Question about Canon Cameras
My Canon Ixus 210 fell in the water I took the battery out and let it dry when put back in the camera lens came out and than flashed . Since than there is no response
  • Canon Master
  • 17,130 Answers
You should not have put the camera on until it was confirmed that there was no traces of moisture orr water present inside.
What would have happened is that the water had made a short into the circuit board and triggered a signal short to delicate electronics.
It will only be a miracle for the camera to function but what can be done again is to warm slightly , tap the camera into the palm and see if there is any traces of water. If so then get the camera opened and DO NOT PUT IN THE BATTERY.
If you can open probe into to remove all traces of water, use a hair dryer and repeat after an hour till it is confirmed .
Put in the battery only once it is sure that the water oozing has stopped-- there can be water trapped in between and will be shorting circuits,
If no action the cirrccuit board would have failed. check power from battery to the main circuit and mP to finalise.
Posted on Aug 31, 2010
Water Damage Lens Error
Most cameras with retractable lenses are very sensitive to grit (sand, dirt, salt etc.) in the lens mechanics and will shut themselves off if everything is not perfect. It's possible some salty water remained in the works and left a salty residue when it dried out.
Unfortunately, most repair shops will charge you almost what the camera is worth to properly clean it and it is not a job for the do-it-yourselfer.
Apr 27, 2017 | Canon SD4000 IS IXUS 300 HS Digital Camera
I have a Canon SD750 camera. It was the victim of a water flood and I dried the unit completely. After recharging the battery, I couldn't get it to power up. I took the camera apart and found several...
Unfortunately with water damage the camera may work for a few days or even weeks after you first dry it out, but then it will stop working completely. If you have corrosion from water exposure then the camera is gone, it's not worth trying to fix. Even if you replace the main PCB it probably has damage to the lens, LCD screen and flash as well.
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 11, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
My Canon IXUS 860 IS went inside water when it was switched ON mode. Then after 5-10 minutes, I get the camera out of the water. I tried drying it through a hair dryer. Then now its not switching ON.I can...
A hair dryer will only get to the external places. Water got into the camera and when you tried to turn it on, you probably fried the circuits. The correct procedure for drying a camera is to remove the battery and card, dry everything you can get to and then bury the camera in a bowl of dry rice for one week. Even after that, you may have water spots on the inside lens elements and the camera may still not start. Also, if the water was salt water, you might as well give up....it's very corrosive and damaging.
Apr 22, 2011 | Canon IXUS 860 IS Digital Camera
Dropped Ixus 50 in water...!
It may recover afeter drying. However, tap water is full of stuff thats not going to play nice. You are better off gettting a gallon of Distilled water. this is electrically non-conductive and leaves no residue when dried. take out the batts and flash memory and soak the thing for a few seconds. hopefully the tap water and drink have not fully dried and you may get some use back out of it. You need warm heat to dry it out, Place it near a heating vent, heater or other heat source. you can get it as hot as you stand to touch (they are good to about 120 degrees). and a fan for circulation may also help. keep drying for at least a day, even a sunlit spot indoors can help
If water entered the lens group or got on the sensor, you are not likely to be able to repair this camera. repair costs will likely exceed its replacement cost.
Good Luck
Jan 09, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Camera fell in the water for 3 seconds, wont turn on
The best advice is to check with Canon, describe what happened, and take their advice. I think you will do best if it is seawater, or saltwater, to return it for servicing, as salt is deadly to some camera parts, and if you switch on with salt water in, it can cause permanent damage to circuits, and even can create a short between components, particularly the flash circuit. If it is fresh water, and for some reason you don't want to return it, it is best to use a hair dryer on medium or low heat to blow dry as much as possible, with the lens off, and the battery and card compartments also open, and come back to it after about an hour and repeat.Do not heat it to anything more than about skin heat, as evaporation will continue at even room temperature. Do this for most of the day, and leave it for a day or two, or even a week, as open to the air as you can, but in a dust-free environment, preferably in a warmish place, like an airing cupboard, so that all moisture will evaporate, Then try it again with fresh battery. I suspect that if it still won't operate, you could repeat the process, but it is most likely then, that you will have to return it for servicing or repair. I had an Olympus C8080w, and me and the camera were swamped by heavy spray from a wave, and I ran to the local shop, bought some tissues, and dried it immediately. I took it home, zoomed out, dried as much as possible down the lens gap, and left it in warm room. When dried out, some salt crystals were left on the lens barrel on zoom out, but thank the Lord, it still worked, and has not let me down - I did use a damp hanky to try and absorb as much water as possible from the outside, and dilute any surface salt as much as I could. I still use it regularly, but dropping into water is a different matter. - Please post and let us know what happens - and the best of luck
Nov 25, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Ixus 4 broke real bad...
If the battery was in there, it probably shorted something out.
if the fuses saved the power board, you can replace the LCD easily, just get the old one out and look at the manufacturer (Sony or maybe Sharp) and get one on Ebay. Open the camera and if it was fresh water, just dry it out with a hair drier on low heat, or dunk it in 80% alcohol and let it dry. Getting the lens clean might involve removing the lens and getting in there with lens tissue. Most PC boards are alcohol proof as they are cleaned in the manufacturing process in the same manner. Youll have to find the microfuse that blew and either short/bridge it with solder or replace it. If you bought it with a credit card, sometimes they double the warranty length or offer repair service. $500 US sounds high, but Im not familiar with your camera.
Apr 24, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Camera is optically blind after water dry out
It sounds as if you have water inside your lens. There may be water on the CCD (its like the film for digital cameras)...You could try to blow compressed air into the lens (on the side of the zoom and into the lens itself), replacing the whole lens unit, or opening up and drying out the lens unit. - each of these options are listed in increasing difficulty.
Jan 17, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Cameras Logo
20 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
