I have a linksys PAP2-NA VoIP adapter. I want to lend to my customers but want to lock the access to admin so they cannot see my settings
  • 24 Answers
Hi rajahc,
That's easy (as long as your voip provider didn't locked it themselves), just log-in to your PAP2's setup page and set the user and or admin password under the system tab. Hope this helps
Cheers and best regards,
Posted on May 09, 2008
Password recovery on PAP2
There is a hard reset that can be done via the phone IVR. Connect an analog phone to the RJ-11 port on the PAP2 and pick up the handset, where you will hear dialtone. Press * (4) times and you will be told you are entering the configuration menu. Press 7 3 7 3 8 + # and you will be asked to enter 1 to confirm. Congratulations, you factory-defaulted your PAP2, the adapter will restart and you can log in with the default user name 'admin' with no password.
Mar 06, 2011 | Linksys SPA-2102 NA Analog VoIP Adapter...
Linksys spa2102 i forget the password
Okay here is what you need to do.
try username : user
password : 1234
or
dial ****73738#
if it asks for a password use 8995523# or 7756112# or 5465866# or 50274537# or 78196365# (one of these numbers should work for you)
Hang up.
to check your linksys pap2 IP:
Pick up the phone dial ****110# The voice will tell you the current IP address. Write it down. Now you put that IP address in your browser and you should be able to get into your box type
http://192.168.1.103(for example)/admin/advance
Press enter.
Feb 04, 2011 | Linksys SPA-2102 NA Analog VoIP Adapter...
Hello, I have a Linksys PAP2-VN VoIP adapter from Verizon Voicewing which you know is now defunct. I cannot access the web setup utility because it requires a password that was set up by Verizon and I...
HelloThe Password/user name will provides you by Verizon, try admin:admin
Here is a list of the most prominent VoIP services providers of this type but better service:
1. Vonage 2. Lingo 3. Voip.com 4. BroadVoice 5. Packet8 6. ViaTalk 7. AT&T CallVantage
Hope it helps, if so do rate the solution Good Luck
Dec 28, 2010 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
My linksys spa2101 is locked, i dont have the password, what can i do
If you forgot your user and password of router then press RESET button of router for 10 seconds it is in back side of router. Then all settings defaults. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . If you forgott WEP password in wireless security note down the WEP code it is your password to connect wifi.Then save settings and restart router. Let me know if you need further assistance. Thanks for using FixYa.
Sep 06, 2010 | Linksys SPA-2102 NA Analog VoIP Adapter...
I just bought a SPA-2102 NA, is it possible for a voip provider to lock me out of my device ?or set a password so i cannot reset the device I paided extra to the the unlocked NA version so that i would be...
Yes - if you set provision enable to "yes" or resync from SIP to yes, they can then set your SPA to download a configuration file with an admin password you don't know.
Seems pretty rude (as in legally actionable) if they have actually done this.
Nov 13, 2009 | Linksys SPA-2102 NA Analog VoIP Adapter...
Linksys Router Issue
My VOIP Adapter is lock I can't reach the web page
Jan 09, 2009 | Linksys SPA-2102 NA Analog VoIP Adapter...
Firmware Upgrade?
i have pap2 phone adapter it has some problem. i says This is the voice massage i have got it from my phone.
Connected in the incorrect phone port. Please try other port. If you believe
your correct port. Please log on to your web account to check your states of
your service O108.
This is the voice massage i have got it when you pickup the phone
immediately the voice massage will comes.
please help me anyone
Thanks
partheeban
Jun 08, 2008 | Linksys SPA-2102 NA Analog VoIP Adapter...
Port forwarding
try this.
1.Access setuppge of the router through http://192.168.1.1
2.User name admin Password is password
3.Once you are int he setup page on the left side click port forwarding
4.You may need to ask linksys what are the ports needed to open for the PAP2 device that you have aqnd get its IP address.
Apr 18, 2008 | NetGear WGR614 Router
Not able to connect my voip adapter to internet
hello sir iam working for voip and iam a tech?
and u r using linksys pap2 which is not a router its just a phone adapter so it will work through a router so try this first
is ur modem is a modem router and u have 4 ether net port on it and u can able to access inter net through hard wired and connect this pap 2 adapter through one of the ether net jack on the modem router (ut starcom)>an dit has a fire wall which block ur voice signals so u need to open some ports on it try this link to open all ports and u need to try this with a pc which connected through hard wired on the modem router go to through this link
http://www.portforward.com/english/routers/port_forwarding/UTStarcom/UT-300R2U/Vonage.htm
and also disable the fire wall on the router screen and reboot the linksys pap2 and ur ut star com modem router also and connect ur phone directly to phone jack 1 on the pap 2 device if u have any issues let me know
and rate me solved if its helps thx
Dec 04, 2007 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Password of linksys spa 2102
The Linksys comes with web admin access disabled.
To enable it, pick up phone, dial **** then 723646# , when asked for password, dial 78778839# , when asked for value dial 1# then dial 1 to save.
Then, go to »192.168.0.1/admin/voice/advanced , enter user and password.
If you did a factory reset, you will need to call Linksys technical support.
Nov 09, 2007 | Linksys SPA-2102 NA Analog VoIP Adapter...
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
