Question about Snom 300 IP Phone
What do I put with my phones Ip address in the address bar to get into my phone settings?
    New Friend:
From your phone go to settings: information: System. It will have the IP address currently assigned to the phone including the gateway and subbed info. It also tells you the current firmware version. you then can go to the ip address in a browser (with any smart screen filter turned off) and type in the ip address and user name & password. If you don't know the password you can try admin / 0000 if that doesn't work you will need to reset the phone from the phone go to settings/ maintenance / reset values if it requires an admin password you will need to download a recovery firmware from snom and follow the instructions on how to restore the hardware to a working state.
Posted on Oct 14, 2017
Dowenload link browen
Posted on Jan 29, 2012
4 Suggested Answers
SOURCE: Please!!! Help with my Grandstream Budge Tone 200 IP phone
all those phones are pure CRABBB!!!!!!!!!!!!!!!!!!!
Posted on Oct 28, 2008
SOURCE: How to configure Avaya's IP Phone 5610?
What IP did you give the phone? When it says discover, its looking for the call server, which it is not finding.
Which system is this on? If IP office, you may need to build an IP route in the system for that subnet.
Posted on Feb 15, 2009
  • 10 Answers
SOURCE: Avaya assighning New static IP address after IP address conflict
If you need to reconfigure the phone press "mute"RESET# where the alphabets correspond to the digits button they appear against on phone. E.g. for R press 7... and so on ..... then the phone will ask reset values? press # to reset and reboot the phone. Then key in the correct IP address for phone .... call server IP address ... router .. files server .... VLAN ID etc ....
If all the settings are done correctly ... and if the phone gets the reach ability to the call server it will work fine...
if you are unsure of these settings.... go to the menu and network options of any working phone and get the correct values from there
Posted on Apr 02, 2009
Do I need internet connection to set up new swann security system even if I don't want to remotely view footage
go to the main menu in DVR find network setup and give it static IP
Example :
IP: 192.168.1.100
Gateway : 192.168.1.1
subnet: 255.255.255.0
then go to your monitor device (computer or smart phone)
inter the IP address (192.168.1.100)
into your browser address bar
Oct 20, 2016 | SWANN Home Security
Unlock Panasonic KX-TSC35SUW Digital Telephone System
Not sure if this would help, but won't hurt to try..
1.
Connect to the Web UI
a.
Connect the Phone and a PC to the network
b.
Check the IP address of the phone using a handset.
[Menu]->[IP Service]->[Network
Setting]->[IP Settings]
c.
Enable the phone's Web UI using a handset
[Menu]->[IP Service]->[Network Setti
ng]->[Embedded Web]->[On]->[Save]
d.
Enter the IP address in a PC's Web Browser.
example: Enter "http://192.168.1.68"
in the address bar of Internet
Explorer
e.
Enter Authentication ID and password
Password:cspass
f.
Now you can upload new Firmware
into the phone using Web browser.
Note: The phone's http server port will automatically close after idle time of 30
minutes.
2.
Factory Reset
a.
Move to Maintenance - Re
set to Defaults screen.
b.
Click [ Reset to Factory Defaults ]
c.
Please wait.
The Base unit will reboot automatically
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Apr 23, 2014 | Panasonic KX-T7636BK Digital Telephone...
Setting static ip address
Do you want to connect your Nokia phone with static ip address you have?You can check the details in user manual or you can search instructions in online.It differ from phone to phone.But you need to wifi modem to connect your ip address to Nokia phone.For home connection ISP provides static ip address.You can use only that.But mobile phone network providers won't give static ip for phone connection.To check ip address you can visit the site Ip-details.com
Jul 24, 2013 | Nokia Cell Phones
How do i manually configure and ip address for the mitel 5224 ip phone?
Press and hold the up arrow.
Configure Phone - Yes
network parameters - yes
press no until you see "change" and press yes.
You will need to set the following appropriately.
IP address, Subnet address, default gateway, ICP controller address, TFTP address, VLAN ID, VLAN priority, DiffServe Value, DNS address.
Normally it is not necessary to set the phone static except for testing. If your network and DHCP server is set up properly, you are not gaining any benefit for setting it static.
Also, you should find out what the other IP addressess are that are static on the Voice subnet. Along with that, you will need to know the DHCP range. These are needed so you don't assign a duplicate IP address to your network. Assign the phone to the wrong device could do great harm to your network. Assign it to use the same IP address as the phone system and none of your phones will operate.
Use with caution,
Mark
Feb 10, 2011 | Mitel 5224 IP Phone
IP address
your voip enabled phone uses dynamic ip addressing so doesn't have a fixed ip. however if you want to configure the phone Connect the WAN port of the SPA922 to your network (router, switch or hub). Make sure that you have a DHCP server so that the SPA922 will get the IP address.
To login to web based administration follow the steps
Access the web based setup page of the SPA922. Verify the IP address through the LCD. Click Menu then press 9. It should show you the DHCP IP address. Open a browser and type that in the Address bar.
Click Admin Login .
Note: The SPA922 does not have a username and password by default. If you are asked for a username and password and you have not configured a password, it means that the SPA921 is locked by your VoIP provider. You need to obtain the password from your VoIP provider.
if this helps resolve your issue please vote for me. thank for using fixya.
Aug 10, 2009 | Linksys SPA922 IP Phone
Polycom SoundPoint 550-Only Showing 1 line
On the phone, press the menu button, then status, then IP status or whatever and get the phone's IP address. Write the ip address down. On your computer, open up a web browser and input the phone's IP address into the address bar and press enter. This should arrive you at the web gui for that phone. It'll probably ask you for login credentials; by default, the name is "Polycom" (yes , it is case-sensetive) and the password is 456. Once you are logged in, you should see several links like "General" "Network" "Sip" and "Lines". click on Lines. under "line 1", you will see the configuration for that line. simply duplicate the entries for lines 2, 3, and 4.
Jul 29, 2009 | Polycom SoundPoint IP 550 IP Phone
Feb 13, 2009 | Avaya 5610 IP Phone
GPRS says "Invalid settings"
Because I bought the phone in the Internet, I needed to have the Ip address, Apn number, T-mobile Ip number and Port number and put them in my phone in order to my Internet to work properly.
Jan 17, 2009 | LG KG800 Cellular Phone
Trying to change passcode on Mitel 5215: worker has left without letting us know the code! Have put phone IP address into IE address bar but only get "page cannot be displayed". How do I access...
The voicemail passcode. It's a 5215. I read the manual that says you can reset passwords by putting the phone's IP address into your web browser, but that just gives me "page cannot be displayed". Don't know what to do next.
Sep 15, 2008 | Mitel Lands Phones
Cisco 7960G IP Phone Problem
Try to manually reset the phone - **#"Settings" (this will unlock the configuration) + Network + menu under number "33" - erase the configuration. Then the phone configuration will be erased. Also you can manually set IP address and TFTP server
Sep 11, 2007 | Cisco 7940G IP Phone
Snom 300 IP Phone Logo
110 people viewed this question
Top Snom Computers & Internet Experts
David Payne
David Payne
Are you a Snom Computer and Internet Expert? Answer questions, earn points and help others
