Question about Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player
Numark no power on numark cdn22 mk4
  • Anonymous Mar 20, 2014
    Dual cd player numark model CDN22 MK4 was set on wrong voltage can i fix it
    Problem Solver:
  • 18 Answers
Bring it back to the shop where you purchased it from and it may be under warranty, if not then the problems yours. Try replacing the fuse in the plug. If bought online, then bring to a repair shop if all else fails, email them
Posted on Jun 04, 2009
2 Suggested Answers
SOURCE: numark
You need a new adaptor...the wires have lost their connection in the cable or plug which isnt user servicable
KK
Posted on Sep 27, 2008
No control on the left cdplayer, left display is not working
I HAVE RECENTLY HAD TWO OF THESE FOR REAIR WITH THE IGHT HAND CHANNEL BEINGAT FAULT. THE FIX ON BOTH OF THESE WAS TOO STRAIGHTEN THE PINS ON THE CONNECTING CABLE AS REPEATED USE HAD BET THEM. BOTH UNITS NOW WORK CORRECTLY.
Feb 26, 2014 | Numark CDN22 MK5 CD Player
One cd player wont read
Take a can of compressed air and blow into the player all around and try it. The heads get dirty over time and stop reading. Clean the dust off the laser head and they usually start working again.
Feb 28, 2013 | Numark Industries Numark CDN 22 Mk4 Double...
Numark 5000FX power
***Please read this reply in its entirity because there's more information way down at the bottom of the reply. Now the below Pro-Audio International Supplier Thormanne, had the power supply for the Numark FX5000. That's where I bought mine and it was shipped fairly quickly. Also here's the part number from my order so you know you're getting the very specific power supply the FX5000 requires.***
1 Stck order code 188821
Numark Power Supply for Numark 5000 FX
each 42.85 EUR, total 42.85 EUR
Tel,-0049-9546-9223-641
Fax,-0049-9546-9223-24
greece@thomann.de
Musikhaus Thomann e.K.
Treppendorf 30
96138 Burgebrach
Germanyhttp://www.thomann.de
Apantiseis stis perissoteres erwtiseis sas, mporeite na breite edw: http://www.thomann.de/gr/faq_99.html
HRA Bamberg Nr. 8988
Also so you are aware you're going to need to pick up an eletrical convertor for electronics built with EURO specs but allows to down step the current to what it is in America. Any Fry's Electronics or Pro-Audio store here in the US will have the one I bought which is a -
MODEL: TC-100A Up/Down Convertor $45.00.
That's it and my mixer is playing wonderfully so there you have it.
Thank you.
Jan 31, 2013 | Numark Industries Numark 5000FX 5 Channel...
I have a Phonic Max 2500 amp and use a Numark 2 channel mixer with CDN 22 mK4 Dual CD. Just in past wekk I've been unable to fade out the track playing oin either side of the mixer (you can still hear...
If you have fader capabilities...and there is still signal "leaking" through...you may try reducing your input gain on each channel of your mixer...as well as make sure you have a good ground connection between your components.
Jun 19, 2011 | Phonic MAX 2500 Amplifier
Use the cdn22 on weekends for 6 hours a night. at least twice a nightone of the cd players said no disc when i put one in. its not always the same side that does it. the only way to correct it is to power...
Check for contamination on the disks that won't load. Also if you have things like cigarette smoke or "fog" machine that can cause the problem. The precision of the head of the CD players is amazing as the tracks are millionths of an inch apart and it doesn''t take much to cause a problem. If trying to load again the disk finally works, then it may not be registering on the hub quite right. Care in centering MAY help.
Mar 14, 2011 | Numark Industries Numark CDN 22 Mk4 Double...
I purchased a Numark CDN22 MK5 about 6 months ago. I used it once that same week. It worked fine. I brought it back out last weekend to use it again and the cd drives do not open. Everything powers on fine...
If the item is still under warranty my first choice would to take it back to the store, if you checked the belts, then I would suspect a bad loading motor or the power feed "about 5 volts" that might be missing.
Dec 27, 2010 | Audio Players & Recorders
Numark 360 21v 750ma Power Supply
Try the following sites
http://www.powerstream.com/power2.html
http://www.platinum-records.com/Numark-21V-750MA-AC-Adapter-Power-Supply-prod7509.htm
Or even a cheap replacement laptop power supply as these usually start at 1000 mA which will give you current to spare and have a longer lifetime. most of these cover from 15V to 24V and are either auto switching or manual select for the voltage. Plus you can pick these up from most electronic / big box / supermarket shelves
Aug 10, 2009 | Numark DM1200 DJ Mixer
Numark dxm power failure?
i'm having the same problem, just wondeered if you found any solutions to this?
Jul 14, 2009 | Numark DM1200 DJ Mixer
Numark
KK
Aug 29, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player Logo
225 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
da surgen
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
