Question about Brother ML-100 Typewriter
How do you get past the right margin? What do you press for Right Margin release?
  • Brother Master
  • 3,594 Answers
Go to brother.com, click on support, poke around there tou will find a manual.
DickyO
Posted on Sep 01, 2010
How do I increase the margins on the typewriter
To set a margin beyond the left or right margin, move the carrier (or cursor) to that margin, press the Margin Release key, then proceed to move the carrier (or cursor) to the desired position. Then, press the Left or Right margin key to set the new margin. A beep will sound indicating the new margin has been set. When you set a new left or right margin, the previous margin is automatically cleared.
Alternatively, you can type beyond the right margin by pressing the Margin Release key and then continue typing when the carrier (or cursor) stops at the right margin. To type beyond the left margin, press the Margin Release key and then the Backspace key to move the carrier (or cursor) to the position where you want to start typing.
Remember to always use genuine Swintec ribbons and lift-off tapes for your Swintec 7040, which can be found at Swintec Typewriter Supplies .
Aug 19, 2014 | Swintec 7040 Typewriter
How to reset the margins on Brother EM-530
On most electronic typewriters you change the margins by pressing the code button and holding down the press r margin or l margin on the key board. You want the carrier to be where you want the margin set. To set margins beyond the right or left margin move the carrier to the margin and press margin release to go past the margin. Then press code left or right margin.
Jun 30, 2014 | Brother EM-530 Typewriter
How to type in Landscape form of paper .
Roll the paper in sideways. Use the Margin Release key to allow you to backspace to the left of your left margin, then touch the Left Margin key to set the margin at the new location. Go to the right margin and use the Margin Release key again to allow you to space past the right margin, then touch the Right Margin key to set the new margin there.
Type.
Aug 18, 2011 | Brother GX-6750 Typewriter
Setting nargins
The keys used for margin control on the brothers is the ALT key just to the left of the space bar, and the #3,4,& 5 keys.
To move outside the present margin to the left, backspace to the left margin. Press the ALT and '3' keys at the same time to bypass the margin. Back space past the margin to the point where the margin is to be set. At the point you want the new left margin, press the ALT and '4' keys at the same time to set the new left margin.
To move outside the present margin to the right, spacebar over to the right margin. Press the ALT and '3' keys at the same time to bypass the margin. Then spacebar over to the point where the new right margin is to be set. Press the ALT and '5' keys at the same time to set the new right margin.
The basics are that the ALT +3 releases margins, ALT +4 sets the left margin at the point of the carrier, ALT + 5 sets the right margin at the point of the carrier.
Hope this helps.
Mar 15, 2010 | Brother ML-300 Typewriter
I lost the manual for my sx-4000. How do I release the margins.
  1. Press "return" key to left margin.
  2. Press "margin release" key once.
  3. Backspace to where you want the left margin
  4. Press "Margin left" key.
For right margin, space bar to where it is, press margin release, space bar to where you want it, press "margin right" key.
Dec 10, 2009 | Office Equipment & Supplies
Right Margin: I need to move the right margin.
Space bar to where the current right margin is. Press "margin release" key once. Space bar to where you want right margin to be. Press "margin right" once. This should work.
Aug 20, 2009 | Brother ML-100 Typewriter
Margin
Hi:
Just space to the right margin. Press the margin release key once. Space to the desired new spot for the right margin and then press the right margin key once.
Good Luck
Andrew
Jun 23, 2009 | Lexmark Wheelwriter 6 Series II Typewriter
Resetting the margins on a manual typewriter.
I can't be for sure if these are auto set margins, but it sounds like they might be. If they are, first move the carriage as far to the right as you can. Hold the Left Margin Set (not Margin Release) lever as you move the carriage all the way to the left. Release the Margin Set Button or Lever. Now hold the Right Margin Set Button or Lever (not the Margin Release), and move the carriage all the way to the right while holding the Margin Set. Once the carriage is all the way to the right, release the Margin Set. Move the carriage to the place you want to set your left margin. Hit the Left Margin Set and then release. Move the carriage to where you want to set the right margin. Hit the Right Margin Set and release it. It gets confusing, but Margin Release does not set margins. Its sole purpose is only to bypass the margins. Hope this helps.
Feb 19, 2009 | Royal MS 25 Typewriter
SETTTING MARGINS
Use the margin release or mr key to be able to get past the current margins. Position the carrier to where you want the margin then press left or right margin set. Lawrence
Jul 27, 2008 | Brother SX-4000 Typewriter
Margin locked
check that there is nothing dropped into the typewriter that may be blocking the carrier try turning the machine off and moving the carrier by hand to the right side,if it moves ok then turn it back on space the place it stops , touch the MR (margin release button) then try spacing further to the right nad reset the right margin.
Jan 28, 2008 | Swintec 7040 Typewriter
Brother ML-100 Typewriter Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
