Question about Homedics Elegant Glass LCD Digital Scale SC 400
Looking for owners manual for a Pennsylvania S400 Digital Scale 5lb w/Aux. 100lb
OXO food scale shows erh code
I am having the same problem with the 5lb scale. Turned it on for the first time about 5 days ago and was ok. This morning when I went to use it it gave the ErH code. Would appreciate if any person has an answer. I am waiting for OXO to respond my e-mail.
Apr 14, 2013 | Oxo Good Grips 11-pound Digital Kitchen...
Need to view owners manual to find out how to set the 1 out of 4 user settings!
You did not provide your model number; however, you should be able to find the manual for your scale on this site:
http://www.healthometer.com/Manuals.aspx
May 20, 2011 | Health-O-Meter Health o meter Digital...
When I check my scale with 100lb weight it reads 100 kg or 220 lbs??
you need to turn the calibration setting to 100 lbs, then it will be calibrated
Mar 17, 2011 | Detecto Model 6855 Bariatric Scale
For the Health-o-meter physician's beam scale, how do you know when it is in balance? What should you do to get it in balance?
For any scale you need to have a known weight to calibrate the scale. Try using something like a 5lb bag of flour or 10lb bag of potatoes.
On the top of the scale set the scale to whatever known weight you have on the platform and see if it agrees, if it is just slightly off, then use the adjustment screw to fine tune the scale, it will be at the end of the left side of the arm.
Dec 27, 2010 | Health-O-Meter Health o meter 402KLWH...
How do i get my canon powershot s400 to take atake self timer picture
Hello. I can assist you. Click on your camera's menu and find the rec menu. Then look for a symbol similar to a clock with one hand pointing at about 10:00. I am going to give you a free downloadable copy of the owner manual All of the details about the self timer are on page 60.
http://www.retrevo.com/support/Canon-S400-Digital-Cameras-manual/id/200ag100/t/2/
Regards, Joe
PS please rate my answer. Thanks
Dec 22, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
FIOS remote
I am a FiOs Technician from Pennsylvania.. The most common occurence of this problem I encounter is when the TV is a dual-device.. Meaning that it is a TV with a DVD player or a VCR built into it.. Whenever this occurs, I do the 922 method using either the DVD or the AUX button on the remote instead of the TV button.
By the Way, if this works you must change the volume control to the other device using the 955 code in the Motorola manual afterwards in order to control the volume
I hope this helps
Jul 16, 2008 | Televison & Video
Canon Powershot S400 take blown out outdoor pictures
The onlything i can sugest you try is to reset the camera. Im not sure how to do this other then to remove the rechargable battery and the button battery. Its a little round silver disk looking thing. Let it sit over night and see if it resets. Have you tried snapping a picture from every mode? TV,AV,SCN,Manual and Auto? Do they look washed out on your computer? Can you take a picture at 640X480 (S) and upload it so i can see what it looks like? Post a link to the image.
Mar 24, 2006 | Canon PowerShot S400 / IXUS 400 Digital...
Homedics Elegant Glass LCD Digital Scale SC 400 Logo
189 people viewed this question
Top Homedics Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
