Question about ActivCard Gold 2.2 for CAC (gacg22cl)
Error on startup - agquickp.exe can't locate acdbilog.dll
I think it might be part of ACG 3.0 hotfix that was erroneously installed onto ACG 2.2 SP2. After several de-installs and re-installs, I still get the same
startup error or trying to go into ACG 2.2 Utils. How can I get rid of this .dll dependency?
  • yell0wr0se May 10, 2008
    Helpful to know some othe things to look for, but the same error is also coming up when trying to AGG Utils, agutils.exe. Same problem with acdiblog.dll. I've de-installed several times and also completely scanned for all spy/malware, virus, etc., and the system appears clean. I notice the 3.01 version of agquickp (1.8X) and the 2.2 version (1.7X). The v3.01 is not location in what I perceive to be a Windows directory; however, I can't be sure that it is not still 'finding' it. My s/w loads are from very secure/reputable govt. sources, so I'm not sure what has happened that I can't remove the ACG and just re-install. I'll pursue a regmon type application to ensure that there isn't something embedded in the registry that is kicking me. Thanks for your help!
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 268 Answers
Check whether it is something else other than the pogram like virus or spyware by checking with this info.
The process ActivCard Gold Quick Fill belongs to the software ActivCard Gold by ActivCard Corp or ActivCard S.A.
Description: agquickp.exe is located in a subfolder of "C:\Program Files". Known file sizes on Windows XP are 208896 bytes (66% of all occurrence), 131072 bytes.
There is an icon for this program on the taskbar next to the clock. The program has a visible window. Program can be uninstalled in the Control Panel. File agquickp.exe is not a Windows system file. agquickp.exe is able to record inputs. Therefore the technical security rating is 2% dangerous.
External information from Paul Collins:
"QuickPassword" can run at start up. Smart card-based authentication and digital signature client software
Important: Some malware camouflage themselves as agquickp.exe, particularly if they are located in c:\windows or c:\windows\system32 folder. Thus check the agquickp.exe process on your pc whether it is pest. We recommend Security Task Manager for verifying your computer's security.
And you check about numerous startup files here :
http://downloads.subratam.org/startuplist.html
Uninstall ompletely.
Run a virus scan and search whether there are any thing found.
Delete the threats found.
And use the application from the known secured source only.
Then install the software.
You will not be getting any errors.
Good Luck.
Live, Love, Laugh.
Posted on May 10, 2008
Skype kernel32
Skype v6.6.0.106 is the last version which supports XP SP2. If you try install newer version, you will need SP3 installed, or you will get the kernel32 problem "Failed to get proc adress for getLogicalProcessorInformation (KERNEL32.Dll)".
If you don't want to install SP3 for your XP, here is a work around for you to run Skype with XP SP2.
1. Download Skypesetupfull.exe v6.3.30.105;
2. Uninstall your current version of Skype from Control Panel;
3. Block the website download.skype.com in your router or in the
Host file;
4. Delete any auto downloaded skypesetup.msi in %Temp%
folder;
5. Install Skype v6.3.30.105.
Done.
Aug 04, 2013 | Microsoft Windows XP Professional SP2
Error loading zsqiupzq.dll
Go to Run-->msconfig then see under Startup Uncheck the file showing zsqiupzq.dll file..
**Don't forget to rate and give a positive testemonial...If you find my solution helpful**
Have a Nice Day
Oct 10, 2010 | Microsoft Windows XP Professional SP2
Receiving error message: WlanMon.exe - Entry
Try a reinstall of the software sounds like that wlanapi.dll isn't being "Registered" If installing on Vista or Win 7 use Admin mode and try Compatabilty Mode for XP SP2.
Feb 03, 2010 | Blitzz Technology (BWA611) Router
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
Windows xp home addition V2002 SP2 gphone.exe not found
The very first thing we do is to solve your problem about the start-up error. For your information, your operating system was corrupt that is why there is prompt error message appear in the windows start-up. The best thing here to do is to start your computer in safe mode and this can be done by pressing F8 key until a operating system menu will appear. Select Safemode and wait until you get into the User Account Login screen. Enter to your account and then restore your computer to an earlier time. Go to All Programs - Accesories - System Tools - and then select System Restore.
But if this procedure failed, the only last thing should be done is to reinstall your computer operating system. Leave comments for further assistants. okay..
Dec 22, 2009 | Microsoft Windows XP Professional With...
Cannot use my pictures folder in windows XP, error reads Uxcore.d
Try re-installing uxcore.dll file.
To re-install UXCore.dll
Just follow this repair link (http://www.corruptedfilerepair.com/File-Information/UXCore.dll-Windows-Live-Client-UX-Microsoft-Corporation.asp) and download the file named UXcore.dll
To download and install a DLL file, you will first need to download the DLL file and register it on your computer.
Steps:
1. Download the DLL file from the download link on this page and save the file to one of the folders as seen in step 3. .EXE files do not need to be manually registered.
2. Backup the old version of the DLL file.
3. Click Start > Run and type in the following command:
Windows 95, 98, or Me:
regsvr32 \windows\system\UXCore.dll
Windows NT or 2000:
regsvr32 \WINNT\system32\UXCore.dll
Windows XP or Vista or Windows 7:
regsvr32 \windows\system32\UXCore.dll
Download File UXCore.dll
EXE (Executable) Files:
Steps:
1. Download the file to a folder on your computer
2. Scan the .EXE file using an Anti-Virus Scanner.
3. Run the .EXE file by double-clicking the file
ZIP/RAR Archives:
You will need to uncompress the files in the archive using WinRAR or WinZip first.
Nore : Default Location - c:\program files\windows live\installer\uxcore.dll
Jul 17, 2009 | Microsoft Windows XP Home Edition
My windows cannot open exefile and I cannot install spybotsd162.
Dear johan_poliwa, ur windows installer has corrupted or have been deleted. The best possible solution is that u format ur OS.
Mar 19, 2009 | Microsoft Windows Vista Home Basic Edition
AegisE5.dll was not found.
hi,
http://www.fix-all-dll-errors.com/aegise5.dll/
u can go to this site...
as I registered few dll's from this site...worked in my case :)
Jan 03, 2009 | Televison & Video
Svchost exe application location error instruction at 0x00d896bc
This error is generally caused due to conflict between windows updates and svchost.exe. For resolving this problem you have to download a hotfix from microsoft.com. There are some workaround as well to resolve this issue:
Method 1 loadTOCNode(2, 'workaround'); Leave the svchost.exe - Application Error dialog box open, and then follow these steps. Step1: Check whether settings for the Automatic Updates service and for the Background Intelligent Transfer Service (BITS) are correct loadTOCNode(3, 'workaround'); To do this, follow these steps:
  1. Click Start, point to Run, type services.msc, and then click OK.
  2. In the details pane, locate and double-click Automatic Updates.
  3. Click the Log On tab.
  4. Make sure that the Local System account option is selected and that the Allow service to interact with desktop check box is cleared.
  5. Make sure that this service has been enabled in the Hardware Profile list. If this service has not been enabled, click Enable to enable the service.
  6. Click the General tab, and make sure that the Automatic option is selected in the Startup Type list. Under Service status, click Start to start the service if it is not already running.
  7. Repeat steps 2 through 6 for Background Intelligent Transfer Service (BITS).
Step 2: Reregister Windows Update components loadTOCNode(3, 'workaround'); To do this, follow these steps:
  1. Click Start, click Run, type REGSVR32 WUAPI.DLL, and then press ENTER.
  2. When you receive the "DllRegisterServer in WUAPI.DLL succeeded" message, click OK.
  3. Type the following commands in the Open box, one after the other, and then press ENTER after each command:
    REGSVR32 WUAUENG.DLL
    REGSVR32 WUAUENG1.DLL
    REGSVR32 ATL.DLL
    REGSVR32 WUCLTUI.DLL
    REGSVR32 WUPS.DLL
    REGSVR32 WUPS2.DLL
    REGSVR32 WUWEB.DLL
Step 3: Rename the Windows Update temporary folder loadTOCNode(3, 'workaround'); The temporary folder of Windows Update may be corrupted. In this case, you can rename the temporary folder of Windows Update. To do this, follow these steps:
  1. Click Start, click Run, type cmd, and then press ENTER.
  2. At the command prompt, type net stop Wuauserv, and then press ENTER.
  3. Click Start, click Run, type %windir%, and then press ENTER.
  4. In the folder that opens, locate and rename the SoftwareDistribution folder to SDold.
  5. At the command prompt, type net start Wuauserv, and then press ENTER to start the Automatic Updates service.
uparrow.gifBack to the top Method 2 loadTOCNode(2, 'workaround'); Follow these steps:
  1. Click Start, right-click My Computer, and then click Properties.
  2. In the System Properties dialog box, click the Automatic Updates tab.
  3. Click Turn off Automatic Updates, and then click OK.
  4. Restart the computer.
  5. Use the Windows Update Web site to install updates manually.
  6. After you install the updates manually, turn on Automatic Updates.
Link for downloading Hotfix :
http://support.microsoft.com/kb/927891/
Download the one which is for your Operating system.
Dec 26, 2008 | Computers & Internet
Computers & Internet Logo
786 people viewed this question
Top ActivCard Computers & Internet Experts
David Payne
David Payne
Are you an ActivCard Computer and Internet Expert? Answer questions, earn points and help others
