For no apparent reason my technika tv has suddenly decided it is monochrome and not colour. I know it is not the tv as such, because the dvd player I use with it plays in colour perfectly (attached through a scart). I also know that the aerial is fine as the other tv's in the house running from it are fine. I am sure I probably hit a button without meaning to but haven't been able to work out how to change it back. I even completely reset the tv to factory defaults but that didn't work either. Any ideas would be appreciated. Thanks, Karen Tyers
  • karen_tyers Aug 31, 2010
    Thank you but there is no apparent way to change those settings - btw I am in the UK. I have double checked the menus and the small instruction book and nowhere does it mention different colour systems
  • 11,800 Answers
The only thing that would do that is if you selected the wrong color system = PAL (or SECAM) instead of NTSC. This setting is situated in the programming part of the menu.
Posted on Aug 31, 2010
  • Azrael SRL Aug 31, 2010
    What is the exact model of tv, how it's connected and with what?
How do I unlock Technika DVD player?
Unlock Technika DVD players - DVD Demystifiziert
www.dvddemystifiziert.de/codefree_en/technika.html
Unlock Technika DVD players - DVD hack. Technika DP 301 ... dezoner, dezonner, destravando seu dvd player, leitor de dvd, destravar, desbloquear, regionsfri, ...
Technika LCDDVD19-918 Multi region hack needed ' AVForums
www.avforums.com > ... > Blu-ray & DVD Player Multiregion Hacks
Sep 25, 2014 - Just wandering if there is a multi region hack for the TV/DVD combiTechnika LCDDVD19-918. ... Make sure there is no DVD in player, turn over to DVD on input Technika HDMI DESIGNSS10: Region hack please!
Sep 29, 2014
technika dvdfaw08 region hack
Sep 27, 2014
Technika BRSS10 Bluray Player Hack for DVD & Bluray
Sep 25, 2014
Technika DVDFAW08 Region Code
Dec 14, 2009
More results from www.avforums.com
Nov 26, 2015 | Televison & Video
Technika 19-228
It sounds like you are using a component video cable (red/green/blue) and either the red or blue cable is loose or broken. Most likely the blue. Check both at DVD and TV ends.
Dec 30, 2013 | Televison & Video
User guide for a technika sc 500172
hi i have a technika tv but when i tune it in i dont know how to lock them in
Dec 28, 2010 | Televison & Video
Technika LCD15DVDiD-108 no picture - sound ok
did anyone solve this please? i have the same problem and cant afford expensive repairs x
May 01, 2010 | Televison & Video
I have Technika TV (model Number 15.4-311) with
  • Remove any DVD in the player.
  • At the blue screen type 9735.
  • A menu should pop up. select region and then select the top option which should be region 0 (0= multi-region).
  • Next select exit setup then power off the tv. It should now play all regions.
I just did this myself so i know it works.
Apr 02, 2010 | Televison & Video
Instructions for Technika 19'' LCD TV with built-in Freeview & DVD player LCD
Suddenly my DVD player has stopped playing DVDs I thought I saw an NSTC message come up but is it supposed to be PAL or is that the other way around. Anyway it's not working, it used to but it isn't now. Help please
Nov 08, 2009 | Televison & Video
Daenyx dvd player suddenly won't turn on....no apparent reason
I have a daenyx dv-833b dvd player. the power button does not turn on when pressed. how can this be resolved?
Mar 22, 2009 | Televison & Video
Loss of colour
Hello judithprust
The IC (integrated circuit) that controls color might be bad or the filter for the color burst might be defective. In either case a qualified TV repair person should be enlisted to fix this problem. The color burst signal uses vector mathematics to control the color output of your device, it the color burst is removed the picture will display a monochromatic (black and white) picture.
Thank you,
Shuttle83
Jul 11, 2008 | Panasonic DMR-E55 DVD Recorder
Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Dec 21, 2007 | Televison & Video
DVD picture cuts in and out first 15 minutes
This is like the problem I had for some months. After a lot of exchanging cables and troubleshooting on forums like this, I decided to call in the Sony service engineers.
The problem turned out to be nothing more than a menu selection. You need to check the setup menu under video and select the colour system you are using (NTSC, PAL). The factory setting on the TVs is 'auto' apparently and sometimes a weaker signal will cause the auto colour setting to drop in and out. In our case we set it to PAL and the problem has not recurred.
Sep 03, 2007 | Pioneer DV-545 DVD Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
