Question about Coleman Heating & Cooling
I have a echelon 9.s furnace and the status light on the control panel is blinking 5 times. What does this mean?
5 Suggested Answers
vanni7
  • 163 Answers
SOURCE: I have a GMP100 gas
Hi!!! you just answer your question.change your flame sensor cleaning it wont work..
Posted on Jan 05, 2009
heatman101
  • 43501 Answers
SOURCE: I have a trane xl80
The ignitor on your furnace broke... this is a common problem and not too hard to fix if you have a place to buy the ignitor from... it also can be purchased online...
If you are not confortable with repairing it then call a repairman...
Here is a tip that wrote about how to buy heating and airconditioning parts online.
How to find Air Conditioning, Heating and Furnace parts online.
heatman101
Posted on Nov 30, 2010
  • 14 Answers
SOURCE: Carrier Performance Boost 80 has
this indicates fault 33, on inside of access panel will tell you faulty switch. i believe off top of my head is pressure switch open, this a safety switch to verify that inducer fan is working, several things besides a failed part can cuase this, there is a rubber hose going from the inducer fan houseing to the safety pressure switch, remove hose from fan housing and run a small stick ,wire or torch tip cleaner, down the acces port, calcium builds up inside the port and blocks the sampling of pressure, reassemble and try it, if this works add it to yearly maintenance could need new switch or inducer fan motor, these need to be replaced by a tech, also birds can block flue pipe
Posted on Feb 02, 2011
  • 106 Answers
SOURCE: The control board on my
What make/ model is your furnace? Do you have the wiring diagram to the unit? Usually on the inside of the heater panel on a split unit where the heater is in one location and the outside unit (condensor) is outdoors.
Posted on Aug 02, 2011
I have a Coleman Echelon 9.C Series furnace that is blowing cold air. The red light flashes 5 times and the green light is flashing slowly.I had it checked several times by techsbut that can'
This code Signifies that your furnace's ROLL-OUT-SWITCH or auxiliary switch, may be open. This switch can be reset by pushing the center of red button on your furnace roll-out-switch. Make sure the heater has been cleaned out good, make sure the flue is clean, have the service company check to make sure there is not a cracked heat exchange. Call a reliable service company, not the cheapest there is no reason that they can not find the problem unless they are not qualified. If you have had a company out for the same reason and you have payed them to fix it then they have to fix the problem.
Nov 19, 2014 | Coleman Heating & Cooling
1993 goodman status light 4 times blinking
Witch blower is running, the inducer or the systems blower?
System blower could mean the the high limit is opening and shutting down the systems gas train, I would check this out first.
The other problem could be with the pressure switch for the gas train, it is supplied from the inducer motor, check to see if it is operating fully.
HSI boards do go from time to time, this sounds more like a system control problem.
Jan 24, 2008 | Goodman GMS90703BXA Heater
HK42FZ034 status code light blinks in pattern
Located on the schematic on the inside of the furnace door should be a key for the blink sequence. 2 short blinks then 4 long ones would be a code 24 on that data plate
Apr 13, 2014 | Carrier Furnace Control Board Bryant...
BGU10016A BLINKS CODE 9
www.repairclinic.com/Shop-For-Parts/a36b383/Coleman-Furnace-Parts
Nov 25, 2013 | Coleman 7990-319p Evcon Gas Furnace...
Won't turn on, light flashed 9 times
the 9 blinks is indicating a panel SOS which means the Panel itself is whats causing the 9 blink error code.
Mar 24, 2012 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
The control board on my furnace is blinking 5 times. What does 5 blinks mean? Also what do 6 blinks mean?
Aug 02, 2011 | Heating & Cooling
Bryant furnace plus 90 led code is blinking once then 3 times fast. What does it mean?
these codes are on the inside panel of the front cover of the furnace. lift off and look inside.there should be a code explain chart on the panel by the light. this panel will need to be replace correctly for the furnace to work as there is a door switch.
Jan 31, 2011 | Heating & Cooling
Coleman echelon 9.T furnace will not turn on. Red light blinking
sounds like it is the pressure switch try jumping it out on some models you fool the heater in too working or see if the tubes are blocked , there should be some codes on the front panel or the fan panel
Apr 27, 2010 | Coleman Propane Forced Air Heater...
Garage door indicator light blinks 5 times
this probably means you have a bad photo eye if you happen to have to doors side by side may be picking up on other sides photo eye just switch sides from left to right, however if the lights are coming on but does not mean that photo eye is not bad it has a small circuit board inside of it...
Apr 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a Carrier furnace. When I look at the furnace the red light is blinking. What does that mean?
it is a diagnostic led light count the short and long blinks. Write them down!!! than remove that panel with 5/16 inch nut driver and there is a diagnostic list on the inside.
Please give a rating it matters to fixya alot.
Jan 15, 2009 | Heating & Cooling
Heating & Cooling Logo
90 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
