowersweapons.com/US MODEL 1903 RIFLE SERIAL NUMBER RANGES.htm SPRINGFIELD ARMORY US MODEL 1903 RIFLE SERIAL NUMBER RANGES (Including Rock Island Arsenal, Remington, and Smith-Corona production)
  • SA, Inc. M1A serial number born on date database (000001 ... m14forum.com > M14 Forum > M14 M1A Forum > Reference
    • 586 POSTS
    • FIRST POST: 2004-12-18
    2004-12-23 · SA, Inc. M1A serial number born on date database (000001 - 100000) ... Inc. M1A serial number born on date database ... springfield armory serial look up,
  • 1911/1911A1 Production Numbers - CoolGunSite.com coolgunsite.com/pistols/colt production.htm 1911/1911A1 Production Numbers: ... Serial Number Range: Manufactured by: Special Notes: ... Springfield : 11,285 : 83856-83900: Colt : 45 : 83901-84400:
  • M1 Garand Serial Numbers - Fulton Armory fulton-armory.com/faqs/M1G-FAQs/tea/m1serial.htm M1 Garand Serial Numbers ... The tables below list only the Springfield Armory and the Winchester Repeating Arms Company serial numbers. Springfield Armory .
  • Springfield serial number lookup website?? - Gunboard's ... forums.gunboards.com > Gunboards.com Discussion Boards
    • 6 POSTS
    • FIRST POST: 2011-01-29
    2011-01-30 · A couple of years back I remember accessing a searchable database to look up serial ... Springfield serial ... up serial numbers by model for Springfield ...
  • SPRINGFIELD ARMORY 1911 SERIAL NUMBER LOOKUP baseoffreethings.net/springfield-armory-1911-serial-number-lookup ... such as we could find a backup and the global hotkeys. springfield armory 1911 serial number lookup ... Manage multiple languages it didn't turn up a graphical ...
  • Serial Number Search ' Springfield XD Forum www.xdtalk.com > Other Handgun Talk > M1911 springfield 1911 serial number search, ... springfield armory serial look up, springfield armory serial lookup, springfield armory serial number lookup,
  • May 09, 2016 | Optics
    Bike started running rough and smoking out of one of the tailpipes. Started while it was at idol.
    Hi, Randy and the usual suspects are:
    1. Spark plugs in bad condition or partially fouled.
    2. Spark plug cables in bad condition or leaking.
    3. Spark plug gap too close or too wide.
    4. Faulty ignition coil, module and or sensor.
    5. Battery nearly discharged.
    6. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
    7. Intermittent short circuit due to damaged wire insulation.
    8. Water or dirt in the fuel system, carburetor or filter.
    9. Fuel tank vent system plugged or carburetor vent line closed off.
    10. Carburetor controls misadjusted.
    11. Damaged carburetor or intake seals.
    12. Loose or dirty ignition module connector at crankcase.
    13. Faulty MAP, CKP, O2, and or CMP sensors.
    14. Incorrect valve timing.
    15. Weak or broken valve springs.
    16. Damage intake or exhaust valve.
    For more information about your issue and valuable free downloads that you need please visit the websites below. Good luck and have a nice day.
    help 2005 Shadow Spirit 750 running rough Honda Shadow Forums Shadow...
    1983 Honda Shadow VT750 NV750 Running Rough
    http://www.vt750dc.com/maintenance/service-manuals
    http://www.partsfish.com/page/oem-parts-for-honda
    Feb 07, 2016 | 2005 Honda VT 750 DC Shadow Spirit
    What year was my winchester model 101 12 guage serial #K479223 manufactured?
    I'm not sure of the exact year, but because it has a serial number on it, I believe that it would have been made after 1968... It wasn't until 1968 that it became mandatory for arms builders to engrave their weapons with a serial number.
    Apr 06, 2015 | Winchester Optics
    I have an old side by side stevens 12 guage shot gun. it was my grand fathers.# h43559 what year is it.
    According to this website (http://www.gundigest.com/gun-collecting-firearm-collecting/sqa-stevens-letter-prefix-serial-numbers) it sounds like it would be between 1913 and 1939.
    Dec 06, 2014 | Cycling
    Where do I plug in my car to find out engine codes on my 93 dodge shadow
    You don't need to, just cycle key, on (not start) off,on,off,on and leave in on position and count flashes of check engine light.
    Will be a 2 digit number with pause in between. For example: 3 flashes, pause, 3 more, is code 33. 1 flash, pause, 2 flashes, is code 12. When you get 5 flashes, pause, 5 more, that's 55 which means end of message.
    Sep 26, 2010 | 1993 Dodge Shadow
    Head light not working
    YOU ARE NOT PRECISE ARE YOU INSTALLING A CUSTOM HEADLIGHT ON THE SHADOW??? iF SO iT NEEDS TO BE GROUNDED....
    Jun 18, 2009 | 2000 Honda VT 1100 C3 Shadow Aero
    Wiring diagram?
    They ain't power leads. They carry heat element current from the cent sw when the motor is running.
    Jan 10, 2009 | Dryers
    Sport & Outdoor - Others Logo
    66 people viewed this question
    Top Sport & Outdoor - Others Experts
    Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
