Question about Samsung PN58C8000 TV
I've got a samsung pn58c8000 plasma tv, screen got broken, had a new screen installed, picture does not fill the screen, fine on top right of screen, gets off by 1/4" by the time its to the top left of the screen, black line 1/4" down left side also..
zjut
  • 106 Answers
SOURCE: Vertical Black line 3 inch width on Plasma Samsung 42C96HD after 2 months of use
Three kinds of detects count for this problem. It could be the Logic board, or the Logic Buffer board, or the PDP panel. Just drop your tv to the warranty depot shop to repair.
Posted on Feb 03, 2008
SOURCE: black line
fixya (four star)
Posted on Mar 20, 2008
steve6375
  • 395 Answers
Panel is faulty. probably bad connections inside the panel.
Not uncommon. Claim on warranty immediately.
Posted on Aug 09, 2008
  • 304 Answers
SOURCE: samsung plasma HPR4272 that had a 4" black vertical line on
There are at least two issues here. First you have bad buffer boards. Second Very possibly a bad X-Main bd and P-Logic bds. Have a trained Samsung tech troubleshoot the set.
Posted on Jul 17, 2009
roety
  • 585 Answers
SOURCE: 42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
Posted on Aug 19, 2009
How do I fix a Samsung TV #pn58c8000yf that has sound but no pix?
Contact the authorized service center. It will be better in case of Plasma displays. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Feb 02, 2015 | Samsung 3D Plasma TV PN58C8000YFXZA...
Pink horizontal lines on samsung plasma tc when white background
I have this same tv and have the same problem, anytime there is a white background there is this pinkinsh tint in the middle of the screen, easily seen during those Apple commercials.
Aug 13, 2012 | Samsung 3D Plasma TV PN58C8000YFXZA...
Is it worth fixing a cracked plasma tv;in particular a samsung pn58c8000? i am asking because I know a person who is selling theirs with cracked screen.It is a brand new television and is not even two...
No, a cracked screen, whatever the type, size or model of tv is terminal, unfixable. In a case of a plasma it's even worse - the crack allows the gases to escape which causes the voltages on the panel to spike, frying the Sustain boards.
The tv's are dead, good for parts at the best - a new panel would cost as much as a new tv, plus the shipping.
Jul 08, 2011 | Samsung PN58C8000 TV
Tv flat screen only half the screen works rest is black
This is casued by the buffer boards on the right or left edge of the plasma tv. You need a direct replacement for the top buffer and then your picture will return!
Please rate if this helps!
Parts are found on ebay or shop jimmy
Mar 07, 2011 | Sony 50 in. Plasma TV
When the Samsung 50" plasma TV is turned on and during the whole time the TV is running there is one small green dot (or light) in around the middle of the screen. It continues and does not go away as the...
Still under warrenty?Yes,call the tv manufacture,get this tv replaced quickly.The Plasma screen is developing a burn in dead pixels.This problems,can't not be repair.Except replaced the Plasma screen itself.The plasma screen panel are 90% of the tvs,not worth repairing,if it damages or broken.Will cost the same as a new tv,if the screen require replacing.Still under warrenty call it in right away to get the picture screen replaced under warrenty.
Oct 04, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Plasma TV screen dull
yep, do u have a digital multimeter? if so, measure all the voltages from the power board located top middle. if u look at the top right of the panel, there is a sticker with va, ve, vset, vsc settings. ground the black lead, and use the red lead to read each of the settings on the pow bd. if there are more than 2 mismatches, its your power board and needs replaced.
Jan 03, 2009 | Samsung PPM42S3 42 in. Plasma Television
How you cann repair a broken plasma tv with out replacement parts
The tv plays fine my sreen is cracked on my Sony 42inch screen can some one help me.
May 13, 2008 | Samsung HCL4715W 47" Rear Projection...
LCD TV with broken screen, good picture??
samsung.com says it has to be repaired by local dealer. get quote first. probably cheaper to just buy a new one.
Jan 08, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Samsung PN58C8000 TV Logo
245 people viewed this question
Jerry Greenberg
Jerry Greenberg
